Results 36 to 58 of 58
Thread: Building a Wharram Hitia 14
    Oct 2017
    Bangkok, Thailand
    Default Re: Building a Wharram Hitia 14
    In this video I am glueing the stiffeners and deck supports to the bulkheads. I also have started stitching the second hull.
    Oct 2017
    Bangkok, Thailand
    In this video I am stitching the side panels of the second hull together. At the end of the video I am taking a look at the drawings to see how to stitch the bulkheads. I then discover that I have glued the stiffeners on the wrong sides on 6 of the bulkheads. So now I will soon discover how easy or difficult it is to remove the epoxied stiffeners and deck supports.
    May 2013
    I'm not sure if I understand the intended build process here. Anyway; The nice thing about using epoxy is that, if worst comes to worst, you can always just grind it off.
    Oct 2017
    Bangkok, Thailand
    In this video I am glueing the stiffeners and deck supports again on the bulkheads, but now on the correct side. I discovered this mistake a couple of days ago. I think I don't have to remove the incorrect ones, just remove a little bit at places where these wrongly placed stiffeners and deck supports are in the way. I also started making a stand for one hull.
    Aug 2017
    Melb, Vic, Aus
    Its good to remove any extra weight you can out of these little cats. Its surprising how quickly the little bits add up. Won't take long to plane them off.
    Oct 2017
    Bangkok, Thailand
    Thank you for your comment. I thought about it, and I agree with you. I will remove the wrongly placed stiffeners and deck supports to save weight and stick to the building plan.
    Oct 2017
    Bangkok, Thailand
    In this video I first clean up the workshop. Then I do some work on placing the stiffeners and deck supports on 2 bulkheads (again). I also assemble one of the stands for the hull. I use epoxy and some nails to keep it all together while the epoxy dries. Later I will add fillets to the stand to make it all stronger.
    Oct 2017
    Bangkok, Thailand
    In this video I am glueing stiffeners and deck supports on the bulkheads and I am adding fillets for more strength on the stands.
    Oct 2017
    Bangkok, Thailand
    In this video I am stitching bulkhead 3 and 2 in place in one of the hulls.
    Oct 2017
    Bangkok, Thailand
    In this video I stitch bulkhead 1 and 4 in place. Afterwards I am spatula's with 2,5cm radius out of thin plywood, which I will use for making the keel and bulkhead fillets.
    Oct 2017
    Bangkok, Thailand
    In this video I start with making the fillets for the keel. First I stitch and clamp the side panels to the sternpost which were still not together. I had to use clamps, because the copper wire that I am using is too thin to keep this part together. Next time I will use thicker copper wire. After that I tighten all the stitches. Then I lightly send the areas where the fillets will be and after sanding I use the vacuum cleaner to take the dust away. Then I start to do the filleting. The straight horizontal part goes very well. The stempost part that is at an angle does not go that well, there are several bumps in the fillet. I will try to sand that smooth tomorrow. It was a good day.
    Oct 2017
    Bangkok, Thailand
    In this video I am making the keel fillet between bulkhead 4 and 3. I am lightly sanding the areas where I am going to apply the fillets, then I clean the areas, then I apply a layer of unthickened epoxy and then I create the fillet. I am mixing epoxy in paper small cups so every batch I can make only a fillet of about 70mm. I tried mixing larger batches of epoxy, but with the paper cup size I am using and the temperature in my workshop I find that smaller batches work much better.
    Oct 2017
    Bangkok, Thailand
    In this video I finish making the fillets on the keel, sternpost and stempost of hull 1.
    Nov 2017
    Panama, Rep. of Panama
    Hello,
    ....I don't see you applying any glue/epoxy in the stitching areas (bulkheads/sternpost/bow to the sides). Are you counting only on the fillets for the gluing and force transfer??
    Oct 2017
    Bangkok, Thailand
    Quote Originally Posted by thjakits View Post
    Hello,
    Hello Thjakits,
    Normally I apply a layer of unthickened epoxy first at the places where the fillet will be.
    I have forgotten to do that at a few places. In the beginning of the video you can see I did apply some unthickened epoxy with a brush at several places. But at some other places I have not applied unthickened epoxy first.
    Thank you for pointing this out to me. I will do it and show it clearly in next videos so that other people do not make this mistake. Thank you.
    Nov 2017
    HI again,
    ... I think I did not get my question across correctly: (I don't have any Wharram plans, so I don't know what/why is their standard construction procedure...)
    I wonder(ed) about the stitch line itself - where the wooden parts touch - is there no glue going there, BEFORE stitching?
    Is the join held together just by the glue in the FILLET? Or is the glue (...or supposed to) seeping into the stitch-join area?
    Good luck,
    thjakits
    Oct 2017
    Bangkok, Thailand
    HI again,
    I wonder(ed) about the stitch lone itself - where the wooden parts touch - is there no glue going there, BEFORE stitching?
    Is the join held together just by the glue in the FILLET? Or is the glue (...or supposed to) seeping into the stich-join area?
    Good luck,
    thjakits
    Hello thjakits,
    There is no glue before stitching. And because there is no glue, you can adjust the postion and shape by pulling the stitches tighter or by loosening the stitches.
    The glue/epoxy is supposed to go all the way into the stitch join area, having no gaps or air within.
    Thank you,
    Kindest regards,
    Marcel
    Oct 2017
    Bangkok, Thailand
    In this video I am making the fillets on the bulkheads of one of the hulls. The more I practice the better the fillets get. It has been more than 10 days since the last time I uploaded a video. I have been to Yangon, Myanmar for a couple of days. If you like to see a video about that trip, you can find it on my other channel: https://www.youtube.com/channel/UCVV...0J1lozDZy1EsjA
    Oct 2017
    Bangkok, Thailand
    I start with a clean up of the shop. Now I am going to see how to fit the fore and aft deck. While I am looking at it I am thinking of doing some work to make it all look better, even though most of it will not be visible once the fore and aft deck are epoxied in place. I am also thinking about sanding everything inside another time with 80 grit sandpaper and apply a layer of epoxy. While I am removing epoxy and pieces of deck support that are wrongly places I notice how strong the epoxy bonds and fillets actually are. I use my wonderful Japanese chisel to remove the wrongly placed deck support. The end result looked very nice, but I can’t show it in this video, because the battery of my camera was empty.
    Oct 2017
    Bangkok, Thailand
    In this video I cut out a notch in the fore deck panel where the stempost will fit. I also removed another deck support that I had epoxied in the wrong place.
    Oct 2017
    Bangkok, Thailand
    In this video I first move the stands so that the boat is standing more stable while I am working on it. You will also see that I started sanding everything. The building plans don't tell to do this, but I want to inside and especially the fillets looks better, so I decided to sand everything smooth and then apply a layer of unthickened epoxy and at some places touch up with thickened epoxy. I am especially not satisfied about the looks of the stempost fillet, so I will try to make it better. After that I am drilling 12mm vent holes in bulkhead 1,3 and 4. These holes are sanded and will also get a layer of epoxy. I am also fixing then deck stringer to the fore deck. The method is to first drill a few holes so that the stringer can be stitched and kept in place. After that I put a layer of unthickened epoxy at the place where the stringer will be and then I put colloidal silica into the resin and hardener mix and apply this to the stringer. After it is in place and stitches tightened I put some nails into it to fix them.
    Oct 2017
    Bangkok, Thailand
    In this video I am doing some sanding and cleaning in preparation for making the fillets and panels look much better. Most of this will not be visible later, but I still want to do it, because I am learning a lot about the materials and methods that I am using. I am feeling so good when I am working on my boat.
    Oct 2017
    Bangkok, Thailand
    I did not do so much today. I just cleaned up the sanding dust again and fixed the aft deck stringer.
