Results 1 to 25 of 25
Thread: Engine paint
    RI ,USA
    Default Engine paint
    Looking for suggestions for engine paint. Engine is and old 700 lb (with gear) Mercedes. Not coming out. Prep suggestions welcome too. thanks
    Default Re: Engine paint
    How dutty is it ?How rusty? What color?
    soap,water,wire brushes,ospho, more elbow grease,rattle can primer,rattle can enamal.
    Jan 2011
    Norwalk CT
    Hard to argue with that. Autoparts stores all sell engine paint in rattle cans.
    I have painted a lot of engines in situ with a cheap disposable 1" brush. Alkyd Enamel from a one pint can (Rustoleum) no overspray, and the application pressure (per sg/inch) is much higher for a better bond.
    Feb 2018
    If it's particularly rusty, you might consider POR-15. The acronym "paint over rust" isn't quite accurate, as you still need to knock off anything loose, degrease, and ideally use their etching solution prior to paint. But it goes on easy with a brush, and bonds very well.
    Downsides: I would try to avoid threads, or anything that comes on and off, and you have to top coat it if you're concerned about UV.
    Aug 2016
    Queens, NY
    i used brush applied hardware store generic brand rustoleum type primer and paint and i'm very happy with it..
    after maybe five years there's just a little bit of rust spotting but i expected to reapply and touch up here and there.
    pulled off the big moveable bits, alternator, starter, brackets, and did dusting, mild water soluble degreaser, scraper, wire brush, followed by brush on ospho
    i considered por-15 but thought if i wasn't getting down to bare iron everywhere than the bonding would only be as good as the original undercoat and maybe not worth the extra expense.
    RI ,USA
    How do any of these handle engine heat?
    Definitely needs good cleaning. A lot of tough to reach spots. Some look damn near impossible.
    May 2007
    Seattle
    Back in 1980, when I was first fishing, my boss took me down in the engine room. We brushed the worst of the rust off the Cummins and each took a rattle can and sprayed grey paint. "looks great," he said. "We call that a squarehead overhaul...."
    Elect a clown expect a circus
    I don't think heat is an issue, I have painted a lot of engines over the years, too many to count and never used anything other than enamel.
    (If you think about a painted object sitting out in the sun on a hot day it is for sure to hot to touch and that is well over engine operating temps)
    RI ,USA
    Any favorite cleaner/degreasers?
    Nov 2006
    Winnipeg, Manitoba, Canada
    If you would like to hide any leaks, use black like MerCruiser. If you would rather see where the leaks are, use a lighter colour.
    I painted a 302 Ford engine for a car with blue Rustoleum and had no problems with it lasting well.
    RI ,USA
    No leaks to worry about.
    Knock on wood.
    Dec 2009
    Victoria, BC
    I use tin foil to wrap hoses etc to avoid over spray.
    May 2012
    UK. Cornwall, Suffolk.
    Quote Originally Posted by mariner2k View Post
    I just use petrol (gasoline). You should use a primer, then an enamel paint of your choice which suits the primer. I just painted my engines with enamel straight on the metal, because I'm a savage.
    I would agree with "Rustoleum".
    RI ,USA
    looks good
    Oh, ... I used paint thinner and tooth brushes and little wire brushes with lots of rags and paper towels for cleaning.
    Quite the difference between before & after - nice!
    oh gawd, you have red and green port n stbd engines ?
    May 2012
    Sorry.
    Sorry.
    I like it! You coulda just told Bruce they were painted that way for Christmas...
    Feb 2013
    These Guys have all the stuff, it's just not cheap.
    https://www.eastwood.com/paints/underhood-paints.html
    But I would imagine that someone has "Marine Engine Paint" at three times the price.
    Quote Originally Posted by ShorelineJohn View Post
    I got some Chris Craft Blue paint (to match existing) from Chris-Craft-Parts.com - $10.95 for a regular size rattle can - which I though was fair. Nice folks too. No connection, just a happy customer.
    Feb 2013
    That is cheaper than anything Eastwood carries. I think I paid about $35.00 for a rattle can full of Mopar Black touchup paint. But it did do a very good job.
    Could be he cut me a deal, as I was buying a new oil pan & bell housing (both cast aluminum) 'cause the engine hoist tipped over with the freshly rebuilt engine attached.
