Results 1 to 14 of 14
Thread: door furniture
    Nov 2012
    Tasmania
    Default door furniture
    I'm at the stage with my mini tug where I'm thinking about making a door for it, the plans recommend 12mm, the trouble I'm having is finding a decent handle/lock for it, I can build the the thickness up where a door handle will go or should I just use the good old hasp and staple with a padlock, what does everyone else use?
    Phill
    Default Re: door furniture
    Why not apply fgraming
    to make a door that looks worthy of the tug.
    Building up a frame around the perimeter - so the door will accept typical hardware - is a perfectly reasonable approach.
    If that won't work for some reason... there IS hardware for slimmer doors available from a variety of sources. Don't know what's convenient for you, for sourcing or shipping... but here's some I use here --
    https://www.hafele.com/us/en/
    https://www.rockler.com/
    https://www.jamestowndistributors.co...portal/main.do
    Mar 2014
    Hasslö, Blekinge, Sweden
    12 mm seems a bit thin for a door, so I would use that for panel/s and make thicker frames. A panel door (is that the name for it) looks an awful lot better than a flat one too.
    /Mats
    Yes the avatar depicts me; yes I drew the comic boat pic, it's a joke on the pop song I'm not a robot by Marina and the diamonds
    /Mats
    Frame and panel.
    Mar 2017
    Waterbury Center, Vermont
    Check out https://whitechapel-ltd.com/?SID=ck5...8nnid98m8d3c13. They have a lot of odd sized hardware.
    Feb 2001
    Seattle, WA USA
    You need an old-school rim lock, like this one.
    https://www.toplicht.de/en/shop/schl...stenschloesser
    Nov 2012
    Tasmania
    Thanks for all the input, I usually sit down with my marine catalog looking for suitable items, never thought to check out the Hafele range, used their stuff for years and yet it never crossed my mind .
    I do like the look of that polished brass item at the end, I will be looking into those I think.
    Thanks again
    Phill
    I will be surprised if the Hafele products are marine worthy. They likely have internal parts of mild steel.
    Hafele carries a line of statinless steel hardware that I've used a number of times for marine applications.
    Oct 2018
    lagunitas, ca, usa
    Quote Originally Posted by mermod View Post
    I'm at the stage with my mini tug where I'm thinking about making a door for it ... what does everyone else use?
    Hope this gives you some ideas, it's fairly simple and works well, I believe it's common on log-tow tugs in the northwest of the US. The door slides in a track top and bottom, takes up very little space, it's pretty trick. Especially the advanced locking system
    Aug 2006
    Rockford, IL
    Not recommending you do it in your tug, but we are very satisfied with an ordinary black-finished die-cast zinc storm door knob and spring-loaded catch from a builders' store for the head compartment door in our Albin-25. This door was originally secured by a pair of spring-loaded ball bearings with rigid catches, however, flexibility in the door panel would make for premature release of one or both latches. Sometimes a temperamental "slam" seemed called for in order to get both laches to catch. The storm door hardware operates properly 100% of the time. Typical aluminum storm door hardware is designed to fit doors thinner than wooden exterior doors.
    Oct 2018
    lagunitas, ca, usa
    Just came across this, it's cute.
    https://seattle.craigslist.org/est/c...736428090.html
    but on a smaller boat the sliding door is a big space-saver ...
