Page 8 of 8 FirstFirst ... 78
Results 246 to 270 of 270
Thread: Losing friends in divisive times.
  1. #246
    Nov 2017
    Gulf Islands B.C.
    Default Re: Losing friends in divisive times.
    Quote Originally Posted by AlanMc View Post
    D, i don't think the 'meh' was meant to be insulting. i "meh' stuff all the time. i type it in there to flavor a response as if we were talking in person. i guess it could have been meant as an insult, but that's not a cross i'd be willing to die on.
    I don't doubt that it was not consciously used, but that is a problem with language. Sometimes things are said which carry more meaning than intended, or are received with more meaning than intended.
    In this case, part of that is certainly me. When I think of that model '94, what it brings to my mind is the years of suffering and hardship that my father endured. And then, one day, he was able to give to his son something that he felt was the best. There is a lot of emotional weight behind that
    I don't have that for any other gun.
    There was no way for FO to know that, so I attempted an explanation. His response to that could have been different. The course steered since is his, not mine.
  2. #247
    Pleasant Valley NS Canada
    Oh, fer gawd's sakes, you guys; get a room! "Ah gets all teary-eyed when ah fondle mah gun thet mah sainted Pappy done worked his fingers to th' bone t' give me, and thet low-down polecat done disrespected mah Pappy when he sayed thet mah gun wuz ugly!" Sheesh!
  3. #248
    May 2007
    Seattle
    Did not realize you were fluent in hillbilly
    Elect a clown expect a circus
  4. #249
    Just channelling my inner Jim Nabors, Bobcat. Too much 'Andy Griffiths Show' in my yout', I guess.
  5. #250
    Nebraska
    Yeah - but kin ya sing?
  6. #251
    Ayup - sounds jus' like when yer Skilsaw tries to cut thru a nail...
  7. #252
    Nebraska
    Them's is pipes!
  8. #253
    Nov 2017
    Gulf Islands B.C.
    You miss, perhaps, the point.
    The item in question matters not. The method of discourse, and the meaning of words when used in particular ways, leads to the result in the thread title.
    If civility is to be expected from others, it must be foremost in the thoughts of those speaking.
  9. #254
    Nebraska
    Decourcy, you found insult where none was intended. Why is that?
  10. #255
    Quote Originally Posted by Decourcy View Post
    HEY!!!!
    That blast of unintended irony almost knocked my mug off the desk.
    Careful wit dat chit!!!
  11. #256
    Jun 2009
    Northwest Oregon coast
    Quote Originally Posted by George Jung View Post
    Post 247 seems mighty insulting.
  12. #257
    Oct 2004
    oklahoma
    Quote Originally Posted by bobbys View Post
    Check the label. Where was it made?
  13. #258
    Jan 2007
    Winnipeg MB
    When you walk into a room after buying a Ford, and start a conversation with GMC being "meh", that is a loaded statement.
    ...and a tragic slur on GMC-lovers' ancestry, religion, sexual preferences, perceived disability, and social position, as well, no doubt?
    Yeah, I'd agree, but you're wrong.
    There is a risk with any "scattergun insult"
    Dude. You seem to be having trouble grasping a fairly simple concept: using "meh" to express indifference is not an insult. To you, to your father, to my Uncle Bob, to the turnip in the White House, or to anyone else. (Unless they have just given you a gift and you use the term "meh" in relation to the gift, to their face, in which case, yes, it probably is an insult.)
    Nobody is obliged to like the things you like. Nobody is obliged to avoid expressing indifference to the things you like in case they hurt your feewings. I like Emeralds and Morgans, but it's not an insult for you to "meh" them; I'll just assume you like Gibsons or Martins better.
    Nope. The language is fine, being indifferent to something someone else likes is fine. The problem, as others have correctly noted, is that you are determined to find insult where it doesn't exist.
    What are you doing about it?
  14. #259
    which begs the question; Why?
    Edit; just a slap of the gloves perhaps?
  15. #260
    Jan 2007
    Winnipeg MB
    Determining why would probably call for introspection.
  16. #261
    Nov 2017
    Gulf Islands B.C.
    If, by "meh", FO meant something like "my personal preference is.." rather than "your choice is garbage", which, because of my emotional attachment read as "your fathers choice was garbage", then a simple reply clarifying that meaning would have allowed common footing. But it's all too easy to allow words to take a minor difference and make it a divisive issue.
    Whether the the insult was intended or not doesn't matter. This has been a perfect demonstration of how one word can cause divisiveness.
    How many times does that happen here? How many times does it happen in the real world when politics or other heated topics are discussed? Is everyone aware that words may fan the flames of irritation between people otherwise friends, not by being words of anger, but just by being loaded with emotion to one party or the other?
    I saw a lot of threads some time back on southern statues and their meaning to different parties. The attempts by both sides to explain their points of view were destroyed more by the loaded language used than by the actual points made.
  17. #262
    Time for another boat picture...
  18. #263
    Jun 2009
    I still have glenn.....
  19. #264
    Of course you do
  20. #265
    Nov 2017
    Gulf Islands B.C.
    That is certainly dividing the water.
  21. #266
    Nebraska
    Effective as a derailment, as well.
  22. #267
    Yes, it divides the water with as little fuss as possible, it supports everyone and carries them to a safe port, does little to no harm to the waters as it passes through, and the waters reunite after its passing so harmoniously that one could never discern that it passed through. Charmingly effective, isn't it?
  23. #268
    You are evil. I like it!
  24. #269
    Jun 2009
    Of course you do
    He prolly drinks something from a Mason jar where he lives. Not that , thats bad.
  25. #270
    I thought I was gonna lose - not a friend, but an acquaintance - on Saturday. The hardware store in Harbor Woodworks neighborhood is excellent, and they sell Traeger, Big Green Egg, and other premium grilling/smoking gear. Their demo guy has been feeding me with samples for several years now, and we've gotten friendly. When I rolled up that day, he was shutting down in the middle of a pouring thunderstorm - so I helped. As he turned to head for his truck, he slapped a MAGA hat on, and commented, "I'd get in trouble if my boss saw me wearing this... no politics is the rule". I allowed as how it could easily alienate a large chunk of their customers. He said, not as many as you'd think in liberal Portland. I asked how he felt about Trump so far, and how it felt to have people support him when he saw it.
    He cited some of Trump's 'accomplishments'. I listened, then rebutted. We wrangled for a bit, but without heat. He said at first it was nice to have folks walk up and slap him on the back - but these days it seemed to be mostly the illiterate, ignorant, and ugly-talking folks who were in his 'tribe' (his word). He said all of the reasonable arguments came from the anti-Trump folks. He said his people were farmers in the Midwest - and this whole tariff mess had him more receptive to the notion that Trump was out of his depth.
    It was a bit touchy for a while, as he defended Trump. But I didn't froth... and he listened. Don't know that he's gonna give up on Trump... but at least we got back to a place of conversation instead of spouting stock lines. We'll see next time we meet...
