Mocking up cabinetry and looking at space requirements for my H28 fit out has me jumping forward a bit to what batteries I need and therefore what battery management system I might need.
I’m a complete numpty when it comes to anything electrical (it’s akin to witchcraft to me) so I had wanted to keep my electrics simple enough for me to fit and manage myself - but for the same reason all and any comments and advice will be very welcome.
I estimate a maximum daily draw of @100AMPS, the alternator that comes with my Yanmar 3YM20 is rated at 125AMP. I’m not looking at any solar charging options just yet but I want to set up so that I’m ready for it (budget pending) and I am questioning whether I should allow for shore charging or not - ie whether to ignore shore charging and just plan for solar charging to maintain the batteries..?? Or make sure that I have allowance for both.
I’ve had a chat with my local battery supplier guys (Battery world Australia) about deep cycle house batteries and, although we didn’t talk about my start battery, they have offered the following options:
- Lithium battery: Enerdrive ePOWER B-TEC 200Ah Lithium Battery 40A DC2DC + 40A AC with ePro+ Monitor Charger Pack - $AUD 4152.00 (though I’ve found the same system elsewhere on-line for $3590.00). The benefit of this as I see it is that the battery is only 25kg, doesn’t need to be readily accessible and has a 7 year warranty. This system will also manage my start battery.
https://www.mygenerator.com.au/enerd...rger-pack.html
- AGM battery: 2 x 100AH AGM batteries with Enerdrive ePOWER B-TEC 40A DC2DC + 40A AC with ePro+ Monitor Charger Pack - $AUD 2378.00
https://www.mygenerator.com.au/enerd...ation-kit.html
These options are both more complicated than the basic house and start battery setup that I had initially envisaged but I can see the long term value for money in each of them.
This is the basis of how I’m estimating a 100AMP daily draw so would appreciate any suggestions/corrections if I’ve completely ballsed this up:
AMPS min AMPS max approx Hrs use/day Min AMPS approx Hrs use/day Max AMPS AMPS/day max Engel MT35F 0.5 2.6 22 2 5.2 Nav lighting 0.08 12 0.96 Electronics B&G Vulcan 7 GPS/Chart plotter 1 24 24 B&G VHF/AIS V60 1 24 24 B&G Wireless handset charger 0.5 2 1 Cabin lighting LED 2 6 12 TMC Toilet 18 18 0.25 4.5 Fresh water pump 18 0.5 9 Bilge pump 2.5 2 5 Deck/anchor wash pump 18 0.25 4.5 90.16 Yanmar 3YM20 From start battery Anchor windlass Manual 0 Yanmar Alternator 12V 125 AMP
Any thoughts? Suggestions
