Results 1 to 35 of 53
Thread: Which method to cut bronze pipe?
    seattle
    Default Which method to cut bronze pipe?
    I’m going to replace six iron pipe stancions in the boat with bronze pipe. (I can hear Chris and others laughing now ). There’s more to the story but for now I have to cut six 1” bronze schedule 40 pipe (sometimes called red brass) to length and thread the ends. Cutting and threading with the store’s machine is not an option because the machine’s jaws scar the pipe. I’ve got a 1” pipe threader, that’s easy. But there are several options to cut the pipe. 1), I can hand cut with a hack saw and square the face on a disc sander. 2), I can buy a metal cutting blade for my chop saw. Or 3), I can buy a larger pipe version of a tubing cutter.
    Which cutting method would you use?
    Apr 2017
    Kailua, HI
    Default Re: Which method to cut bronze pipe?
    If I have to hacksaw pipe or tubing, I do best if I wrap tape around the piece and steer to that. A good hacksaw with the right blade is an underrated tool, I think. Abrasive blade in a chopsaw (or one of those belt driven dedicated ones) seems to be the way local shops cut off stock, bit messy (in the work area, lots of dust and particles) but the cuts are square. For holding pieces for threading, maybe a hardwood block drilled before splitting, the clamped in the vise?
    If you are screwing it into a flanged base, does it really have to be blob on perfectly square?
    May 2012
    UK. Cornwall, Suffolk.
    Small grinder with a 1mm blade.
    se pa (Bristol PA)
    Pipe cutter, if the pipe is not be used for liquids, you don't even have to remove the burr on the inside edge.
    Ragged threads = bad dies,
    they really need to be nearly new to do a good job, because so many of us (not blaming anybody) don't use enough lubricant.
    Jan 2005
    Deepest Darkest Wales
    Lathe with a bar feed?
    tacoma washington
    as you already know...the store's machine is the ideal for this ...if you're lucky the scaring grips can be positioned at the very end and finishing up is just a matter of cutting the marred end off to finished/desired length. I would also suggest that you use electricains die's - might well be known by some other name. they don't cut a tapered thread ( ok not entirely straight either, but closer than the more typical "tapered" threads that are common in the water/gas trades) done right, the finished product will have less threads visible- and the finished threads will have a more exact stopping point when screwing into a socket
    seattle
    The pipe starts out at 10’. You want to chuck that up for me?
    For Chris who is probably still laughing, I’m tired of trying to stay ahead of this.
    I would cut it in my horizontal bandsaw. My second choice might be my chop saw with carbide blade (triple chip). Or a handheld bandsaw such as the Milwaukee Portaband. I would also consider not threading the ends but, rather, drill out the bases to fit the OD, insert, and silver solder. Or weld the pipe to a bronze flat.
    I think that an abrasive blade will load up with the soft bronze and become useless in short order.
    May 2014
    SEATTLE, WA
    If you want to thread both ends without any scars on the pipe just get two dies and thread both ends at once. With a little luck they will both thread equally. Mount the bottom die in a vice.
    Alan
    se pa (Bristol PA)
    Internal pipe wrench
    May 2012
    I'm a savage at times, but I get stuff done. If I'm hearing you correctly, you are asking how to cut a 1" bronze pipe square? Have you eyes? Then to a grinder with you.
    Hacksaw (on taped pipe) should do just fine - as mentioned.
    A thought on threading. My stanchions are held into the base with a machine screw into threads in the base & the pipe. 1 minute to remove the stanchion & no scarring of the pipe when you do so*. The curve of the cable (as it follows the curve of the toerail/bulwark) holds them tight.
    I also found that the pipe bends surprisingly easily. I turned mine upside down, put in a 5.8(IIRC) dowel & filled the gap with epoxy. This stiffened them up quite a bit.
    * label them if you use this method because they won't all be identical DAMHIKT
    Take it slow with a standard wood cutting carbide saw blade on the chop saw.
    The metal cutting blades are ideal, but before they were commonly available wood cutting carbide blades worked for softer metals like brass, aluminum and bronze.
    Lots of not overly useful information: https://www.ame.com/sawing-academy-a...arbide-sawing/
    Jan 2001
    St. Simon\'s Island, GA, USA
    I have used a metal cutting blade in my skill saw to cut steel pipe. Would it work on bronze? I would guess yes.
    Any of the cutting methods will work fine. It is important to start a pipe thread using a square end.
    As far as holding the pipe without marring while threading it, look into a gun barrel vise. There are home made versions and a piece of Oak would do the job. A die with sharp threads is advisable, the force required to cut is the inverse of the force required to hold it. You might look into replacing the single die just for this job (Mc Master-Carr should have them)
    And now; have you considered simply boring out the flanges and silversoldering the pipe into them? (no threads)
    I will volunteer the boring bit...
    Jan 2005
    Bar feeds will commonly take twelve foot long bars.....
    Nothing to add to the advice that has already been offered, but I'm not laughing at all. If I had Snoose nothing less than bronze would do. I also think you should tap the deck plates deeper into the taper so you can hide all of the pipe threads...
    - Chris
    Oct 2010
    Trenton, ME
    A short block of wood could be drilled or bored to just fit over the pipe being careful to make the hole perpendicular to one face. Slit lengthwise on one side and you have something non-marring to clamp the pipe in and guide you for a square cut if you’re cutting by hand. A metal file can be used to square things up although a stationary sander would be my preference.
    Jan 2011
    Norwalk CT
    Use a chop saw with a sharp carbide blade. Go easy. It will cut it smooth and clean and square.
    Actually, I take that back. I do have some advice. Which is to not overthink things here. A good hacksaw is easy, quick and plenty accurate enough. No need for anything more complicated than this:
    Each cut took less than thirty seconds or so, if I recall. I do remember being surprised at how well that saw went through the pipe after a lifetime of using cheap, flimsy, hardware store hacksaws. Never again.
    - Chris
    A truly rigid hacksaw makes an amazing difference!
    Barrie, Ontario, Canada
    Ditto on the good hacksaw. But you might have to use a bench grinder to square it up after.
    My stanchions simply slide into tight sockets in the bases, no threads, and a 1/4" bolt functions as a set screw to hold them in place.
    seattle
    Chris, without going back thru the pages of the Petrel thread, how did you treat your black iron stanchions? Did you hot dip them or barrier coat epoxy? Have they rusted at all yet?
    Thanks all, for all the good ideas. I know it isn't a big deal to cut pipe properly, but now I have a better idea of what tool(s) I want to buy for the job. Biggest thing I learned, I didn't know there were better hacksaws. No wonder I've always hated them. (Oh, I also learned how to spell stanchions.)
    I just painted the black pipe with Rustoleum. It held up ok but the stanchions weren't on there for very long as I pulled them off to tear up the aft deck only a few months after I installed them. If I was going to do it again I would use bronze.
    - Chris
    The simplest solution by far.For six stanchions it ought to take less than half an hour.If the end isn't perfectly square you can help things along with a chamfer to help start the die and a file will do this.
    Newport News, VA
    chop saw, and you can use a carbide tipped saw blade made for wood. I have lots of blades, so i dont care, I just want it cut as easy and quick as possible.
    I have also used circular saw for this.
    seattle
    Tried several different methods; by FAR the best and quickest was a hand hacksaw. Even my old cheap one with an old blade went through the schedule 40 pipe like butter.
    Then when all pipes were cut and threaded and the new bronze flanges were put on, I discovered that the outer diameter of the new flanges was a problem. For some reason, 1” iron pipe flanges are 3” diameter, but 1” bronze flanges are 4” diameter which doesn’t fit with the cap rails on the boat. I scoured the planet looking for smaller ones or some substitute to no avail. So I decided to cut down the 4” flanges using a fine tooth blade on my wood cutting bandsaw. Didn’t work. However, again the hand hacksaw went through the cast bronze easy. A little touch up on the belt sander and problem solved. I am now a real fan of a simple hacksaw.
    Funny, that was exactly my experience in cutting the stanchions for Petrel as well. It's easy to be seduced by the convenience of a power tool but for some jobs the simple hand tools just work best. I cut all of the deck beams I just made for Petrel using a double edge Japanese pull saw. I might have been able to do it marginally faster with a circular saw but it was so much more enjoyable to work without the noise and weight of a power tool. And even more so that I was able to just flip the saw over between rip and crosscut when notching the ends.
    That base looks perfect Ron. Just the right thing for Snoose!
    - Chris
    Well - you might wanna pretend it's an illegal gun that needs to lose its serial # & use a dremel or some such to remove the "China".
    As far as cutting bronze with a band saw - I've done it a bunch, but find a medium blade works better than a fine one.
    Then you’ll LOVE one of these - a portable band saw ( ......the Makita one that I have is not cheap, but performs brilliantly, an absolutely fantastic bit of kit !!! )
    seattle
    What do you think? Better?
    Wow! Yeah. That looks fantastic. Nitpick.... slotted screws maybe?
    - Chris
    seattle
    Square was the only thing Tacoma Screw had, but why slotted?
    Slotted & clocked is traditional.
    Looks great I think!
