Results 36 to 70 of 72
Thread: Re-powering a Century Resorter - seeking input on engines
    Jul 2002
    Default Re: Re-powering a Century Resorter - seeking input on engines
    Since many have given an opinion here, I thought I might take the opportunity to present my opinion, since I restored runabouts for 35 years or so. Below is a Chrysler Ace, the little brother of the engine in the original post.
    The rebuilding cost of this engine was $15,000. It was common to be asked whether or not to rebuild an original engine. It is a personal question; there are many points to be considered. Here are a few, in no particular order.
    1. It ain't a cheap job. One is rebuilding the engine AND the transmission.
    2. There are very few people who are qualified to rebuild a vintage marine engine. In this town (Seattle) I doubt if there is more than a handful of guys. And there are fewer every year.
    3. Yes, they are simple engines, but they typically have many things wrong. It takes a pretty bright person to sort it out. A typical car or modern marine engine will have a few things wrong. It will be MUCH easier to figure out.
    4. Yes, old engines are really cool. However, they can be a royal pain in the butt. Again, it is a personal decision, but I think that most would be better off with a modern engine. It will be cheaper and more reliable.
    5. If one is concerned with originality...fine. However, there is only a modest show judging penalty for installing a modern engine in a classic runabout.
    6. Parts and labor can be very hard to find. Yes, there were thousands of these engines built. Used to be that Crowns could be found easily. These days we are at the bottom of the barrel.
    7. I wanted a rebuild on the carb on the Chris MB in my Racing Runabout. Thought I could do it myself. Ended up finding a guy out in the sticks to do it. Looked simple but was not.
    8. A customer rebuild his Chris MB in his Custom. If I recall, the major rebuild cost about 10k almost twenty years ago. The engine blew up almost immediately upon starting. The machine shop had not been checked it out properly. The mechanic rebuilt another block for nothing; he was a solid citizen.
    In other words, the answer is considerably more complicated than the boys here would have the original poster believe. Good luck! best/pcf
    I'm not so sure it would be that much, but you can pay as much as you want to for anything.
    A master rebuild parts kit for that specific engine is about $750.00.
    That is everything except pistons. All brand name products.
    https://www.cleggengine.com/engine-r...1933-1960.html
    (Even if it needed bored with new pistons (which I would do if it showed more than .002" wear), decked and line bored with new hard seats installed, I don't see how it could be much over $3500, assembled. The transmision I don't know, but if it is now working, I think seals and bearings would "freshen it up" for a few more years.)
    Yes. I think it's worth noting the difference between "rebuild" and "restore". Dan Payne's Ace in Pat's photo is a beautiful motor and I can see why it took $15k and 18 months or whatever to get it done. And if the OP sends his motor to Dave Van Ness for a concours restoration I think $15k is the low end of what it will cost. But a simple top end rebuild could be done by any competent mechanic with experience working on old American motors and wouldn't be anywhere near that much.
    The gear on the other hand I would leave alone unless there is some indication that it needs work. And in that case I would send it to a specialist. Sad story there: My dad gave the gear from his Chrysler Crown to an old boy in Maine for a rebuild. Two years later and it's still sitting in pieces under the old boy's workbench and the boat - a pretty little down east picnic launch - is now free to a good home as my dad has lost the energy and enthusiasm for it. They aren't complicated but they do require someone who knows what they are doing.
    Mar 2001
    Grosse Pointe, Michigan, USA
    FWIW, I had that engine, which was in my Dodge Power Wagon, rebuilt for $200. Of course, that was in 1966.
    Jul 2002
    You guys that are guessing about how much it should cost to rebuild a Crown marine engine:
    Are you aware that there is a difference between a car engine and a boat engine? Did not think so.
    Please furnish bonafide estimates on how much a rebuild should be. I have.
    I just rebuilt the 283 in a Chris-Craft (with new pistons because it was bored 0.020 over & a complete, done by a machine shop, valve job) for about $1K. Of course much of the labor was my own, but if I'd billed at $75/hour it woulda been well under 3K.
    While the gaskets are all CC only, pistons, rings, bearings, etc. are all "buy it on the internet" car stuff. Cam shaft would be CC only as well, but mine was fine.
    Jul 2002
    So what it sounds like is that we are obviously comparing apples and oranges. Or being a mechanic is a great way to get rich. Kinda doubt the second. However, would believe you if you can find someone in Seattle to rebuild a vintage marine engine for 3 thousand bucks. I will wait here.
    Jun 2017
    spicewood, texas, usa
    wow, 18 months and 15k! must have been many unobtanium parts on that restore. i mean that is not an airplane engine. then again that model may well have been a rare one.
    jim
    C'mon Pat, if you are going to be insulting please base your condescension on specific info not unsupported generalities. Do I know the difference between a car engine and a boat engine? Well, yeah. I do. Can I tell you the exact differences in compression ratio, cam grind, piston metallurgy, valve sizes, carburetor settings, etc. for a 1956 Chrysler Crown M47S over the equivalent car or industrial motor? No and I don't think you can either. But what I do know is that a top end rebuild is a top end rebuild and the rest is just parts.
    As for the cost - well no, you haven't provided a bonafide estimate for how much the rebuild on the OP's motor should cost. You have provided one cost example for one motor restored to what is evidently a high degree of finish and, I assume, a commensurate level of work on the internal rebuild, and you are asking us to take it as a given that every other rebuild of a similar motor would have to cost the same. BS. If I asked you how much it costs to restore a boat you would want to know what kind of boat and what it needs and the level of restoration desired and a bunch of other info before you would tell give me an estimate, and that estimate would vary widely based on the answers.
    At some point we got far enough into the weeds with this thread that I very much doubt it is doing a service to the OP. I maintain that there *may be* a path forward to rebuild that motor for far less than it would cost to repower. Maybe not. It could have a broken crank and a cracked head and rusted-through cooling passages in the block. But it's also possible that it it could be made serviceable and reliable with far less work. We don't have that info so we can't say.
    Jul 2002
    Please call a local (Seattle) engine shop and get a rough quote and report back here. I've done this stuff for nearly forty years. I am not just guessing like you boys.
    By the way, as I said, the rebuild on the Chris MB was 10k. That was about 2001 if I recall correctly.
    Nobody is doing the original poster a favor by suggesting that his engine can be rebuilt for $3,000.
    Please note I said "rebuilt" not "restored". To restore a motor to perfect condition is a completely different thing from rebuilding an engine to get it running better. For example, a lot of attention (& many hours) went into painting & polishing the engine you pictured. I spent $15.00 on a couple of spray cans of CC Blue & spent upwards of 15 minutes spraying the assembled engine. IOW - I'm afraid it's comparing a rebuild to a restore that's apples & oranges.
    Yes - exactly this.
    Pat, I'll grant you one point. I don't think $3,000 is a realistic estimate either if you just hand the motor over to a shop and ask for a rebuild. I said "under $10k" and I'll stand by that number assuming there are no major issues with any of the big parts - crank, head, block, etc. - or any marine-specific stuff like the manifold. But I do think you could get close to $3k if you were willing and capable of doing a lot of the work. Disassemble, send the head and block to Hill Machine and then reassemble with new pistons and rings? Sure. I think that's doable. Even if you had to machine the crank and do the bottom end I don't think it would get much over $5k. But that requires a certain level of mechanical ability and tools.
    Jul 2002
    I am still waiting for someone to quote a local to Seattle bonafide vintage marine engine mechanic offer to rebuild the Crown for $3,000.
    Not looking for what an amateur "thinks" is reasonable. Real world stuff, please.
    I have a call in to Mike Murley for an estimate on a top end rebuild, not a full show-quality restoration. Not local to Seattle, but I'd guess he has as much or more experience than anyone around here. I'll report back.
    Jul 2002
    We should be talking about a total overhaul. Including the transmission. No cheating please.
    Ok Pat, I talked to Mike. He says $10k-$12k for a full rebuild including the gear, and he says that's the only type of job he would do because anything else is just going to be a problem down the road. I'm going to say you win on this one. I still think you could find someone to do it for less but I would rather spend a bit more and have it done by an expert so there you go.
    Jul 2002
    Ok, I appreciate your honesty. This ain't my first rodeo.
    Mar 2001
    I've known Murley for many years, (assuming that is Murley Marine in St. Clair Shores) and he is quite good. He doesn't do production rebuilds anymore, although that was his main business for decades. Last time I talked to him, he said he only took on a few high-end projects, and did them his way, which is quite good and expensive.
    Jul 2002
    What you appear to be attempting to imply is that Mr. Murley's work is an outlier and that he does work for "showboats." I don't think this is the case, but you could prove me wrong by producing a thorough overhaul quote from a bonafide vintage marine engine expert for significantly less than that quoted by Mr. Murley. I do not think we will see it.
    Jun 2017
    mr. ford, i have not been on this forum very long but somehow from the first post you made i get a very negitave vibe. is there a lot of trouble in your home life or some other underlying problem? i bet you mean well but your communication skills seem to be lacking- despite your avowed "not my first rodeo". just some food for thought.
    jim
    Jul 2003
    Concord, NH, USA
    Gentlemen!! Yikes! Let's take it down a notch here!! OP here... I didn't look at this thread over the weekend and didn't realize it was still going!
    I appreciate everyone's input and advice, especially from those with greater experience than my own. There are clearly a number of approaches to a rebuild.
    In the course of trying to diagnose and possibly repair my engine problems myself I spoke with a couple of shops who have rebuilt or restored these engines. I spoke with Dave Van Ness initially, and today I called up Drake's Engines Inc. in Rochester, NY. My notes from speaking with Dave two or three years ago say this:
    "complete re-manufacture ~$5800
    new pistons, rings, valves, guides, springs... rebuild transmission, paint...
    10-15 hours
    rebuild can be less"
    My notes don't say whether Dave is including accessories in his ballpark number. I'm waiting to hear back from him to get more details and current information.
    Drake's would' probably be Van Ness's closest competitor. Most of his work these days is flathead 6 cyl engines. He has photos on his website of a very sharp looking crown
    http://www.drakeengines.com/marine.html (Crown photos under "Chrysler marine engine")
    From my notes from Drake's this morning:
    "Drake complete engine and transmission rebuild + accessories (starter, generator, water pump, etc...)
    $8000-8500
    Motor and transmission less accessories rebuild $6000-6500
    12V conversion could run to $1500 to $2000 with gauge conversion, new bilge pumps, other electrilal"
    Electronic ignition conversion would add ~$200"
    Neither of these includes costs of removing and re-installing the engine from the boat or transporting it to New Jersey (5-6 hrs) or Rochester (7-8 hrs) or any other hull work that might be accomplished with the engine out.
    I believe the owner's name is Jim (Drake?). He cautioned against a basic rebuild-kit type of job and suggested that it would lead to endless tinkering in such a tired, old engine. So I might not be looking at $2k, but it sounds like it wouldn't necessarily have to cost $15k either. Another guy I spoke with in Michigan over the summer said to expect around $1000/cylinder, which is consistent with Drake and Van Ness.
    Douglasville, Ga
    Quote Originally Posted by guillemot View Post
    10-15 hours
    $8000-8500
    Sounds like you are getting good advice and quotes from knowledgable people. That all seems pretty reasonable compared to a re-power and keeps the boat original. With the Boeing history (if documented) it seems like originality would be beneficial.
    If it were me, I would "repair" the engine to be within the original specifications. Those clearances or tolerances are worked out to last reliably within a working standard of maintenance. Generally this is about 4 or 5000 hours. If the engine has been well maintained it could be significantly longer.
    Most engine problems are age or maintenance related (gaskets, seals, piston rings and maybe valves and a camshaft. Given a running engine, a simple disassembly, visual inspection and measuring will tell everything. To simply surmise that "it needs everything" and replace it all to me seems silly, but it does make a nice profit for the man selling and fitting the parts.
    There are factory prescribed tolerances for every moving part and fit in that engine and if within those tolerances it is as good as it needs to be.
    It is simple; If it needs to be bored and new pistons fitted to have the correct clearances, you do that. If it needs pistons because the ring lands are worn, you do that. If it needs valves and guides, you do that. If it needs hardened seats to comply with modern fuel they can be installed, no big deal. This is not a competition or contest where "blueprinting" (making up your own tolerances) will gain a thing.
    The engine will not know the difference between gaskets, valves and pistons and seals etc. If the parts are listed for the application they are fine, in this case listed for "marine and industrial" applications or "continuous duty".
    To further what CanoeYawl said - when I redid the above-mentioned 283, I bought automotive pistons & rings (as I bored to .020 over). The pistons were purchased as part of an automotive rebuild kit from Summit Racing. They were literally 1/5 the price of Chris Craft ones & turned out to be the exact same brand that was installed in the engine. Plus - folks buying from a place like Summit are building far higher horsepower engines than this (relatively) low compression boat engine. The rebuild kit: 8 pistons with rings and wristpins, main bearings, rod bearings, cam bearings, full gasket set, and a timing gear/chain setup was about $200 including shipping. I did have to buy CC gaskets for a few things as they were different from automotive.
    While you may need marine-specific gaskets or possibly a camshaft or the like, most of the internals (pistons, rings, bearings, etc.) are no different from what's in your boat.
    Jul 2003
    Concord, NH, USA
    So.... I have rounded a corner. Although I started this thread to ask what new engine to install in the boat, it seems I'll be headed in an entirely different direction now. After pricing out new motors and speaking with several machine/engine shops, it looks like the old beast is going to get a second chance at life after all.
    I had good conversations about engine re-builders with Bo Muller (from Muller Boatworks in Sunapee, NH https://www.facebook.com/mullerboatworks/), Andrew Robb (North Country Boatworks http://www.northcountryboatworks.com/), and several other shops who specialize in varnishy old boats like mine. Their combined wisdom suggested that:
    (1) Re-powering will be the most expensive option,
    (2) Drakes is a very good shop and does excellent, show-quality work,
    (3) Van Ness is top notch as well but perennially backlogged, and
    (4) For my purposes, I should check out Portland Automotive Machine in Hollis, Maine
    I called Bob at Portland Automotive Machine. His shop is 1 hour from Phil Spencer's shop where the boat is (https://lakesregionwoodenboatsales.com/). He has rebuilt Crowns before and knows them well. He can take the engine about five weeks from now and have it back around New Years. He is going to do a total rebuild including, though not limited to:
    disassemble, clean, magnafulx to check for cracks.
    bore oversize as needed, sleeve if necessary
    replace all internals
    regrind crankshaft
    new bearings, pistons rings valves cam bearings, valve guides, replace valve seats on exhaust and most likely intakes, most likely valve springs
    new oil pump
    rebuild water pump, fuel pump, carbs
    timing gear, timing chain
    resurface all surfaces
    recondition transmission as needed
    detail all accessories and repair as necessary (starter, generator, etc...)
    repaint everything
    reassemble and test run engine.
    He says he can do this for around $5000, which is at least $3500 cheaper than the next guy. If I want, he can even leave the copper and brass bits shiny (though that might be a pain to keep up). Converting to 12V would be a big expense, as the generator would have to be re-wound, and all the other electrical components in the boat would need to be modified or replaced.
    This isn't as inexpensive as Garret's $200 rebuild, but I gather he put a lot of his own time into it. My time would be better spent on the wooden parts of the boat, or maybe doing my day job so I can pay this guy! I may even have enough left from my budget to have the gauges rebuilt! I bet it would be nice to have a functioning fuel gauge.
    ^^^ That's great Jeff. Sounds like the right direction to me. Looking forward to posts of your boat back on the lake again!
    Mine wasn't $200 - just the basic parts for the engine were 200 + CC gaskets, etc. Probably a total of a grand plus many hours of my time. I think the 5K you're being quoted for a complete job like this sounds very fair.
    That sounds very reasonable to me (both cost and time line) and sounds like a pretty thorough job. The only question I would have would be does he have a source for clutch plates if needed, and what would the cost for them be if needed.
    Six or seven years ago I rebuilt the mechanical reverse gear on what was basically a Chris Craft SBC marine engine I had. The clutch plates, pinion bearing shafts and gaskets ran me $750 then. I believe the internals of the two reverse gears are very similar.
    Jul 2003
    Concord, NH, USA
    My understanding is that clutch plates for these transmissions are fairly scarce. That point was raised by both this guy (Bob from Maine) and by Drakes (in Rochester, NY) and is a known possibility. Bob said the clutch plates are often fine and require only a little cleaning up, but he may have to source parts if they're badly worn, which may add some to the cost.
    The clutch plates for my gear were pretty much like “hens teeth” too. Just checking that you have your bases covered, and it sounds like you do.
    Sadly I think many of these motors and transmissions are just getting scrapped now. I see them come up on craigslist every so often. There are a two or three for sale near Seattle now for example. But they seem to sit for a long time and I don't know how many of them ever find a buyer. It would be nice to save the parts - even used wear items like clutch plates could be valuable if they still have some life left - but I don't see that happening.
    There do seem to be more still on the west coast, kind of odd considering many more probably started out in the east. I casually keep my eyes open for them (thinking spares for mine), and don’t see them often at all.
    It is a good call, I think, to keep the boat and engine as built.
    I would paint it as original, probably about like it was "dipped" in paint. Showing off and polishing the brass and copper bits is an affectation.
    Jul 2003
    Concord, NH, USA
    Hi all,
    I thought I'd post an update on my engine rebuild. I just got off the phone with Bob from Portland Automotive Machine in Hollis, Maine. He has the engine all apart at last and is getting ready to set to work on it.
    I haven't been to see it in person yet, but he reports that in addition to the expected general wear and tear on a high hour engine, I have a cracked water pump housing, at least 4 cracked piston rings, badly pitted and leaking exhaust valves, and some transmission trouble. Apparently the lower drive gear had slid up into the upper drive gear and worn itself and its teeth to bits. He tried to explain this, but I'm not sure I can quite visualize what this looks like. I guess I'll see it in a few weeks when I go to visit.
    On the bright site, he says the cam shaft looks good, so there's that!
    I'll post more when I know more.
