Results 71 to 105 of 114
Thread: Adventures of 'yeswhen', a boat with a lot of questions
    Bay of Islands,N.Z.
    Default Re: Adventures of 'yeswhen', a boat with a lot of questions
    Very comfy looking.
    Sep 2009
    Sydney OZ.
    Boob knowledge eh
    I remember being told you could remove the additive by pouring it through a loaf of bread.
    Xanthorrea
    Jun 2013
    The other problems with putting metho through bread are (1) it takes a LOT of vegemite to hide the taste; and (2) toasting metho-soaked bread is a really really really bad idea. Just drink the stuff neat!
    Apr 2019
    Aust
    Well... questions have escalated to another level. We have got given whatever paperwork was there from the build and it's pretty amazing. For now the first page, mentioning a lot "Nevis", which from my googleing around shows an american boatbuilder referred to this name.
    Is our boat based on a Nevis design then?
    Pretty interesting to see how he basically went bigger on everything from the original design.
    Someone can read this language better than us, although we're slowly getting better at it... what do you see?
    Cheers!
    Jun 2013
    Nevins was a top boatbuilder who had a set of "rules" for scantlings. The Americans on the forum would probably know more.
    Gold Coast Australia
    That lead in the bow is odd.
    To induce hogging perhaps?
    Looks like 60kgs or 70kgs?
    Cool adventure
    Since the vessel appears to have new chain did the obviously fastidious owner possibly halve the chain locker supply and substituted lead to trim.
    Aboard WB I cut my 5/16 chain back to 25 m from 75m which is a lot of weight for a small boat.
    The little antenna gizmo may well have a magnetic tip a very useful tool.
    Jun 2013
    If she had a different name she may have been used for offshore racing, in which case the lead could have been used to induce bow-down trim to reduce the rating.
    A lot of older boats were built with no engine or just a small engine with a small fuel tank, and just one battery. Add a bigger engine, more fuel and an extra battery, and the boat needs weight in the bow to compensate.
    There is a stainless stem fitting up for sale on Gumtree in Adelaide at the moment. I don't know how you'd work out whether it will fit your boat but let me know if you want me to have a look, take measurements etc. Could even be worth you making up a physical template somehow and I could offer it up and see if it fits.
    Apr 2019
    Aust
    I think from all the above theories what Rick says seems to make sense. I believe she was an ocean racer in the past (a radio license from when she was launched states her intentions) and I have found an old plugged shaft-hole (better names for that must exist) higher than the one that its currently being used by the Beta 20 on board.
    Things are escalating and slowing down at the same time as the weather allows both to happen. We've got ourselves to be in a cold and damp place and it's hard to get the chill out of the body to have productive days, so we're taking it as it comes.
    Since last updates, we have been focusing on stopping the water from coming down below as much as possible. We've spotted more rot (surprise!) on different areas of the deck and we've temporarily overbored, epoxied and redrilled two stanchion bases with wooden backing plates, washers and bolt and nut. We've also stopped the water from coming down through the starboard chainplate, as it had done for some time damaging tools and equipment that was sitting on the boat.
    First mate has been focused on the starboard handrail, as it was rotten almost all the way (but at least it did not let water in!) and we've been crashing our heads trying to find a similar one or a solution. The teachings from that came down to actually have to use our first dynel to cover some of the exposed timber since the old handrail took the canvas when we took it off, practising with fillers and seeing what result we get.
    This jobs have been teaching us confidence, have been our first epoxy experiences and understanding, and have brought an immediate feedback as there's substantially less water coming in as it was before, but at the same time we're realising the amount of work to be done on top of the standard wooden boat owner style type of thing
    Small portholes were also a drip drop party, but on those ones we believe we've done a "proper" job. I'm not sure of the material, silver but not aluminium, some sort of cast bronze or so. They're old and they use glass, but since they're the two small ones in the forward part of the main cabin we simply opened them (as there function was once upon a time), cleaned all the old bedding apart (a mix of silicone, sika and foam) and re-bedded with foam and butyl tape. We tried to fill it all up with butyl (since we're not going to open them) but the wear and the 'space' left did not wok, so we put new gasket and then assured the bedding with butyl. Rain is falling as I write and not a drop there.
    More work to come in those lines are some of the side portholes. One of them, and most probably the cause of why the old-ancient depth sounder is not working, leaks quite a bit pretty much where the depth sounder sits and then travels down. This one seems to have a deeper history on the last owner, as there is a ****ton of bog and what not around the area where the porthole is fastened. I can see in the distance of future jobs that we might need to "add" some framing since he's mounted it over an older one, bigger one, and tried to keep it watertight in a... cheap? way.
    I spent yesterday a good amount of daylight and some nighttime into replacing the fuel line coming from the main tank to the day tank since it gave me the shivers to look at it, touch it and think about it. It was reinforced water hose and it was stiff as a rock, all the way. It had a leaky electric fuel pump (which I believe it was ment to be for water), about 3 different copper-pipe "links" and a real good sense of being very old and not being replaced when the new engine came. I have observed this pattern in quite some things in this boat. New things, but kept the old fitting/cable/pipe. Not how I would do things, but I guess that's what we're here for. For now, I put an in-line bleeding bulb to be able to pump fuel into the day tank, although I have ordered and received an electrical fuel pump, I want to try and get the sediment out of the tank one day, or even take it off and completely clean it. But not just yet. So I stick to manual non-clogging and eventually the bulb can help prime the electrical one too.
    I also changed the two primary filters/water separators and cleaned them all up, as well as the engine fuel filter. A good first experience with positive result with the whole bleeding the engine working by the end of the day. When darkness came (early anyway) was time for the oil, and this engine seems to have a simple system with the sump-pump being preinstalled in the system. Changed the oil filter too and seems to be all fine.
    The focus on getting the engine as good as it can be is that we're taking her out of the water next week and we've got a bit of motoring to do to get there. The rig is not to be used since the forestay is off but I will still keep the tension in the haliards that are holding the mast and have a little sail ready in case there's no other option. An anchor and rode will also be ready on deck.
    Will be a fun first trip, with no depth reading and no rig!
    Apr 2019
    Aust
    Thanks Phil!
    Tried to find it, have you got a link?
    Many boat owners in the PNW used a 60 - 80 W bulb left on permanently to reduce moisture in their vessels.
    Quote Originally Posted by JorgeR View Post
    Thanks Phil!
    https://www.gumtree.com.au/s-ad/glen...ing/1221408236
    Apr 2019
    Aust
    Whoa, on the first picture I got excited! But then I saw that is a whole three-dimensional piece (including the stem protection) and that won't fit for sure. The angle is bigger and wouldn't fit without having to cut it off. Infinite thanks Phil!
    No worries, just stumbled upon it and thought it might work. You'd be extra lucky to find all the angles the same though. Unless you know a bloke who is pretty handy with an angle grinder and a welder.....
    Aug 2020
    Yamba NSW OZ
    Hi all
    I'm a newcomer to the to forum. I'm the new owner of Siquando. Look forward to learning how to keep the water out!
    Here is a video I made about the boat - https://youtu.be/4KHxEAtNEkQ A few surprise repairs, but hopefully nothing that effects the structurally integrity
    Adelaide, South Australia
    Following with much interest. I met Jorje and Jodi in Adelaide. I've lost touch with them and I was wondering about Siquando as well as them.
    Aug 2020
    Yamba NSW OZ
    Hi Bruce
    Jorge and Jodie sailed Siquando to Yamba, where they sold it in December 2019 to me. It is my first yacht and when I bought it, I knew absolutely nothing about yachts. A local from the yacht club came out for a test sail and his survey was to check the bilge, and on seeing dust said, 'This is what you want to see' The boat is dry but on docking I found a few unfortunate surprises - a previous repair had delaminated in front of the keel and a few bug holes in front of the rudder. A bit of water logging in the repair in front of the keel (out of the water for a week to dry) I'm a bit concerned there could be some wet spots, and most of the bolts along the keel have a bit of rust. But every one who looks at the boat say she is built like a brick ****house. Big learning lesson for me, but I must say a wooden boat has an appeal, when inside, that you just don't get with a fibreglass boat. Here is a short video I made with some shots of the boat https://www.youtube.com/watch?v=UBycyyQe9Tg
    Feb 2012
    Sorrento Australia
    Hi Siquando, nice vid of your boat. Ive re posted it. I noticed mention earlier in the thread of an ozfridge. They are pretty good as most of the wooden boats around here have them.
    Bruce Cockburn
    Aug 2020
    Yamba NSW OZ
    Here is another video of Siquando, with some more information
    Aug 2020
    Yamba NSW OZ
    I have a cold-moulded Triple diagonal Oregon hull that is Dynel sheathed. I am getting some cracks along the Hull. I have tried filling with bog, but they reappear. Would I be best to sand back and fill with epoxy and fairing filler and overlay with fibreglass cloth?
    Gonna need more info and better pics.
    In the one pic shown, It looks like strip planking.
    Where on the boat is it happening?
    Is it all over the boat?
    Is "bog" epoxy?
    Is the dark color spray paint?
    Sanding back and using fg is probably not the best thing to do.
    Is the deck leaking above the hull cracking?
    Aug 2020
    Yamba NSW OZ
    So l have sanded back the crack. There are three silicon bronze boat nails on the left hand side. An old trawler boat owner suggested l use everdure ( two pack epoxy wood preserver) then either fill gap with sikaflex or west system epoxy. I was thinking of filling with a thin slice of thermolite, which I have been using instead of marine ply on deck repairs
    Aug 2020
    Yamba NSW OZ
    Is it all over the boat? no just towards rear of boat on both sides of cockpit
    Is "bog" epoxy? yes
    Is the dark color spray paint? primer
    may have been deck leaks prior
    A broader photo to show the location might help, but if you think that it’s below a deck repair you may have some rot between the diagonal layers. So it may be worth exploring a bit deeper through the layers, you could take a core with a small circular saw that you can fill easily with a plug later on if there’s nothing nasty found.
    If there is rot between the layers you will need to cut it out as far as it spreads and do a local repair, glassing over it without removing the rot will just promote more rot below the glass.
    Repairing it isn’t its scary as it might sound.
    more photos please
    Maybe those bolts are holding stantion base and maybe that hole is a scupper or hause and maybe the crack is diagonal and maybe there are more cracks and maybe the 3 nails serve a purpose related to the leak....but we cannot be sure cuz the photo is lonely.
    by n by, if the boat is epoxy cold molded wood, one uses epoxy and wood for repair, not sika or whatever thermalite iz.
    bruce
    Bruce, it’s triple diagonal Oregon (DF) dynel sheathed - this looks like a shrinkage on a strip of the outer diagonal layup........Cause? Moisture and drying cycle under the sheathing?
    Aug 2020
    Yamba NSW OZ
    l used everdure ( two pack epoxy wood preserver) then filled gap with west system epoxy and microfibre filler then and fibreglassed over entire area. An old trawler owner said I need to check the ribbing in this area to see if they are loose and also check my rudder in case it is vibrating. It looks as though this has happened before close to this area as there is the new paint of previous repairs
    WhatsApp Image 2021-06-01 at 2.52.40 PM.jpgWhatsApp Image 2021-06-03 at 11.57.36 AM.jpg
    So it’s directly below a stanchion that I’m assuming is screwed into the deck as well as the tow rail..?????.. a likely cause of fresh water ingress under the sheathing.
    I must confess that I am surprised that you aren’t taking any heed of the warning that there is likely to be rot or more damage in the layers underneath the visible outer one. By sealing over the top you are just sealing it in to continue to grow.......or are you banking on that being someone else’s problem?? Which, if you think it has happened before, is likely what the previous owner thought....
    Aug 2020
    Yamba NSW OZ
    I poked around inside the crack and scrapped out the edges. I've dealt with rot before on this boat and am aware of the canned tuna effect rot can have on wood. It seemed solid on the next layer, although I envisage having to sand back and check this whole section to the water line.
    Aug 2020
    Yamba NSW OZ
    Siquando has a double steel ring frame support amidship, with steel chainplates welded to the ringframe. Rust has appeared where the steel plugs of the ring frame come through the hull. It appears that previously these plugs have been sealed over with epoxy bog. Can I lay epoxy and a fibreglass sheet over them? Will doing this also lead to rust?
    Aug 2020
    Yamba NSW OZ
    At the top of my transom I had several vertical cracks appearing. I sanded back and found they ran along where nails are in my cold molded hull. Why would this happen? The hull has dynel sheathing but I was thinking of fibreglassing over the cracks to add strength. What would people suggest I do for this repair?
    Rusty fastenings underneath would expand causing the sheathing to crack. Is it just the sheathing that's cracking or the transom timber as well?
    Aug 2020
    Yamba NSW OZ
    Cracks have appeared on the outer third layer of my Oregon cold molded hull. They appear only towards the rear of the hull, on both sides. Someone suggested this could be vibration from the motor or rudder. Has anyone else experienced this?
    Attachment 91835 Attachment 91836
    Aug 2020
    Yamba NSW OZ
    cracks in timber vertical where nails are. Here is another photo
    Attachment 91837
