Results 1 to 16 of 16
Thread: Half of one engine running hotel
    Long Beach CA
    Default Half of one engine running hotel
    Good morning. Iím at my wits end. I have twin v8ís. One hundred percent raw water cooled.
    Half of my port engine is running substantially hotter. Iíve replaced circulating pump. Replaced pump impellers on raw water pumps. New manifolds and elbows and hoses. Donít think itís a head gasket no water in the oil. Any ideas?
    Default Re: Half of one engine running hotel
    Some of the waterways clogged with salt, mud and possibly rust.
    Pleasant Valley NS Canada
    Possibly an obstruction in the internal coolant passages in the head. How long since the engine cooling system has been flushed?
    When I took my raw water cooled 283 apart, I found amazing amounts of blockage. Ended up having the block boiled - but still had to manually clean up passages going to the heads.
    The old boys around here used to boil the head and calender blocks in washing soda.
    Replace the thermostat.
    Try a different Hotel
    Montana USA
    Must be a small hotel...maybe one of those "boutique"ones...
    Long Beach CA
    That too replaced. only left 1/2 of the engine getting hot.
    Mar 2006
    La Conner, WA
    I am guessing that one of the risers from the manifolds is plugged and not passing exhaust water, it should show a lot hotter temp from an infrared temp sensor.
    Long Beach CA
    As stated in the opening post. Raw water cooled. All manifolds and elbows changed out.
    What is the engine?
    Is it a Mercruiser? The exhaust flapper installed in the downtube/ Y tube on that side may be installed backwards, retaining exhaust gas.
    Mar 2001
    FL
    Assuming full water delivery is getting to the engine...Pulling a head off will likely hint whether its a debris restriction or salt buildup. I'd guess crystallized salt in the water passages. If so, you could try running oxalic acid though it without much effort or cost. Oxalic will dissolve salt and not harm the other parts. I've done it on two gas sailboat engines with ok results. Get the engine warm. Disconnect the raw water intake end and put the end into a 5 gal bucket of oxalic acid...powder or crystals mixed in water. Suck the bucket down and shut the engine off with the block full of that water. Let sit overnight and do it a couple times. It may help and you will be amazed how much crud comes out the exhaust.
    You have mentioned replacing both the circulating pump and the impellers on the raw water pumps. This implies something other than "raw water cooling".
    The symptoms described indicate little or no coolant flow on one side of one engine.
    A diagram of your specific setup can likely be found online.
    RI ,USA
    A friend of mine had that issue on a 350. Turns out the riser or manifold ports were way undersized by design. He reamed them out some how, he may have eventually replaced them. They were clogged with rust
