Results 1 to 34 of 34
Thread: Need design(er) for 80' sailboat
    May 2019
    Bahrain
    Default Need design(er) for 80' sailboat
    Hi,
    I am looking to build an 80 ft. sailboat similar to the attached photo in Wood/epoxy “perhaps mahogany” could anyone recommend individual designs and designers.
    Many thanks,
    Ayman
    Default Re: Need design(er) for 80' sailboat
    Welcome to the forum!
    You're expecting people on the WBF to have an opinion on this? Well - let me just say that the responses should be fun...
    Aug 2012
    Beaufort, NC
    What is your budget, 2-2 1/2 million?
    May 2019
    Bahrain
    Thank you Garret
    Doesn’t hurt to try and will learn at least few things from everyone.
    Dannybb55
    My budget is $500k US; I will use my wooden workshop to support this project.
    Never hurts to try! Let me rephrase that. Sometimes it hurts like hell - but you do learn along the way...
    While I realize labor rates vary around the world, the surveyor's estimate for replacing my 52 ft. sloop (the boat itself - no rigging, no sails, no engine, no electronics, no interior, no head, etc.) was 625K & that was 12 years ago.
    Lynden, Wa
    Off hand,
    Tad Roberts, Paul Gartside, Sam Devlin
    A quick google should bring up any of their information.
    Ben Sebens, RN
    May 2019
    Bahrain
    Ill paste some of my comments on other website and let me know your opinion please!
    1-By the way, my initial calculations for west system epoxy, fillers and fibers are about $40k-60k USD max. So it’s expectable to me.
    For a same like new yanmar engine 450Hp, never opened & imported from japan from a damaged boat is $12k USD here, same one will be new at 45K, for example.
    I have mechanics that rebuilt such engines for less than 3k USD. I also have my own plumper’s, electricians and so on.
    2-
    Good news, I just received a quotation for African mahogany (kosipo) $750 USD C/M including tax. (5% tax here)
    3-
    As for masts, aluminum is the best and will cost $100k by one of the best makers (Reckmann of Germany). However, mostly ill make them of wood (which is bad for sails; they will tear it off if they are not stable enough) but that will add stealth from radars and pirates. And I will save a lot.
    4-
    The wood turn to be Kosipo, which is African mahogany (heavy - also they call it heavy sapili) priced at $1000 C/m including tax. So if I made the boat in solid will cost around 50k for wood.SD no KD
    5-
    I have support here but with Turkish builders (4 of them paid double what they get in turkey for a year + free accommodation and others, I believe I could do this dream boat with half price, also I am an engineer and I did many projects in my life). I will inject (group of 4 carpenters and painters from my side to support the Turks builders) to speed up construction with accuracy! Total salary for the 8 ($75-100USD max)/year
    6-I received quotations from both Turkish and Egyptian boat builders ranging from 400k-2500k $
    7-
    I have requested the design only from few Turkish and international designers and turn cost between 20k-200k USD. I am thinking of building this boat with my wooden workshop & importing 3-4 Turkish builders in addition my labor here in the gulf because I think I could build it completely with around $500k with the highest standers and materials and ready to sail.
    So that’s at least 50% less than all Turks factories. I have support here but with Turkish builders (4 of them paid double what they get in turkey for a year+ free accommodation and others, I believe I could do this dream boat with half price, also I am an engineer and I did many projects in my life).
    May 2019
    Bahrain
    Thanks, I got a quote from Ted Roberts already.
    Nov 2001
    Seattle
    The boat in the OP looks like a Turkish charter ketch. Is that the purpose of this vessel?
    Are you thinking of something like Tatoosh: https://www.yachtworld.com/boats/196...ketch-3496331/
    Or something even less modern?
    Mukilteo, WA
    I can't think of a designer who works with that type of hull particularly. Your best bet is probably a designer in Turkey.
    Your budget seems impossibly low, perhaps just enough for the materials, but I am unfamiliar with the real-world conditions in your country.
    Your comment about wood masts being bad for sails is a bit misguided. Furthermore, the boat you posted is not primarily a sailboat, it is a motorsailer or more likely just a motor boat. That is fine, as long as it is what you intend. If you are looking for real sailing performance, we might be able to recommend some other hull types.
    May 2019
    Bahrain
    The boat was design and built in Greece in the 1964. The purpose is for family use & maybe charter. I like the design in & out; it suites me very well. Ease for sail, simple, open space its just perfect to me. (it was made for a rich man too and many royalty went in it including prince Charles of UK). Basically, I am looking to make a 2nd copy with slight changes.
    http://chrisgiatrakos.gr/2018/06/08/...acht-cruising/
    May 2019
    Bahrain
    Your right, it’s a motorsailer boat kinda and got a 400hp engine but with wood/epoxy hull should get lighter with help of the designer and faster. I am not looking to race as much as worm houseboat or whatever you like to call it. I like to make it more of a trawler. Its also shallow drafted and I need that 2.2 m. So what do you recommend!
    May 2019
    Bahrain
    news_thumb_1.jpgI received 3 Turkish quotes (from respective builders) for 1.1-.1.3 million USD.
    Nov 2001
    Seattle
    I agree, boats like that are still built in Turkey, maybe your shipwrights will know a good designer. In most of the world, as engines became smaller and lighter, boats with the same power performance could be built with better sailing performance. Jay Benford is the only American designer currently working who has done much with really heavy sailing craft, and even he has done some light displacement wood cruising sailboats. That said, there are other designers who might be interested in such a project, and you could certainly contact Tad Roberts, Bob Perry, and a few others.
    Nov 2001
    Seattle
    A gulet might suit you. Mousing around the web, I found this:
    https://www.sailboatlistings.com/view/20002
    Phillip Rhodes designed some motorsailers that would do the job, back in the 1950s, such as this:
    http://ybi1.com/nostromo_29m_de_vrie...r_for_sale.htm
    But in steel. I think with the more compact engines now available, you could get a better balance between sailing and motoring than any of these examples with a new design, but I do wonder about whether the cost could be controlled.
    May 2019
    Bahrain
    Thank you Johnw, by the way they are asking for this boat now $360k but its older than me. For steel , the Turks offered me 50K less than wood but I want wood for its heat /cold isolation and to avoid cathodic protection and help stay more away of radars !!
    May 2019
    Bahrain
    I have looked at gulet a lot in the past, but some how this boat got a little of everything and everyone, all set in one boat. This will save me a lot because the setup is just beautiful to my needs. The Turks always make gullet as charter and family boats but in heavy forms! This boat was perfectly set. ( they ask Dr. ferry Porsche founder of Porsche auto; what makes your cars wanted so much, he said; our design is based on multi languages, I have designers from Germany, Denmark, japan, USA and other parts of the world).
    The 29m boat is nice but again not as shallow draft and complicated. I always remember an English friend of mine who always say: Less is More!.
    May 2019
    Bahrain
    I was close to do this boat before, but I wasn’t sure for quit some time; the issue of big sails, hydraulic transmission, fin keel and draft.
    Still; lovely boat.
    http://www.classic-yacht-design.com/...creole/pc.html
    Sep 2002
    Quote Originally Posted by Ayman View Post
    Hi,
    Many thanks,
    Ayman
    Michael Kasten.
    Jay Benford.
    Tad Roberts.
    John Welsford ( Sign, not design, out of my league).
    Sep 2002
    Falmouth England.
    Try the Arkin Pruva Yard in Antalya Turkey. They built Ed's 83ft Shindela.
    It sounds like you have done plenty of planning. Good luck with her, keep us posted.
    Pleasant Valley NS Canada
    Well, I certainly don't have the name recognition factor of the other fine designers mentioned in this thread, but I do have a track record of designing classic yachts up to 72-ft LOA for cold-mold construction...
    I suppose that I should add (for clarity) before someone gets all upset... Yes, the yachts shown are a Burgess and a Herreshoff, respectively. However, in my defense, both of the originals were built plank-on-frame with (for the day) minimal interiors and virtually no domestic systems. My design brief was to maintain the classic look and detail of the originals on the exterior, but install modern navigation and communication electronics, a much more luxe interior, full mechanicals including diesel propulsion (twin engines in the Burgess) and generators, multiple tanks and associated plumbing, modern toilet facilities, modern well-equipped galleys, etc. All of these additions added weight, but the clients wanted the boats to float on their original lines with the original ballast/displacement ratio, so pretty much every component of the hull fabric was evaluated for potential weight savings, and very detailed weight analysis was done to ensure that the all-up weight was maintained and weight distribution was as accurate to the original as possible. With modern fabrics and cordage, rig pressures were expected to be higher, so all rigging points - both standing and running - had to be evaluated and strength added to mounting points where necessary. Finally, both boats have twin VHF antennae, a radar, multiple smaller antennae, and radar reflectors aloft - can you spot them? Essentially, the only thing that I did not change with these boats was the lines and sail plan.
    Nov 2001
    Seattle
    And people need to keep in mind, most of the actual design work on boats this size is not the lines and sailplan, unless you want a very bare bones vessel.
    May 2019
    Bahrain
    Thank you everyone for all your support and recommendations.
    I have contacted many designers in many places and I believe I need someone who have the experience with such size, who could work with me and match my budget.
    You’ll wonderful people.
    Nov 2001
    Seattle
    Please update us on the project!
    Shubenacadie NS
    Will you be keeping a build log as she's assembled? We'd love to follow along.
    -Henry David Thoreau-
    Apr 2007
    Pittsburgh, Pa.
    my suggestion is to go to Indonesia or Malaysia and have a Pinisi built
    Pinisi Traditional Sail Ship
    Apr 2007
    Pittsburgh, Pa.
    Using modern construction methods I'm sure Reuel Parker could come up with a good design
    https://www.parker-marine.com/parker2_1.htm
    Bermudian
    Schooner 65
    Designed for a charter company but never built; there is a yacht version and a passenger-carrying version; also a boomed sail plan that is self-tending
    Aug 2012
    Beaufort, NC
    Nice budget. Building is cheaper than restoration. Why an epoxy boat?
    NZ
    I know a guy who has this bridge in San Francisco for sale... I think he does schooners as well.
    whatever rocks your boat
    The Rhodes is one of the best boats there is, in comparison the gulets are chicken sheds
    Boat Designer. Boatbuilder
    , you might as well replank a fishing boat, it will save you lots
    I have trouble taking this seriously. But good luck.
    Apr 2007
    Caribbean cliff edge
    Good luck with your venture.
    Please post updates, and pictures, as your yacht building project progresses.
    I live and drink rum where other people vacation.
