Results 1 to 6 of 6
Thread: Flush engine deck hatches and leak avoidance.
    Upstate, SC USA
    Default Flush engine deck hatches and leak avoidance.
    How do you guys deal with flush deck hatches and leaks? I keep coming back to the plastic boat idea of building a channel around the hatch sealing area and running hoses to the scuppers, kind of a C channel. The deck hatches will have to be walked on to get in and out of the boat.
    Default Re: Flush engine deck hatches and leak avoidance.
    That's done on wood boats too. It's how Huckins did it. Also the lazarette hatch on Temptation, our Chris Craft Constellation, used that design as well. It works ok but not great if the hatches are regularly exposed to weather. I had plans to improve on the design using a rubber gasket and cam latches in addition to the channel but never got around to it.
    Gutters for sure. For Meg we made them all about 3" wide so that I could clean them easily.
    Ah - that's the way to do it for sure. All the ones I've seen have a gutter of about 1/2"-3/4" wide. Not nearly enough of any real amount of water. Make them big and they will probably work great.
    Upstate, SC USA
    Thank you all. That kind of confirms what I was planning. I was thinking about making them 1.5 inches. I think if I made them much larger, I would catch a toe and break it. I've done a similar thing before.
    Newport, OR
    Grand Banks also used the gutters. It doesn't always work when you have 90 inches of rain a year, but the design theory is solid.
    1973 Grand Banks 42
