Results 1 to 35 of 47
Thread: Cutting a clean hole in metal cargo trailer side
    Texas
    Default Cutting a clean hole in metal cargo trailer side
    Good morning friends
    I want to install a couple of windows and hatches in my cargo trailer. Whatís the best way to cut a clean, neat hole in the metal siding? I was leaning towards buying a rotozip with a metal bit. Iíve seen it done with a sawzall but seems like that would be pretty sloppy, at least in my hands.
    Pretty thin stuff. Iím almost tempted to try a carpet knife or dremel.
    Thanks
    Aquitaine
    Default Re: Cutting a clean hole in metal cargo trailer side
    What we call a jigsaw, but over there, a sabre saw, with a metal cutting blade. Best if it has speed control, to avoid overheating the blade, but a spray of WD40 helps the cut.
    I cut some windows in the back of a Renault van this way. Prob about .8mm steel.
    Mar 2006
    Northern NY
    Flat surface? Maybe a plywood pattern for a small diameter router bit with a pilot bearing?
    I want to install a couple of windows and hatches in my cargo trailer. What’s the best way to cut a clean, neat hole in the metal siding? I was leaning towards buying a rotozip with a metal bit. I’ve seen it done with a sawzall but seems like that would be pretty sloppy, at least in my hands.
    Pretty thin stuff. I’m almost tempted to try a carpet knife or dremel.
    Thanks
    Steel or Aluminum?
    Rattling the teacups.
    Jan 2012
    Sequim, Washington
    Thanks
    Plasma cutter!
    Just joking! back up the thin sheet metal with thin scrap ,plywood to keep it from getting ripped, then use your sawzall.
    PaulF
    Aquitaine
    Quote Originally Posted by paulf View Post
    Plasma cutter!
    That crossed my mind too, as I have one. But I assumed the OP does not? (if he did, doubt he would bother asking here)
    Using a router makes my skin crawl if in steel. OK in ally.
    Texas
    Yes, flat surface. And aluminum. Iíll see if harbor freight has a sale on plasma cutters (chuckle).Thanks all.
    Aluminum scores very well:
    Isle of Mull, Scotland
    Nibbler- probably called something different in the US.
    Quote Originally Posted by birlinn View Post
    Nope. They're called nibblers here, as well, but if you want straight lines, the double-cut snips are better.
    Not too good if you want a radius on the corners.
    Jan 2012
    Sequim, Washington
    That looks like a great tool! Do they make them in a power/ battery version?
    PaulF
    Jan 2012
    Sequim, Washington
    Bingo...$50.00 Eastwood.
    PaulF
    Northeast
    They also make a nibbler attachment for drills, IIRC. (https://www.amazon.com/SHEET-METAL-N.../dp/B0043RHHN4) No personal interest.
    -William A. Ward
    Dec 2009
    Frankfort, MI
    I'd use a sawzall with the proper blade, along with a steady hand. A little cleanup with a hand grinder might be required to get a nice edge, but even a dreamer tool would make an easy job of that.
    As someone mentioned, backing up the area with plywood will make for less noise and other drama...
    Jeff C
    You don't need to back up with a nibbler.
    I have used the drill attachment type a lot on aluminium car bodywork- works fine, but you don't half get a lot of crescent shaped swarf.
    Jan 2012
    Sequim, Washington
    If I'm envisioning this right the bulkhead is sheet metal over wall board with thin insulation and inner wall board. More than 3 layers at around 2.5" thick including back up thin ply.
    I'd cut 2 holes with a hole saw at opposite corners then use a sawzall and do the thing in one pass.
    PaulF
    Too far inland.
    Jigsaw. The little bit of distortion it might create in the metal will certainly be within the window/hatch frame's ability to manage.
    Bainbridge Island WA
    One of these days some of us would like to see pictures of this deluxe trailer you are putting together.
    This is what I think of when somebody asks about a nibbler for sheet metal, goes around curves better than shears.
    R.D Culler
    Jan 2012
    Sequim, Washington
    For real fun!!! Det cord!
    https://youtu.be/VK0WYJ6tG78
    PaulF
    Det cord...
    Too late by a minute!
    I have the Milwaukee version, it would be perfect for this application.
    Jan 2012
    Sequim, Washington
    Det cord...
    Great minds think alike...and so do ours!
    PaulF
    ibeeria
    115mm angle grinder and 1mm cutting disc you can get 0.8s but you'll get through them a bit quick, cheap and fast and if you don't have an angle grinder you can pick up one for about euros 20 pounds beertokens of your choice.
    I have cut a lot of sheet metal using a skill saw with a fine carbide tipped blade, just sayin'
    We need to learn if this is a hole with square corners, or what...
    Texas
    Thanks for all the good options everyone.
    Not much to show yet. Very limited time outside in the heat.
    I cant seem to find a photo on my phone. This is how it looked when I got it.
    http://forum.woodenboat.com/showthre...-cargo-trailer
    I have taken all that out to insulate it properly. My AC guy recommended against the mini split because of the rough treatment the unit will receive. The 5000 btu AC was too small when I tested it. I have moved up to a 10,000 btu soft start unit. It passed the testing with the little costco inverter generator this morning.
    It is a pretty big unit. Air supply and venting it out the floor is going to take up too much limited real estate. I ordered an large RV cargo hatch off ebay today and plan to mount the AC on a sliding tray out the side. Push it out and done.
    Thanks again.
    Nov 2001
    Germany
    There are cutting discs with fast change adapter for the Dremel. I use them from time to time and they should work for this application. Mind you - I had one bursting into two parts recently at pretty high rpm after giving it some heavy use, so, make sure you wear goggles and do not put your head in the spin plane.
    https://www.conrad.de/de/dremel-spee...et-816444.html
    Apr 2007
    Caribbean cliff edge
    Post a pic on here of the job before, during and after.
    Enjoy a good rum on the rocks at sunset.
    Sep 2002
    I have a very similar one to that, run it on my 18 volt cordless to trim iron roofing and such. Great thing, not perfect but a lot better than snips.
    John Welsford
    Jul 2008
    Tacoma, WA
    Cargo trailer? Is it plywood with sheet metal on the outside?
    Sabre saw would be best. Less heat than a grinder. If it's aluminum clad, just use your circular saw.
    IMMIGRANTS BUILT AMERICA - IMMIGRANTS BUILD AMERICA
    Pleasant Valley NS Canada
    Too much tool porn here, guys. And PaulF, comments like yours is what got you elected to BROTM! <grin>
    It's just thin aluminum sheet, fer gawd's sakes! I helped build a 42-ft cargo boat using Craftsman circular saws, drills and jig saws, built using plates up to 3/4" thick.
    Mark the corners of the panel to be cut out, then put heavy masking tape over the area to be cut; mark the cut-out line. Drill a hole big enough to insert a jigsaw (sabre saw) or sawzall blade through (if you want four square corners, drill a hole on each side and cut to the corners; if small-radius rounded corners are desired, drill the starter holes in each corner), and cut he panel out using a carbide blade. Sand the rough edges with 80 or 120 grit emery paper. If you want to be really anal about cutting a straight line, use the jigsaw only and apply a set of guides (1/4" x 1-1/2" lath works well) to the panel - with appropriate off-set to accommodate the jigsaw shoe - with double-sided carpet tape and run the jigsaw along the guides to get a really straight line.
    Done.
    Wear a full face shield and glasses if you use a circular saw, or you may be pulling pieces of aluminum through from the inside of your cheeks.
    Bass Harbor, ME
    Ah come on guys, you are taking the fun out of it - chainsaw with carbide chain.
    Jan 2012
    Sequim, Washington
    Especially if you use the Det-Cord! Ya make it easy mmd!1
    PaulF
    You definitely want to cut it, grinding malleable materials with a stone or disk is not a good idea.
