Results 1 to 20 of 20
Thread: Fuel tank material
    Apr 2007
    Caribbean cliff edge
    Question Fuel tank material
    I have another thread discussing fuel lines.
    Acknowledge that various persons prefer various materials, e.g. fiberglass/stainless steel/aluminium/aluminum/plastic, for fuel tanks.
    However I have come across persons using built in plywood tanks.
    These tanks apparently are NOT lined with fiberglass of other 'sealant/liner' and are left bare internally.
    The outside may be sheathed in fiberglass or maybe just at the joints.
    Wouldn't the gasoline would attack the glues in the plywood as well as soften the wood fibers causing them to separate and thus affect the carburetors and filters.
    Has anyone else heard of using plywood tanks?
    I live and drink rum where other people vacation.
    Default Re: Fuel tank material
    The plywood is acting to both protect and keep in place a bladder tank.
    Apr 2007
    Apparently these guys don't even have bladder tank.
    It sounds like a fundamentally flawed idea. Any fluid will eventually saturate the bare wood. There will be fumes passing through the wood, so if it isn't coated with a barrier on the outside, it will stink and must be in a well ventilated area. Diesel should have less softening effect on wood than gasoline with ethanol in it.
    http://forum.woodenboat.com/showthre...ss-diesel-tank
    http://www.duckworksmagazine.com/04/.../011/index.htm
    Diesel also saturates wood. My old schooner Goblin would not hold her topside paint in one spot. Turned out that the bed logs supporting the cockpit wing tanks held the moisture that (Goblin was over 60 years old) allowed some pit rusting through the sheet steel tank, wicking the diesel along the grain to the hull and causing a major stretch of plank to be saturated as in tap and the wood sounded "splat".
    I really cannot believe no bladder. If that's the way they are going, stand by to let the Darwin Award folk know.
    Wood to hold gas without a bladder? Ian nailed it - contact the Darwin award folks.
    Apr 2007
    I will try and get more information of this.
    Goblin was probably not ply. Wouldn't the glue lines in ply act as an impermeable barrier?
    You can make plywood tanks and then encapsulate in glass and a special resin. Hatteras (and others) used to do this.
    However, someone could weld you up a custom sized tank for about the same expense, especially if you factor your time ( which, I realize, you may not, given the DIY ethos of Forumites)
    Dec 1999
    Oriental, NC USA
    Fuel, gasoline or diesel will eventually or sooner saturate and weaken unprotected plywood or solid wood. Seen it and repaired it. I hold any wooden boat with an inboard engine in suspicion, especially one without an adequate drip pan or protection under the engine.
    Tom L
    Oct 2000
    Padanaram, MA USA
    The LAST place i’d experiment with methods and materials in boat construction is in fuel systems.
    You can swim away from structural failures. Explosions, not so much.
    Follow the ABYC standards.
    West Boothbay Harbor, Maine
    I'm a bit unsure about this youtube, but Jamestown Distributors posted it on their FB page. You'd think that was some kind of expert curating, but whatever. https://www.youtube.com/watch?v=qFk1...&feature=share
    I have a ply tank on Woodwind. ACX fir..maybe it's mdo, can't remember.
    But it's glassed on the inside,epoxy of course, and only 35 gallons.
    And it's for diesel.
    I would not want to go much bigger or use one for gasoline .
    Oh god, I lasted 30 seconds into that video in #12.
    That boat looks like crap!
    May 2016
    Ottawa, Canada
    I'm out of action recovering from knee surgery ,so I watched the video. It's painful to think how much effort this guy is putting in, but might end up with a boat that can't be insured. Most marinas want proof of liability ect, which means passing a survey. I haven't looked, but I'm pretty certain AYBC doesn't allow wood integral tanks.
    Mark
    Montana USA
    The annoying intro music stopped me before getting to the boat.
    Oct 2000
    Padanaram, MA USA
    Scary.
    Meg has wood water tanks glassed inside with food-safe epoxy. There are petroleum proof epoxies, such are quite clearly not in the tank as described in the OP.
    Edited to add: I skimmed the vid, jumping ahead a bit. Did not notice any treatment of baffels.
    I skipped to the end. The tank wasn't half finished and it looks like you have to be a paid subscriber to see part two.
    West said somewhere, you shouldn't but if you are going to do it anyway, that for better chemical resistance you could mix their epoxy slightly resin rich. That is consistent with other information that I have seen over the years. The old Armstrong C7/Cat W tds describes a wide range of ratios and how the properties vary. That is one of the very few variable combinations where bad things don't happen.
    May 2016
    Niagara, ONT Canada
    They're the experts, but that sounds a bit weird to me, paraphrasing as "to resist a really strong solvent, err on the side of 'may never get really hard' "
