Results 1 to 14 of 14
Thread: Electrolysis Tank for rusty parts
    Default Electrolysis Tank for rusty parts
    I have a large vice that's very rusty and need to clean it as well as some saws, etc.
    I've got an electrolysis tank set up in a large plastic tote, all wired up as I have seen via YouTube. The water is in with the sodium carbonate and the electrodes are in place. Pretty as a picture.
    The issue is my power source. The charger I have is for trickle charging a deep cycle trolling motor battery. It's got some whiz-bang circuitry in it (I think) that is preventing any power from reaching the terminals in my tank. All I see on YouTube says 2 amps should be plenty so I'm not even gettingthat.
    I know zip about how battery chargers work and have no idea how to fix this.
    Useful suggestions are appreciated. Suggestions like "grind the rust off" not so much...
    Cheers!
    Oct 2018
    lagunitas, ca, usa
    Default Re: Electrolysis Tank for rusty parts
    Quote Originally Posted by cbcc View Post
    Put a battery in series with the charger ? Buy a cheap old unsafe charger off craigslist that doesn't have these safety features ? Just use a battery without the charger ?
    New Zealand's Far North
    Connect a 12V battery to your tank. Disconnect it from the tank & put it on the charger when it gets down to about 10 -11V.
    I used this system when cleaning the inside of an old motorcycle tank.
    I was surprised at how quickly it worked, and also how quickly the cathode eroded. (Cathode, Anode, I forget which.)
    I have a similar charger which wont charge a nearly completely discharged battery. I usually connect another better battery in parallel until the discharged one comes up enough for the charger to see it.
    I know just as much as the OP about smart chargers, zip. So I looked it up. This site http://www.a-aengineering.com/chargeroperation.htm says "This charger has a CHARGE ENABLE function. If you connect a battery that has less than 6V, the charger assumes there is a defect in the battery and it will not attempt to charge. Likewise if you turn the charger on without a battery connected, the charger will not output any voltage/current. This is a safety feature which prevents output short circuits."
    Looks like you need a battery. If you run the battery in parallel with the charger and electrolysis tank, I think it will over charge the battery, so Stiletto has it right, you have to alternate between charging and electrolysis.
    https://www.youtube.com/watch?v=y4yYF8gSHdA
    For small jobs, if you can get hold of one of these, you've got it made in the shade:
    May 2009
    Fort Worth, Texas, USA
    A plain old charger from Harbor Freight is all you need, and it probably will be cheaper.
    What I want to know is how are you going to avoid rust once the parts are cleaned?
    Newly "de-rusted" parts tend to rust quickly.
    You going to paint or apply some coating? What if you are using a coating?
    Thanks.
    Oct 2018
    lagunitas, ca, usa
    'zat yours ? Want to do some engraving, electro-chemical-etching-style ?
    I think that's the ticket, thank you. I've looked for an old style battery charger on Craigs list, pawn shops etc. with no love.
    Stay tuned for before and after pictures.
    Oct 2006
    Livin' in the Golden Triangle
    Search for molasses rust removal. I've done threads on it
    Or soak the parts in molasses
    I've used both the molasses and the electrolytic method, electrolytic is faster in my experience.
    May 2012
    Central Ohio
    Just at HF earlier today. They have an old-school 5,10, and 50A(! or more) 'dumb' charger for about $30 with a coupon. (The 50A option is only for about a minute with a cool-down interval, and used for car starting.) But the 10A is the right thing. It weighs an appropriate amount to have a big old transformer in it.
    For a container, I picked up a city-size rolling trashcan -- I think its 90 gallons. Have some auto front suspension parts to do...
    Texas
    Reminder not to use stainless.
    Thanks Chip. My Craigslist charger was gone when I heard back from the guy. On my way to HF.
