Page 28 of 29 FirstFirst ... 18272829 LastLast
Results 946 to 980 of 997
Thread: Fiberglass Sheathing a 1962 Carvel Hull
  1. #946
    Default Re: Fiberglass Sheathing a 1962 Carvel Hull
    Yes, I don't think the shaft goes far into the rudder, if at all. I hadn't thought of there being some sort of sheer pin or bolt through the shaft to hold the shaft into that strap fitting on the rudder. It seems to me that the strap fitting will be able to be removed without too much drama, if necessary. It might even be a simple case of replacing the pin or bolt, if there was one, and not needing really to remove either the strap fitting or the shaft. Have you tried lifting the tiller to see if it will pull the shaft upwards?
    You know, it could even be worth donning a wetsuit and some weights and checking it out in the water. Get someone to move the tiller and see what's operational and what isn't, and see if there's broken casting or welding, or a hole where a bolt or pin ought to be.
    Yes - I've been thinking of dropping in myself.
    Either way it needs to come out to be repaired. I could be forearmed, so there is some advantage.... But even at that until the paint and everything is ground back for a proper look, its just guess work.
    No - the rudder post doesn't move vertically. I didn't put my heart into it, but there was no indication of any vertical movement.
  2. #947
    Jan 2011
    Norwalk CT
    Id be mighty tempted to try a little harder to pull the rudder post up and out. Maybe rig a small block and tackle from the boom, or a simple trypod? Assuming it's parted somewhere between the tiller and the rudder head, what would be holding it in place? Is there a thrust bearing down there?
  3. #948
    I'd be reluctant to pull it out of the rudder while the boat's still in the water as then all the weight of the rudder, and any forces, will be borne by the lower fitting.
    I think the advantage of jumping in would be not only that you might see where any pin or bolt should be but you can also check that the rudder is still held at the top. If it isn't, you could wreck the lower fitting simply by leaving the boat in the water.
    Lean and nosey like a ferret
  4. #949
    Jan 2011
    Norwalk CT
    Yeah, you're right, dont so that. I guess I missed the fact there was no upper fitting....dumb idea.
  5. #950
    Jan 2016
    Auckland New Zealand
    Gopro on a boat hook could well be an option to assess the rudder.
  6. #951
    New Zealand's Far North
    How is the tiller connected to the rudder shaft? The reason I ask is that I experienced the same situation years ago when I had my trimaran.
    In my case it turned out that the tiller fitting was held to the shaft by a pair of stainless pinch bolts that had stretched and let go, there was no keyway there. It was hard to see.
    I realise that it is unlikely that you will have the same arrangement, but thought it worth a mention just in case.
  7. #952
    Thanks Stilletto, the rudder shaft is keyed into the tiller head.
    Here it is before removal for the new deck (tiller off).
    Solid rod of steel from there down to the rudder.
  8. #953
    That is a hell of a lot more substantial than what my Tri had!
  9. #954
    Yeah its pretty butch, and that (maybe 28mm or 30mm) of steel rod goes through into the rudder.
    I'm thinking through options.
    I am thinking - perhaps - maybe - get in the water (see if i can diagnose while I'm there) insert an M6 bolt with an eye on each side through the rudder. Use those eye's to attach straps so i can steer from the deck. Sail her round to Ulladulla where the fishermen pull out their boats and go at it one way or another.
    I'm doing a bit of a dance because I'm aiming for insurance to cover the costs - but they're already talking about old age, wear and tear and so forth. Also, their way is the most expensive route which if i follow, and their assessment is its not a claim, those costs are mine.
    Then again - if she does land back in the yard and i have to cop the costs - there is a spray dodger that could be upgraded, and maybe a few other bits and pieces.
  10. #955
    Got in the water - not as cold as i thought.
    Beautiful day and gorgeous sailing conditions. Wind was strong, W to NW, but a fully reefed main would have been a lovely way to sail away a day.
    A couple of Tall Ships seeing out the blow.
    I didn't get up close but I think the Southern Swan (closer) and the brigantine is the Coral Trekker.
    Anyhooo - gave the rudder a wiggle.
    There's no sign or hint of anything i can spot superficially.
    In the drawing, part A and Part B are locked together, though i think they are separate pieces. The rudder inserts through the sleeve (A) - and these are no locked together.
    Rudder is still fully attached to the boat - no additional strain on the lower fitting.
    Problem is internal, probably under the question mark.
    The rudder is fully sheathed in 2 layers of 450g glass. Bit of itchy grinding in the future.
    Then a look at how the rudder is fastened to the post - I will go with a first guess at a pin through the assembly, second, not as nice a guess, a key has dropped out, or worn/torn somehow.
  11. #956
    Found a slightly better pic of the rudder.
  12. #957
    I can’t offer any advice Trev’, I’m just hanging around here waiting to see the outcome when you get her out ion the water..
  13. #958
    I think one of your guesses will be right. The key or pin could even be mild steel, designed to be replaced every so often in a maintenance schedule. These boats were built for wealthy people - the Farr 40 or TP 52 of their day.
    The good news, of course, is that you can tow the boat or whatever now without worrying about breaking off the lower rudder fitting or losing the rudder.
  14. #959
    These boats were built for wealthy people ........
    Don't get me started
    I checked in with someone i thought would have some insights.
    His opinion is almost certainly a keyway. The parts A and B are either cast together (I don't think so) or fabricated together, more likely.
    In which case the stock should lift up through the boat....
    Confusing thing for me there is - what's keeping it down? The gland at the hull, above the water line, is not a stuffing gland, there's minimum friction - just a big helping of grease to stop water ingress.
    If the stock is pulled up, the rudder is 100% on the lower fitting.
    Like you Greg - I'm pretty keen to see what outcome i achieve too. Pop corn on the stove, I'll be watching this thread with interest..
  15. #960
    Anyone conceive of a tool to pull the rudder stock upwards?
    With the tiller attached i'd have something to grab. But maybe there's a tool that can grab the stock directly....?
  16. #961
    Dec 2016
    EU
    If there's a key then there is a nut inside part B tightening the shaft against part A. Both parts were certainly cast as one piece, they didn't weld bronze when the boat was buildt.
    Look at the photo in #221 http://forum.woodenboat.com/showthre...progress/page7 it's the same arrangement, just hidden, the nut sits in a cutout in the wood.
  17. #962
    Auckland, NZ
    .....am thinking - perhaps - maybe - get in the water (see if i can diagnose while I'm there) insert an M6 bolt with an eye on each side through the rudder. Use those eye's to attach straps so i can steer from the deck. Sail her round to Ulladulla where the fishermen pull out their boats and go at it one way or another.
    Perhaps a 'c' clamp on the rudder blade to attach steering lines.
    Once upon a time some off shore safety inspectors required a hole near the trailing edge of the rudder blade .
  18. #963
    I think you may have nailed it Rumars.
    There is a large, 25mm+ plug in the leading edge of the rudder just at that point.
    It was working its way out when i last tended to it. In my head it was the base of a tie rod going through the rudder staves. It could very well be what you describe.
    Also explains whats preventing the shaft from lifting out.
  19. #964
    Well - the shaft is a single piece of 25mm (1") steel, al the way from the tiler to the base of the rudder - and passes through the gudgeon.
    It snapped, very roughly, about 50mm up from the rudder, right inside the through hull gland.
    I've asked the local shipwright to repair.
    To get the shaft out of the rudder requires the rudder's destruction - and necessary remake. He'll look after this and the reinstallation while i get on and do the bottom, redo the topside paint and touch up the brightwork on deck.
    After which, she'll be going on Boats for Sale.
    I can't continue to justify the costs of keeping a boat that we just don't use. Its a drain on the purse and emotionally.
    The decision does allow me to dream a bit big on these plans i bought a few years back (Don Kurylko's Myst).
  20. #965
    Oh!
    My first preference would be to find someone who is interested in taking stewardship of a vessel like this, rather than throw it into the wilds.
    If anyone has any leads or wishes to share my contact please PM me.
    I'll draft up a inventory, plus a list of all the work carried out over the last few years and i have an 11 month old survey that is still accurate.
    She is also currently on the hard for another 10 days.
    Did i just break a rule?
  21. #966
    Okay. Well, it would be dead easy and inexpensive to make a new rudder from foam and glass. Light, strong, easy. I'd use a bronze rod for the new shaft. Your break looks like a classic example of crevice corrosion. I bet the shaft is stainless steel.
    If I didn't have Masina, I'd buy your boat, especially knowing all the work you put into splining and sheathing. I'm sorry to hear you're selling and hoping you change your mind. But whoever gets your boat will be getting a great deal.
  22. #967
    Thanks Rick.
    The break is above the water so I wondered about corrosion v poor repair. Yes - I am sure it is SS.
  23. #968
    Well you know what they say about the two happiest days in a boat owners life - the day you bought it and the day you sold it.
    I can fully understand your reasons for selling her, though I can’t imagine that you’ve made the decision easily. Regardless, I’ll look forward to following your new build when you get to it.
  24. #969
    Thanks Rick.
    Crevice corrosion is a particular problem in stainless steel and can be almost mysterious. Corrosion of prop shafts inside bearings and glands is not uncommon. It's one of the key reasons to have an anode on a SS prop shaft, for example. Your rudder shaft probably should have had one. But I'd replace it with bronze which should prevent any corrosion from occurring again.
  25. #970
    sonofa beach,never seen that beforejuskidding
    I have a friend ,just left Marthas Vineyard for the Caribee...had to turnaround, lost rudder.
    No injuries but have not heard what drama transpired to get her back. 50 foot yawl,recently underwent a million dollar tune up at Gannon /Benjamin
    I suspect it's just a screwy thing like this.
    this is why I like simple over easy for a cruising boat
  26. #971
    Never thought of the zinc on the rudder shaft.
    I'm planing to pull the prop shaft this week for a peek. As the rudder is off it's a matter of some bolts at the motor. Freakin awkward spot for 6'4" string bean to get into. But, if I don't the thing'll crack as I motor up the river.
  27. #972
    Transom mounted makes sense in sooo many ways.
  28. #973
    She's looking spiffing with her new paint job.
    PU 2 pack on topsides, Micron 2 under. New touch up of the brightwork, Cetol Teak.
    Here's the bit without the rudder.
    Naming - I've never had the name displayed except on the AIS. Danu btw, goddess of rivers and the sea.
    I got a local printer to mock up a version, but i think its too informal.
    Or its just my anticipated regret......
    Any opinions out there?
    Came across this; https://yachthub.com/list/yachts-for...seabird/277311
  29. #974
    I like it.
  30. #975
    That Seabird certainly presents well in the photos! Long way to go for a look ....
  31. #976
    It's a beautiful nane, but it cannot be easily read from a bouncing boat with binocs from a distance
    practicality strikes again
  32. #977
    Epoxy set glass sheathing can work but boats that were sheathed with dual-diagonal wood fare better.
    accommodated was plank on frame. He seams were all reefed and soft wood splines set in, epoxy on both sides. The splines accomodated shrinkage and expansion of the planks. She was epoxy sealed inside and out but epoxy is vapor permiable so there was a little movement. Not much and not a problem.
    Based on that experience, I'd give some thought to splining and epoxy sealing but not sheathing.
  33. #978
    The name on the transom is low so that makes it harder to read. Obviously that's to accommodate the plate. I'd leave it because it probably doesn't matter but you could paint the plate white and put a bigger name across it.
    Convention has the port or country of registration below the name on the transom but for a local boat it's not necessary.
  34. #979
    Sorry Ian, but, as the owner of a strip planked timber boat that was sheathed, with woven glass and epoxy 50 years ago, with no problem with the sheathing in all that time, I do have to laugh a bit at the incessant condemnation of sheathing. With all the issues we now have with worms, environmental concerns with antifouling and the accelerating costs of haulouts, I think anyone with a wooden boat that doesn't sheath it properly is stubborn or crazy.
    In about 30 years of restoring boats and examining many boats, I haven't seen sheathing ever cause a problem. I've seen glass laid over crap, sure, but all the problems I've seen, in the main, are caused by inadequate protection from fresh water. Usually laid decks, teak strips on laid or plywood decks, or glassed decks left with exposed edges. I've seen a lot of carvel boats scrapped due to failed fastenings, smashed seams and worm damage.
  35. #980
    One nice thing about the rudder removal is it has required a 'destruction test' on the glassing.
    I was worried most about this area. The curves were extreme, the shapes especially in the tuck of the bilge threw the cloth in all kinds of angles.
    It is stuck like the proverbial. I couldn't have asked for a better adhesion. If its this good here, its good everywhere.
