Re: Best tender sheerstrake padding products?
If you put the 3/4 on properly you will hide the top fastenings by folding it over. Sometimes this becomes hard when you go around a corner. I have sometimes trimmed the padding a bit on the stern corners and at the stem. Now that poly is available use it, not the canvas which can retain water and rot the rub rail. Every few years it isn't a bad idea to take off the rubrail and repaint under it as needed.
If your tender lives on a dinghy dock gunwale guard is not enough. I have four fenders forward and aft of the center rowing seat tied at both ends so they can be flipped out and hang horizontally just below the sheer strake. These give me extra protection when I am coming alongside another boat. I also have a three side rope mat that goes over the gunwale guard which protects the stem from the float on the dinghy dock and probably should add a metal stem band down to the bow eye. I have thought about how to protect the corners of the planking aft on the sheerstraked and on the plank below it which can take a beating from unfendered low freeboard dinghies. Possibly some bronze or bamboo with small screws painted to match the hull.
