Results 1 to 9 of 9
Thread: Launching small boat over riprap
    Jun 2019
    Holland, MI USA
    Default Launching small boat over riprap
    Due to high water levels in the Great Lakes region, the shoreline of our neighborhood's deeded access along Lake Macatawa has been experiencing moderate erosion this year. The neighborhood association decided to dump (too much) riprap along the shoreline to protect it.
    I use this access point to launch a Pygmy Wineglass Wherry from a small dolly. The somewhat steep embankment always made launching interesting - The added riprap will likely make launching (or entering the water from the shore) even more difficult.
    Does anyone have ideas for making this area more accessible? I am looking for cost-effective solutions that would allow easier access to the water. Can some sort of ramp/stairs be built into the riprap?
    Short-term, I plan to use water shoes and beach rollers to help launch. Are there any other hacks that could make launching over the riprap easier?
    Thanks.
    Default Re: Launching small boat over riprap
    If the rip-rap makes access to the water hard, perhaps the neighborhood association would get behind a wooden stairway that's also wide enough to slide the boat up or down.
    (It would have to come up for the winter.)
    Some riprap is fine enough that you could cross with rollers. But it's a real pain to deal with positioning the rollers on a slope and you'll need an anchor point at the top.
    An aluminum extension or folding ladder atop the riprap might give enough evenness that you could use the rollers and the top rung gives you a place to hang a pulley for the bow or stern line used for control.
    If the slope is 16' or so, you could make a sort of ramp for the dolly. Basically a pair of long 1x4's with 1x2's nailed to the sides to keep the dolly wheels on board and a couple of demountable bars to keep the ramp planks the correct distance apart.
    Dimensions approximate but light enough to load on the dolly as you go two and from.
    I like this sort of ladder:
    West Boothbay Harbor, Maine
    A photo of the location, etc. would help.
    Do you have any idea yet how much leeway/discretion you'll have for implementing a solution?
    Seriously, Ian said it all above.
    May 2016
    Niagara, ONT Canada
    but with .. https://www.homedepot.com/p/Everbilt...9-48/202533611 also known as chestnut paling fence.
    Then there's things like boat railways, overhead monorail cranes, and large tilting A frames with a rope sling. As a property owner, I'd wanna fill over with smaller rip rap, then railway ballast sized stuff that a ATV tire could roll on easy. Don't think it would be worth going down to gravel, since I think it might wash out too easy.
    Jun 2019
    Holland, MI USA
    Thanks much for the ideas and help. I'll try to post a picture. Riprap rocks are about 6-8 inches in diameter. The shore is about 2-3 feet above the waterline. While the rocks are problematic, I think the main issue is the slope. The embankment was already somewhat steep, but the rocks now are piled at a 45-60 degree angle.
    The neighborhood association is open to solutions - I'd like to propose some sort of permanent ramp (Flexamat?) or at least a more gentle grade of riprap into the water. Assuming no solution, I like the idea above to construct a ramp for the dolly. But, that would just be more thing I need to drag down from my house.
    Thanks again for the suggestions.
    Mar 2017
    Indian Land, SC, USA
    A question : what is the distance between your home and the launching point ? If you don't already have them, could you replace dolly wheels with a golf cart- sized or ATV-sized wheel and tire assembly ?
    Check out Roll-A-Ramp and similar. You may also need a winch on a post to get the boat back up the ramp. Something like this commercial product could be home made, of course.
    I've also seen precast concrete ramp segments that can be laid down over a gravel bed. The photo below shows a fairly large ones. I've seen them installed that were long and narrow and linked together, presumably to be dropped off a truck and then unrolled into the water.
