Results 36 to 65 of 65
Thread: Building "shoe" for Spike (Oughtred Design) = Convertible skiff to sail-motor-sail...
    Feb 2010
    Austria
    Default Re: Building "shoe" for Spike (Oughtred Design) = Convertible skiff to sail-motor-sai
    Inside-painting from frame forward.
    Placing and gluing foam-panels at this zone will be next.
    Hay mas tiempo que vida!
    It's coming along very nicely. I'm curious. If it separated from the mothership, would it float the motor?
    Feb 2010
    Austria
    Thanks Woxbox. Good to see Senior Members watching my project.
    Separation from mothership should not happen, as shoe will be bolted/secured to mothership with three strong bolts. One into skeg, two between splash-well and transom of mothership. May be two more small bolts through frame #4 of mothership, near gunwales.
    But, if accidentaly, "shoe" gets separated from mothership, shoe has enough buoyancy to float with motor attached. Motor (Mercury 5 hp) weights about 30 kg ( 60 Pound) and I have built-in already at least 140 Liters of foam-panels into shoe, which means I do actually have 140 kg (280 Pound) uplift.
    Due to the wider and longer stern of the boat I am gaining, compared with the buoyancy-situation of mothership only. This adds safety for sailing in motor-mode and cares for motor-weight and better hydrodynamics.
    Feb 2010
    Austria
    Foam panels placed at bottom-transition. Remaining space will be filled using liquid PU 2-component-foam poured from top with mothership acting as formwork, separated with PE-sheets.
    Panels glued to bottom. Some more foam in aft-part (above waterline, for safety/space-filling only):
    Excessive foam trimmed:
    Feb 2010
    Austria
    Bottom-transition secured with screw/pin:
    viewed from below:
    Feb 2010
    Austria
    Quote Originally Posted by koederfischgriller View Post
    Hi
    Daggerboard Plug obviously.
    i like this kind of "swiss army knife boat approach"
    Changed daggerboard-plug for a more robust solution. This allows to install plug top-down:
    Fwrd-bracing of daggerboard-case changed. Will need still some bracket and finish-work:
    Daggerboard-slot viewed from bottom up:
    May 2012
    UK. Cornwall, Suffolk.
    Throw her in the water!
    My popcorn is ready...
    Feb 2010
    Austria
    Shoe-shell-structureincluding installation of connection-bolts finished:
    Transition-zone shoe to mothership (8 mm dia bolt connecting shoe with skeg/keel of mothership visible):
    Detail transition zone (bolt through frame 4 holds cheek of shoe to plank near gunwales. Black rubber-seal between shoe and water-zone):
    Looking really good. Any chance we'll see a video of the trials?
    Feb 2010
    Austria
    Thanks Dave,
    yes will to do video/pictures of trials. First launch into Alpine-lake with electric motor (probably will borrow Torqueedo 1003). Planned mid June this year. Test with Mercury 5 hp gasoline outboard in the Laguna di Venezia thereafter in summer.
    But need to slow down progress now, as other more urgent project to be done. Therefore much less frequency of posts in this forum from now onwards, until I restart working on this again.
    Remaining steps on this "shoe"-project:
    - Countersink bottom-bolt and secure transition-plate with pin
    - Cover mothership with PE-sheets to allow separation of shoe for foam-filling-step: Fill remaining voids inside shoe with foam (pour-in from top at gunwales)
    - Cover gunwales of shoe with glued-on ply-sickle. This will give more lateral stiffness to cheeks of shoe, will be installed with flare to shed water and will cover all foam from being exposed to sunlight
    - Sand, varnish, paint. Also repaint/varnish mothership
    - Glue rubberseal onto cheeks
    - Construct trolley and simple wooden-ramp, to be able to load/unload/slip boat onto my standard trailer with small boat-winch
    Feb 2010
    Austria
    Some cateye-cosmetics done. Cateyes = splash-well limber-holes = handles for putting shoe on to mothership
    Feb 2010
    Austria
    Now I am continuing my project, building a shoe to convert sailing-skiff "Spike" to 5hp motor-skiff and vice versa.
    Here shoe filled with PU-foam-panels before filling with liquid PU-foam:
    "Mothership" covered with plastic-sheeting to separate hull from liquid-foam to be poured into fwrd. part of shoe:
    Tape fwrd-end of shoe in order to stop liquid-foam to spill:
    Turn-over boat and fill remaining voids (fwrd part of shoe) with liquid PU-foam from top:
    Cut foam overspilled at top of shoe:
    Feb 2010
    Austria
    Glue bbrd deck-plate onto shoe after foam-filling is complete:
    and trimmed:
    Feb 2010
    Austria
    Taking off shoe after foaming of remaining voids:
    Plastic sheeting, separating mothership from shoe worked well:
    Separating sheeting taken away. Foam-filling worked quite well:
    Dec 2017
    Germantown, NY
    How hard did you have to swing Thor's hammer to get it to pop off?
    Looks great, I can't wait to see the pics of it on the water.
    Feb 2010
    Austria
    Quote Originally Posted by jcpout2c View Post
    Thanks jcput2c, good question!
    Answer: Exactly three times. Falling head 1 1/2 feet = 0,471 meter. Yes, I counted the hits ;-) and used a peace of soft plywood to protect shoe from sledgehammer-impact. Most probably friction at sides of mothership-skeg was main reason. Glad I separated thouroghly with robust PE-membrane and taped all off, as glue to body of mothership would be impossible to get it loose. Using liquid foam-fill as an art by itself, one has to be very fast to get in liqid before foam starts to build-up. On the other hand, very liquid-mix finds its way to every void and hole and foam expands. Needs luck or experience. I was lucky.
    Yes, as promised, pictures of launching will be taken, but I will have to finish/paint first.
    Feb 2010
    Austria
    Feb 2010
    Austria
    Foredeck filled with PU-panels for additional flotation:
    Cover PU with 4 mm mahagony-ply:
    Epoxi shoesole:
    Feb 2010
    Austria
    Preparing simple trolley using my canoe cart:
    Not yet tested! Will see soon if/how it works.
    Jun 2017
    spicewood, texas, usa
    just found this! amazing work pate. i think you must be an engineer after all that nice work. i am looking forward to your tests and finally ride in venice. cool trolley!
    jim
    Aug 2014
    Bavaria, Germany
    Hi,
    looks great! A "runbehind"
    Feb 2010
    Austria
    Painting waterline (just a guess, will see soon if this is correct location).
    Plug for daggerboard-slot = fwd seat:
    Ready to get wet with her finished shoe.
    Keep fingers crossed!
    Feb 2010
    Austria
    New standard trailer. Made wooden ramp and simple trolley. Sold my previous boat trailer as only used for boat. Now I can use this trailer for other issues such as transporting material, furniture, firewood, waste....
    Feb 2010
    Austria
    Putting her into water. Re-christening her to "Gualala" (now with shoe!):
    First test with small electric motor Minnkota Endura C2
    Stability-Test. Boat much more stable compared without shoe:
    To my surprise: Boat still very good to row with shoe. Even better. Almost 3 feet increase in length does have positive effect!
    Feb 2010
    Austria
    Videos as promised:
    - First test-drive with small electric Motor Minnkota Endura C2 40. As we cannot use gasoline-engines in alpine lakes I used this motor to see how my project is performing (shoe-system function in general, loading/unloading with new trailer and trolley, rowing, stability, deadwater-issues?, hydraulical behaviour due to transition mothership-shoe...)
    - Project has been designed for use of an 5 hp gasoline outboard. This configuration will be tested in a few weeks in the Laguna of Venice. I expect that the boat will go to gliding-mode with this additional power.
    First time with small motor:
    Feb 2010
    Austria
    Stability-test:
    Feb 2010
    Austria
    Sailing in front of the wind with small electric motor. Wind about 2 BF. Max V of boat was 5,4 km/h (about 3 knots):
    Excellent!
    Jul 2010
    northeast Ohio
    Yours has been a very interesting project. Glad to see it working out for you.
    It will also be interesting to see how it goes with the gas motor.
    Thanks for posting your project.
    Feb 2010
    Austria
