Results 1 to 5 of 5
Thread: Chainplate mount question
    Jun 2018
    Fullerton,Ca,usa
    Default Chainplate mount question
    Hi All,
    Im building a Oughtred Gannet in glued ply and am trying to make sense of the chainplate attachment shown in the drawings. They seem to indicate a 1/2 thick pad glued to the inside of the boat just below the gunwale and then the chainplate on that pad. However, the drawing also seems to show the top of the chainplate lying flush against the sheerstrake and passing upward through a notch in the gunwale. These two things seem to contradict each other so I think Im missing something. If anybody understands this and can help Id really appreciate it. Thanks in advance.
    Steve Zicree
    Default Re: Chainplate mount question
    I'd go with this block, it will be stronger. Make sure that the top bolt has a big bearing surface on the outside of the boat to resist the inward component of tension peeling the chain plate inwards and drawing the fastening.
    Aug 2016
    Queens, NY
    maybe it's meant to be flush on the outside but through bolted with the backing block on the inside ?
    Quote Originally Posted by coelcanth View Post
    OK, bolted to the outside of the sheer passing through a notch in the rubbing bend and bolted through the doubler block on the inside. The best of all worlds.
    Jun 2018
    Fullerton,Ca,usa
    I appreciate the guidance. I think the arrangement with the chainplate on the outside and the doubler on the inside makes the most sense.
    Truth is I’m still not decided between balance lug and gunter rig, so the chainplate might not be needed. Tough decision.
    Steve Zicree
