Results 1 to 27 of 27
Thread: Optimist build My first boat build
    Aug 2018
    Boise, ID, USA
    Default Optimist build My first boat build
    My daughter and husband Live in Coeur d'Alene, ID and have a J24 on Lake Pend Oreille that they sail and race. I have been drafted on occasion to act as ballast mainly. Early this summer they started a non profit Coeur d'Alene Youth Sailing Association to teach kids to sail. The fact that my grandson was 6 and wanting to help sail was some of the motivation to start it. Dan's (my SIL) father had owned and operated a marina in Sandpoint, ID until he sold it to the city a few years ago. Dan did have an Optimist and a Laser in addition to the J24.
    When they formed the association the requirement to participate were a child wanting to sail, a responsible adult, a life jacket, and if possible an Optimist. Dan did find and buy a used optimist in the Seattle area and brought that back to Cda and his brother gave him his Laser so the fleet consists of 2 optimists and 2 lasers and one of the families brought in an optimist for their daughter. This gave them 3 but still left them a little light on boats. My daughter thinks that all she has to do is ask and I will build whatever she asks for. I get a not so subtle FB message directing me to an Optimist plan. I ordered a plan from CABBS and after looking it overtold them they supply the sail and rigging I will build the boat.
    Here goes nothing. I have the strongback built and have started gluing up some of the components and hopefully this will float next spring.
    se pa (Bristol PA)
    Default Re: Optimist build My first boat build
    Welcome aboard!
    level level and check level on the strong back before during and often as you build they have a tendency to twist when you assume they are stable.
    found a a build blog here.
    http://cabbs.org/cabbs-optimist-construction-photos/
    When I was 16 our yacht club decided to start a kids' sailing program. At the time Optimists were not manufactured but the plans were freely available. I worked with a local shop teacher to crank out what were essentially kits - all panels cut, chine logs, risers, gunnels and all that cut out. All to excellent tolerances. Perhaps things would have gone better had we insisted that the kids be involved in the building. In the event, there was a beer fueled night in which twenty or so dads made all the boats ready for painting. Some worked together, say three dads making three boats. Others worked alone. Some followed the plan exactly. Some were a little sloppy. And some had theories of how to improve something, bottom rocker for example, and found ways to fudge what they wanted without making obvious changes to the panels.
    In those sexual stereotyping days, the moms made sails.
    No two boats were quite alike.
    The sails were.
    But who cares? Community boatbuilding is always good.
    G'luck
    Congratulations, you've taken the first step toward delightful craziness. But you might want to raise that strongback up to a comfortable working height. Your back will thank you.
    Dec 1999
    Oriental, NC USA
    I built several optimists in the 60's to the original plans from Clark Mills. Easy and great little boats for kids. About 10 years go I built a mold from which about 30 optimists were turned out to the International Optimist Association rules. This was more of a PITA as the rules and tolerances are ridiculous. It seems the IOA frowns on home builders and goes for the very expensive commercially built fiberglass version. Good on you for not getting involved with them.
    If you are using the same building jig that Clark Mills suggested, the building height will be fine and much higher than the photo implies.
    Tom L
    Jan 2011
    Norwalk CT
    What Jeff said. Work at a comfortable height, build a stool for the kid to stand on. Optis are easy and fun to build and a ton of fun for kids to sail.
    I will light up like a Christmas Tree if my (as yet unconceived)grand daughter ever asks me to make her a boat!
    bruce
    Aug 2018
    Boise, ID, USA
    I got the Bow, midframe and transom glued up, cutout, legs installed and everything on the strongback. I even got the keelson cutout. fit and installed. It looks pretty good everything is level and straight. Should finish the frame tomorrow and then it's off to Coeur d'Alene for week. One thing about these fram pieces they are making a dent in my warped lumber. I barely had to bend the Keelson to get it to fit.
    Aug 2018
    Boise, ID, USA
    The Frame pieces have legs on them that get everything up to a comfortable height.
    Aug 2018
    Boise, ID, USA
    If you are using the same building jig that Clark Mills suggested, the building height will be fine and much higher than the photo implies.[/QUOTE]
    When I was searching for info and watching you tubes on Opti's. I printed out the measuring grid and tolerances a 2-3 mm tolerance was way tighter than I was going to build too. The kids don't care, if they get to where they want to race nationally or internationally. The parents can buy one that meets those tolerances.
    Aug 2018
    Boise, ID, USA
    This is the reason for this project. My Grandson and a friend on Lake Coeur d'Alene a couple of weeks ago.
    Aug 2018
    Boise, ID, USA
    I got all the stringers and frame members glued and screwed except one chine. I had it all clamped down with glue applied and was tightening the last screw when crack it breaks tight at the tightest part of the bend.
    I got it unscrewed and the glue cleaned up. I had cut a spare chine just for that eventuality. I came up with a redneck steam system. I wrapped the wood in towels and poured boiling water on it for about 20 minutes that got the temp up to about 130F. I clamped it a little differently and it pulled in a lot easier than the previous one did. I let it dry a little then drilled and screwed it and left clamps in place. I'll take everything off and glue it up next week when I get back. Once that is done need to cut extra wood down and fair up some things then should be ready to screw and glue the plywood on.
    Aug 2018
    Boise, ID, USA
    A little more progress have the sides and bottom glued and screwed on.
    se pa (Bristol PA)
    aromatic cedar?
    Aug 2018
    Boise, ID, USA
    Yes, I picked up about 700 BF of this for about $ .50 a BF so I use it for quite a few projects. It's about with maple for hardness, fairly light, good rot resistance and fair strength and looks good. You do have to watch for knots.
    Southern Maine
    Somewhat down the road, but you used to be able to get Opti "practice" f9or about $100 on eBay. I lookd and could not find them. They are just as good as the class sanctioned sails.
    There is what appears to be an official sail for $115. https://www.ebay.com/itm/Optimist-Cl...0:pf:0&vxp=mtr
    Aug 2018
    Boise, ID, USA
    I hadn't looked on ebay yet. There is a ton of sails out there in all different prices from about $170 and up.. My daughter and SIL have a used genoa and his dad has several used sails. I think they are going to cut one of those up and make a sail from that just for the fun of it. I haven't been able to find any 13/4" round stock. I got a clear fir 2x6 that was close to being QS today and ripped that in half and glued it up. I'll cut that into a hex and get the spokeshaves out later on. I should be able to come up with a pretty good mast.
    Aug 2018
    Boise, ID, USA
    I am still working on the optimist. I put the box in for the daggerboard and covered the exterior with fiberglass. I used 6oz cloth and two coat of resin. This will give me some abrasion resistance the beach they pull out on has a lot of small rock 1/4" and smaller. This should give that 1/4" plywood some protection and support when out of the water.
    I also glued up and made the mast round. I glued up the sprit and boom also. I made the boom and sprit out of red oak that came out of the Idaho state museum and I had to scarf a coup0le pieces together to get the length I needed for the sprit. the scarf came out very well you can't see it unless you no where the joints are and even then they are easy to miss. I'm very happy with those first time for scarf joints. The mast was glued up from a doug fir 2x6.
    I drilled an 1 3/4" hole in a piece of scrap and slid down the mast as I used a spokeshave to bring it down to round and correct size. I think it will work.
    And the boom finished all three with spar urethane. That brings me up to date. Working on the rudder, tiller and dagger board. Waiting on SIL to find paint in a color my grandson wants.
    Aug 2018
    Boise, ID, USA
    It's been a while since I posted any progress. I got busy and didn't take the time to post anything.
    I got the mast, sprit and boom finished with spar urethane just need to take them north and get them rigged probably do that in January.
    I glassed the exterior 1 layer of 6 oz glass and 2 coat of resin. It is on and sticking I should have done a better job of sanding and fairing.
    I turned it over removed the strong back, installed mast partner, dagger board case, sanded everything to 220 and put on 2 coats of spar urethane I will put on the last coat after the bottom gets painted.
    The interior looks pretty good. I was going to paint the bottom with exterior house paint as it time in the water is going to be limited. My son in law is sending a marine epoxy in his color choice, While I am waiting on that I will finish my daughters adjustable desk that I have been working on in parallel with the Opti.
    Congrats on this project. The Optimist is an 'evergreen' design. If there's a fleet of 'em to sail with, everyone will have great fun.
    Be open to building another later - when that grandson is old enough to help with the build. I built our first family sailboat, a Goat Island Skiff, when my boys were 10 & 15. At their instigation. It remains a highlight memory of their childhood.
    Nice work. Is the desk your own design?
    Nov 2001
    Seattle
    Costs less here:
    http://www.intensitysails.com/saforop.html
    Looks great.
    I love optimists. I've never been able to fit in one, only discovered them when i was about 14, but i love the idea of them.
    I have one a friend gave me a few months back, but haven't had the chance to drop it in the drink yet for my 2 boys. Pretty slack of me......
    Aug 2018
    Boise, ID, USA
    David G My grandson is about 350 mi away. I might end up taking strongback north this summer and help a friend build one for his daughter.
    Dave the desk was featured in a Woodsmith magazine. My daughter is an attorney with the Kootenai County prosecutors office and wanted something to stand up at.
    My SIL is getting the sail. I'm trying to talk them into sewing one. They have access to several used sails for material and the opti practice sails are a simple flat sail.
    My SIL did not scrimp on the paint. I received a quart of Interlux perfection in Lauderdale Blue, a quart of 2 part primer and reducebr />
    I got the rudder hardware. Hung the rudder and now time for paint
    I had a little fun with the primer the first coat crazed badly, it adhered well just had a lot of cracks all over. Did a little research and put in more reducer went from 25% to 33% and that helped a lot with the second coat.
    I sanded both coat of primer with 120 and went for the top coat. It was easy mix and apply sanded first coat with 220 and second coat with 320 the third coat I will rub with 4/0 steel wool and paste wax to knock any dust nibs back. My lousy fiberglas work really shows thru on that dark high gloss paint. It looks good as long as you're 20 ft or so away. The kids won't care as long as it floats.
    First coat
    Finish coat tape off the gunwales
    I'll set it set like that for a week or so for the paint to harden then turn it over and another coat of spar urethane on the inside.
    Aug 2018
    Boise, ID, USA
    For all intent and purpose the Opti is finished. I have to step the mast and rig it. I have to take the mast north in late Jan. to rig it and get a sail. It came out looking pretty good, at 20 ft it looks real nice. It will be the best looking boat in the fleet the rest are white glass boats.
    Jun 2017
    Boise, ID
    Wow, that thing is adorable! Would love to bring my Elf up to sail on Pend Oreille sometime in the spring. Would you be interested in a get-together?
    Aug 2018
    Boise, ID, USA
    Yes. My daughter live in Couer'D'Alene. The opti is going on Lake Couer'd'Alene. They have a J24 on Lake Pend Oreille they sail there. definitely like to get together.
