Page 3 of 3 FirstFirst ... 23
Results 71 to 84 of 84
Thread: Casting lead questions
    Default Re: Casting lead questions
    Another sealant which can handle molten lead temperatures is silicone, the stuff used for sealing up roof gutters etc.
    Construction grade silicone won't take the heat. There is one readily available high temperature gasket silicone that might be OK here.
    I was about to say that you would have to go to something like Pelseal liquid Viton because no silicone could handle the temperature. As much as I hate being wrong, one more check came up with Permatex 81160 High-Temp Red RTV Silicone Gasket Maker that is supposed to be OK to 650F while Pelseal is only rated for 450F. Between the high price, difficulty finding it and potential for toxic fumes, Pelseal is not the best bet.
    Your first test will reveal a lot of information to you. But my guess, based on some experience, is that the lead won't release easily. If it doesn't, you'll have to build in draft or make two sides removable to aid release. I don't think you need to use furnace cement. A simple dab of plasticine clay will do the trick and is easily done before each pour. The first pour will heat the mold and you'll be good to go from there on.
    Apr 2007
    Caribbean cliff edge
    I live and drink rum where other people vacation.
    Jul 2017
    Toodyay, Western Australia
    When I did my big pour, much of the lead was old roof flashing. Lots had big lumps of silicone stuck to it where attempts had been made to fix roof leaks. I thought it would just burn up, but no, it didn't burn, didn't melt, didn't change at all. The lead melted away and the silicone retained its original shape as though nothing happened. Later when everything was cool I picked up those bits of silicon and found it still nice and rubbery, stretchy, flexible, just as it is meant to be. I have not previously sealed a mould with it, but next time I pour some lead I will incorporate some silicone to see what happens, and will heed your caution about fumes by standing to windward.
    Apr 2007
    Oh no, my secret plan revealed. It's true, I'm planning for the Waterworld future, where I'll be shaving bits of gold from the bottom of my ballast castings to survive the lawless, sunken planet.
    Good information. Thanks. I wouldn't count on any real strength at temperature, but as a plug for a very small leak, it sounds like it should work.
    I meant that any fumes from Pelseal were a problem. It is a fluorocarbon, so it can release HF and other really nasty things if it gets too hot. Most silicones are not fluorinated so the fumes, if any, wouldn't be as bad. I never met a fume I liked, but some are a lot worse than others. Avoid them all. There are fluorosilicones, but I doubt you can find them in a retail store.
    Could you not just pour some sand into that cavity so the lead can't get in? I'd consider packing sand all around the mould as well, to keep the lead in the shape required.
    Don't do it! The sand will float up all through the lead making it impossible to work with edged tools. Even drill bits.
    Don't ask how I know this...
    Jul 2017
    Ha ha, reminds me about my concrete mould. Tried to make a weak cement mix by having a fair amount of sand in it. Well some places evidently had a bit too much sand, so when the ballast keel emerged it had patches with sand embedded on the surface. The fix was a cheap electric plane which I didn't really like anyway. Fairly hacked up the blades which had to be sharpened every 10 minutes. Got the job done ok.
    Now here's a thing of beauty. 38 pounds of stability in my bilge. 500 plus to go. Big thanks to everyone's help here. I took your advice to heart and it paid off.
    Here's the setup for the pour. After the lead was ladled in and fully cooled, I flipped the mold over. The square end started to drop right away so the end with the finger grab jammed. I put some bricks under the loose end to keep it from twisting out, tapped the sticky end of the inverted mold, and out she came.
    Here what it looks like just after the pour, or ladling, actually. You can see how the lead cooled immediately, but the layers do appear to have bonded strongly. It was easy to get it up to the edge with minimal spilling. Shrink back was negligible, it being only 1-1/2 inches deep. And the stove cement sealed the joins without failure.
    Nice. Steady, easy, safely as she goes and you'll get it done!
    Dec 2017
    Germantown, NY
    Very nice, I like the built in finger grab.
    Given that the mold is steel, do you think it would also work as the melting pot? Just set the mold on the burner, fill with lead and watch it melt. Obviously more lead would have to be added as the initial amount melts and takes up less space. Then let it cool and you've avoided the pour/ladling and know it is one solid piece.
    Just an idea to skip a step if you are not in a rush to get them all made.
    -JP
    Quote Originally Posted by jcpout2c View Post
    -JP
    I suspect the answer is yes and no. This particular mold has lots of surface area and cooling fins (or the equivalent) all around. I'd probably need a lot more flame to get it hot enough. But the bigger thing is, as I'm working it, I can let the last pour cool in the mold while the next batch heats up, which should keep things moving along. But yeah, if I wanted to do just one, I could give that a try.
    This brings another thought to mind. That plumbers pot I'm using is made to order. The flame sounds like a jet engine, and the pot cradle concentrates the heat around the pot every effectively. I'm still wondering how much propane it will take to melt 600 pounds. Any guesses?
    Looks good. Much better than the Micro Keel that I mentioned before. You could waste gas and pretty up the surface with a torch, but hiding it under the sole is best.
    No idea. Could you weigh the tank before and after the next pour?
    I would use wood, but I have brush to burn and a place to burn it, so boiling syrup and melting lead come under landscape maintenance for me.
