Page 5 of 5 FirstFirst ... 45
Results 141 to 162 of 162
Thread: Oughtred Gannet build - downunder
  1. #141
    Aug 2002
    Sydney, Australia
    Default Re: Oughtred Gannet build - downunder
    Looks great Neil: nice hull colour and interior fit out. Well done!
    PeterW
  2. #142
    Jul 2010
    northeast Ohio
    Looking very light and spacious Neil. Nice job
    I agree with Andrew's assessment 100%
  3. #143
    The mast chock fitted over the transom is a nice touch and shows the amount of thought that has gone into the project.
  4. #144
    May 2015
    Guerilla Bay, NSW, Australia
    After a lot of raising and lowering, adding some more fittings trimming lines, sticking and whipping sheets, etc.............................. we are now much closer to a launch. Must admit I'm rather happy with the look of a rigged Gannet.
  5. #145
    Beautiful work.
  6. #146
    It will look even better on the water-just make sure somebody is there with a camera to record the event.
  7. #147
    Charleston, SC
    Beauty!
  8. #148
    Aug 2019
    Providence,RI USA
    Two thumbs up!
  9. #149
    Dec 2009
    Frankfort, MI
    Very nice!
    Jeff C
  10. #150
    Feb 2012
    Aruba, Dutch caribbean
    Beautiful work. She looks to be a joy to sail.
  11. #151
    May 2015
    I haveleathered now Steve and applied Dubbin. Much less creaking and sticking now. Am going for a trial launch tomorrow with a friend so the lifejacket is ready :-)
  12. #152
    Feb 2019
    Narellen, NSW, Australia
    Fair winds and following seas Neil
  13. #153
    Feb 2019
    So is the Gannet gaff rigged like the one on the right in the pic below? If so I imagine that would be quite difficult to raise without manually pushing the yoke up by hand.
    Mine is as per the one on the left and gives no trouble at all but then it appears my gaff doesn't go quite as near vertical as yours.
  14. #154
    Toowoomba QLD Australia
    Cannot wait to see her on the water. All the very best and fair winds!!!
  15. #155
    Beautiful work Neil, congratulations.
  16. #156
    Quote Originally Posted by Steve TN 15 View Post
    Yours looks like a 'Gaff rig', where Neils is Gunter rigged i think.
    Gunter doesn't require throat and peek halyards, just a single main to a fixed point on the gaff. As in mirror dinghy's.
  17. #157
    Feb 2019
    Iain Oughtred calls it a gunter sloop and the gaff is at a much higher angle than it would otherwise be. It's just not quite as near vertical as other gunter rigs. This may have been designed for ease of raising.
  18. #158
    May 2015
    My plan at the moment is to rebuild the gaff jaws and possibly revarnish the mast/gaff with slippier varnish. I have confirmed that the Gannet has been designed by Iain to have 2 halyards (though the plans are very unclear, and his book describes both single and double halyard gunter rigs). I would very much prefer 1 halyard for the mainsail as I want to be able to rig her myself and my hands are not as strong as they used to be for boring reasons..........................
    So, I'm going to try for the 1 halyard and I want that gaff as high and vertical as possible. At the moment I am pretty fedup with it!! (I have leaks around the centreboard case as well).
    Regards Neil
  19. #159
    Feb 2019
    Sorry to hear of your troubles Neil, gentle considered perseverance will pay off
  20. #160
    May 2015
    Found the leaks at last - my own fault. I hadn't bedded the centreboard case properly when I installed it so there were 2 areas where there was a distinct lack of glue and hence the water spouts when she was in the water. Cut out some offending parts around the centreboard case logs , cleaned out usin ga chisel and a bit of multi-tool, cut some new spacers from Douglas fir, glued in with epoxy.
    So, next step will be to put Plockton back in the water and look for any offending water spouts :-)
    And on to the spars...............................
    Regards Neil
  21. #161
    A bit of a diversion but the much bigger Norfolk wherry has a single halyard for it's gaff sail.Some information here https://wherrymaudtrust.org/mauds-hi...ig-propulsion/ .A much more detailed description is in the book Black Sailed Traders.A bit of varying of attachment location and angles might be necessary.
  22. #162
    Georgia
    Enjoyed your thread! Pick up a couple good tips. Sorry for the launch difficulties. I always worried about cb/db trunk leaks. Hey, in the long run those mishaps are minor. You're looking at years of enjoyment out of your efforts.
