Results 1 to 25 of 25
Thread: Help removing masking tape!
    Default Help removing masking tape!
    What do youall use to remove crappy masking tape and its gooey residue when it's been left on a couple of weeks too long, outdoors in winter. So far I'm chiseling it off in tiny gooey fragments and leaving a sticky mess. We are talking 100 feet of rub rail. Not having fun.
    May 2012
    UK. Cornwall, Suffolk.
    Default Re: Help removing masking tape!
    Can't help with the tape, but that's a tasty looking salad you have there.
    Try methylated spirits, aka wood alcohol.
    Wd40
    16 grit
    Heat softens many things, and I've found that it doesn't take burning heat, hot water will often do. I remove labels from beer bottles by soaking in soapy water, that glue is intended to be permanent. Paint thinner or kerosene might work. I have used WD40 on duct tape residue, it works well if given a few minutes.
    A pro painter on a job site told me heat for masking tape removal. Hot water if it can get wet and hair dryer if it can’t. Not heat gun, hair dryer.
    Oct 2006
    Livin' in the Golden Triangle
    Don't use crappy masking tape.
    After you use crappy masking tape, spend the money you "saved" and buy some Eucalyptus Oil.
    VMP Naptha
    Block plane
    Dec 2009
    Vancouver Island
    Pitch and gum remover as made by CMT. Comes in a spray bottle but you might want to just put it on with a rag. Very effective!
    I keep a bit of the 3M product in my kit --
    https://www.3m.com/3M/en_US/company-...3194120&rt=rud
    The good thing is, you will never do that again!
    Jun 2019
    Bellingham, WA, USA
    Hair dryer to soften the adhesive, plastic scraper to remove the majority of it, any of the above mentioned chemicals to remove residue.
    Mar 2006
    La Conner, WA
    Theb3M remover will help, but Toluol will soften it
    May 2016
    Niagara, ONT Canada
    I discovered that blue stuff (tape) last year and intending to use it for everything now... even though I'm a cheapskate, yah, because it's a bit like post it note glue in that you can peel it off and restick it... so you can get double or treble duty out of it if you're careful.
    Masking tape is available with several different degrees of stickiness, and durability outdoors. Some of them, once they have been painted over and left out in the sun for a few days are almost impossible to remove. You only make that mistake once.
    I like the 3M blue tape the best, it is sticky enough to not bleed under too much and is good for 3 days so I can get two coats of varnish on with a day between coats.
    But there is a new one that I haven't tried yet, claim is 60 days.
    https://multimedia.3m.com/mws/media/...ive-matrix.pdf
    A friend dropped these around today, so I have them, plus petrol, metho and heat to try. And yes, I also used some blue Scotch tape which I happened to have on board. No problems at all with that. Scotch all the way from here on in.
    Thanks for all the ideas.
    I'm sure those will do it.
    I also remember removing packing tape residue from appliances with vegetable oil and a rag. The oil takes time but it's harmless to the finish.
    I call it "Blue Tape Season",when the supers and the megas and the Classics come to Antigua for their bright work tune up.
    Aug 2016
    Queens, NY
    on a piece like that i skip the tape entirely and just cut in the paint line with a small trim brush..
    it's slow going but probably not more than all the prep and removal work with tape
    May 2016
    Niagara, ONT Canada
    I knew I'd done this before, removing weathered and sunbaked white masking tape, but for the life of me couldn't remember what I did, it being a decade or more ago. Turns out it wasn't any magic wand deallie though, just warm soapy water, cloth, plastic scrapers and elbow grease/stubborn repetitive application of measured brute force, you know, work... no wonder my subconscious tried to blank it out, LOL
    Quote Originally Posted by coelcanth View Post
    Yeah I don't know why I masked it anyway really. I'm going to be repainting the rub rails anyway. Completely silly waste of time. Live and learn.
    I cleaned up one side this morning. Now turned the boat around (that's was fun) and doing the other after lunch.
    Job done. Turned out petrol was the best thing. Gas in the US.
