Results 1 to 5 of 5
Thread: Lubber Catboat Rudder Questions
    Default Lubber Catboat Rudder Questions
    I'm in the finishing stages of the rudder for my Wm Garden TomCat build, and am thinking a bit ahead with these questions in mind:
    1. Should the rudder be "permanently" in stalled? That is, since the boat will be trailer-sailed, should the rudder be left in place during trailering?
    2. Should I install some sort of locking pins, such as cotter pins or other type to prevent the pintles from slipping out of the gudgeons either during sailing and/or trailering?
    Thaks
    Jun 2007
    Default Re: Lubber Catboat Rudder Questions
    Quote Originally Posted by GregH View Post
    Thaks
    1. No, bad idea, just asking for trouble.
    2. There are commercial products specifically made for holding the pintles in place. Here's one from Duckworks
    https://www.duckworks.com/product-p/rl-336-parent.htm
    Thanks for the tips Dusty- that gadget on Duckworks looks like the solution!
    West Boothbay Harbor, Maine
    Depending on your launch ramp depth and the incline of the boat as it slides off the trailer you may find that a mounted rudder will be jammed up against the transom, so setting it on the gudgeons after the boat is afloat may be necessary.
    Removable rudders should always be removed for trailering and in some cases launching / retrieving. The easier it is to mount and dismount the rudder while in the water, the happier you'll be. I recommend installing the rudder keeper on the top gudgeon area, so you can easily reach it from the cockpit.
