Results 1 to 13 of 13
Thread: Battery charging question
    Mountain lakes of Vermont
    Default Battery charging question
    I've got (2) 12 volt batteries wired in series to power my 24V electric motor. I've got an onboard dual battery charger. At present, I have one set of leads to one battery and the second set of leads to the second battery. I leave them wired in series as I charge and everything is fine.
    Here's my question. While still wired in series to 24V, can I just use one set of leads, hooking the positive wire to the positive pole on one battery and the negative wire to the negative pole on the other battery? Will this work? I know it would slow down charging time, but will it do any harm?
    The reason I ask is that I'd like to add a second set of batteries to extend cruising time and to simply have as a backup. It would be nice to use the existing dual battery charger for both sets of batteries rather then having to buy a second one.
    Thanks for your wisdom.
    Mar 2015
    Victoria BC Canada
    Default Re: Battery charging question
    No.
    Because a 12V charger won't charge a 24V battery.
    Oct 2006
    Livin' in the Golden Triangle
    I just bought this...
    Not overly expensive... and would solve your problem
    No.
    Right. You'd need a 24-volt charger to connect it as you propose. Check your chargers specs, some are 12/ 24 volts, so you may be able to use it.
    May 2002
    Deer Isle, Maine
    This may help... https://www.nyc-arecs.org/batt1.pdf
    Specifically, fig.10 and fig.12 on pages 7 thru 12.
    Thanks all. Very helpful info and my question has been answered. My best course of action is to buy another dual battery charger for that second bank unless I can find one that is will charge two 24V batteries.
    If they are deep cycle batteries (not just regular car batteries) do you want us to tell you how using an automotive battery charger is hurting them?
    How about how combining old & new batteries will quickly bring the new ones down to the same ability to hold a charge as the old ones?
    I know that using a regular ol' automotive charger isn't good for deep cycle batteries. So what should I get? My batteries are rather small: 12 volt, 35 amp.
    Thanks.
    I'm using an onboard battery charger made for deep cycle batteries. I also knew about the taboo of pairing mismatched batteries in series.
    Thanks.
    What kind of battery? Lead Acid, Gel AGM, Lithium?
    Good to hear Rich - just had to be a PITA
    I learned the old with new issue the hard way: at my old place, which is off-grid & runs off batteries & an inverter, I added 2 new $400 batteries to my 5 year old bank. Got an extra day+ cycle out of them at first & within a month or 2, it'd dropped to marginally better than before I spent $800.
    Sorry... they are SLA/AGM.
    NP - you knew - so it was obvious, right?
    Most batteries (except Lithium) should have a 3 stage charger: Bulk, Absorption, Float. However, many AGM do not want to be Floated (which is not done every time you charge anyway). What voltages for each stage also vary. Best thing would be to check with the manufacturer of your battery. Proper charging will keep the battery's capacity & (greatly) prolong its life expectancy.
