Results 1 to 19 of 19
Thread: Macomber 15' Traditional Skiff Build
    Feb 2016
    Madison, Connecticut, USA
    Default Macomber 15' Traditional Skiff Build
    This will be my attempt to thoroughly document my girlfriend and I's build of Scott Gifford's Macomber 15', a traditionally built skiff modeled after the Westport River Skiff. I have built the Devlin Polliwog and the CLC Northeaster Dory, both stitch and glue. As a cabinet maker and finish carpenter, I'm excited to pick up a hand plane and put down the resins and give a go at a traditional craft.
    I'm going to share up to date costs and labor time as a resource both to myself and anyone who may be looking to build a similar skiff. I can't be the only one who wonders "but how much will it cost!" when eyeing potential designs.
    The transom will be 5/4 mahogany, side and bottom planking to be eastern white pine, and structural framing to be white oak. We're hoping we can complete the build for just over 2k not including the outboard.
    On Saturday, we cut the station molds from 3/4 exterior ply and ordered our fasteners. Using the cabinet shop and the makita tracksaw made this quick and easy. We have a detached single car garage at our house that we were thinking of building in, but came to the conclusion it is probably too small (~18' x ~12') and cold (uninsulated). Luckily I have a friend with a shop/warehouse space far too big for his current operation he is letting us build in.
    This week we aim to complete the building jig and glue up and cut our transom.
    Fasteners: $550
    Molds: $60 - 3 hrs
    Total TD: $610
    Total Labor TD: 3 hrs
    Aug 2013
    Valnesfjord, Norway
    Default Re: Macomber 15' Traditional Skiff Build
    Subscibing!
    Looks like a great project. I'll be following along.
    Jun 2017
    spicewood, texas, usa
    sounds like fun!
    jim
    Feb 2016
    End of week 1 - we got the transom glued up and the stem cut out, ready to build the jig for week 2.
    We used 5/4 Sapele for the transom and glued it up in three pieces. The lumber was bought rough cut to about 1 1/4" thickness, so we planed it down to 1 1/16". We used Jamestowns Total Boat epoxy for the glue up and used festool dominoes to align the joints and provide extra structure. The plans call for a spline or biscuits, but we figured dominoes would be a superior joint.
    The stem was laminated 4/4 (rough cut) white oak then sent through the table saw to get our stem angles.
    We used paint scrapers to scrape the excess epoxy once it had cured. Thanks to Lou at total boat for this tip. We're VERY happy we didn't need to use an orbital sander to get it all off. The transom turned out fantastic. Flat!
    - leaving Parkerville Wood Products with our Sapele and White Oak. We rough cut at the yard so we didn't need to travel with 16' lengths on the truck rack. This lumberyard was about an hour away, located around Hartford, CT. Great supply though and some awesome exotic woods!
    - ripping a straight edge onto the transom planks using plywood as the fence
    - did someone say "dust collection"??
    - transom edged and planed
    - dominoes every ~10"
    - epoxying the joints
    Hours:
    Fasteners: $550
    Molds: $60 - 3 hrs
    Lumber: $137.62
    Total TD: $747.62
    Total Build time TD: 13 hrs
    Feb 2016
    - glue up, wax paper everywhere so we didn't make a mess of our clamps
    - wogodenboat forum meet Dana, Dana meet woodenboat forum.
    - did someone say epoxy dust?
    - the transom scraped and sanded. We rubbed a little paint thinner on it to see how the grain would pop once varnished
    Feb 2016
    - ripping the stem angle
    - the finished stem
    Is there much in the way of framework support for the transom? What you call dominoes, we call biscuits. Thats going to look great!
    Feb 2016
    The transom will have an outboard plate with the grain running vertical, along with a transom knee and quarter knees. Thanks!
    This will certainly be a learning curve, any tips are greatly appreciated!
    Is there an inside frame on the transom or does your planking fix direct onto the transom only? It can be done both ways, not familiar with that design, the transom looks thick enough for direct fastening.
    Feb 2016
    There will be white oak corner posts at the transom. I believe the planking will be screwed to the transom and the corner posts, but Iíll have to check the plans to be sure!
    Feb 2016
    What’s the best way to go about bailing the boat if left at a dock? We plan on keeping the skiff in the water, but I’d rather not have to go bail the boat out with a bucket every time it rains. Any thoughts?
    Lake Champlain, Vermont
    Quote Originally Posted by Woodenboatsarebetter View Post
    I keep my dinghy, a Cape Dory 10, at the dock all summer. To take care of rainwater I have a 12v motor cycle battery in a bracket under the center thwart to power an automatic bilge pump. The battery is good for about three months before needing to be recharged. I keep the pump in the lowest part of the hull which fortunately happens to be right under the center thwart so it is all pretty much out of the way. This might not work as well for you with a flat bottomed boat, but definitely better than nothing.
    Feb 2016
    Thanks for the tip Oldad, I think I came across one of your previous posts explaining this.
    So we currently have most of the jig built, almost ready for the molds, transom, and stem to go on. How do I make sure everything is centered while attaching the molds? I was thinking about stringing a line since the molds have center lines, or setting up a laser. Maybe setting a laser 6' high or so near the stem of the boat and using the plumb line to center everything from the transom up? Sorry, I'm thinking out loud here.
    Our No. 5 jack plane and Stanley rebate plane came in today so I've been sharpening them tonight.
    Heres some photos of the action.
    Feb 2016
    Also, the plans call for boatlife caulking, but I’ve seen mixed reviews about the stuff. Does anyone have other recommendations? This is for caulking planking to planking, planking to chines, chines to stem and stern etc
    Jun 2014
    "Dominos" are not really the same as "biscuits" I think. Festool's dominoes are much more substantial than the typical "biscuit joiner" biscuits; they more resemble a mortise and tenon join with what is often called "floating tenons" or "loose tenons."
    regards
    pvg
    Jul 2010
    northeast Ohio
    Boatlife is good stuff.
    Takes a while to dry before you can paint over ---- is the only shortcoming I have experienced.
    Plan for that and you should not have any troubles.
    Feb 2016
    Hey everyone, I have a few very naive questions...
    - I am starting to fair the transom and stem. The plans state to start fairing only where the garboard plank will land, about 8" down on the stern and 12" on the stem. Basically, fair for one plank at a time. Is this done mainly with a spokeshave? If done with a block plane, the block plane will ride up onto the unfaired portion and the plane iron will no longer contact the material. I am new to using hand tools and the learning curve is more than expected! Also, should I fair down a little past where the garboard plank will land? I don't see how I could fit a block plane or spokeshave beneath the plank to fair up close to it.
    - Should the corner posts be bedded to the transom? The plans don't state to bed them but I'm having second thoughts. I did however put a little bedding compounds on the tip of the screws.
    - When I place a batten across the chine pockets, they want to sit away from molds, thus changing the shape of the chine line. Once I fasten the chines, should I put a few temporary battens across the bottom so they hold to the molds until I start bottom planking?
    Stern fairing
    A lot of material to take out at the stem!
    some quick lapstrake clamps
    Thanks for any help or just letting me know I'm on the right track (I have my doubts)!
