Results 1 to 16 of 16
Thread: Winch ID help and disassembly
    Oct 2017
    Johnstown, Colorado, USA
    Default Winch ID help and disassembly
    Hi everyone first post and sorry it will probably be easy for someone with experience.
    What brand of winch on this boat and any info about maintenance would be appreciated. They don't spin smooth so will need a cleaning. Boat is a 1974 Columbia 23.
    I do not see any markings to ID it.
    Thanks
    Ryan
    Apr 2017
    Kailua, HI
    Default Re: Winch ID help and disassembly
    Hello and welcome!
    Those look like the old South Coast (and others) from that time. Looking down from the top, you should see a big, wide, giant, straight screwdriver-like slot. The winch handle end engages the big screw, (counterclockwise turns) and out it comes. Solvent clean, regrease, and off you go. If you've no handle, you'll have to fabricate something to engage the slot (steel flatbar, etc.)
    Oct 2000
    Padanaram, MA USA
    With old winches, parts are VERY hard to find and losing any part probably means the end of the winch.
    Before opening up a winch, tape cockpit and deck scuppers and keep the parts contained in a box of some kind. A plastic dishpan makes parts cleaning easier.
    Oct 2017
    Thank you for the help with the ID and MX recommendations. I will give that a go and keep an eye out for any parts sense they are hard to come by.
    Thank you again.
    Ryan
    Aug 2015
    Midcoast Maine
    Beware of springs and pawls flying out as you lift the drum. A partner to cup their hands around the base while you lift may help.
    "Where we would wish to reform we must not reproach." -Thomas Paine
    I had a plastic pan with a circle cut in the bottom just big enough to fit over the winch. I'd tape it to the coaming around the winch. Hit on that after pulling a drum off and hearing a feint ping followed by a tiny splish.
    Jun 2018
    Los Angeles CA USA
    Ouch. I made Barient winches for a while, there's nothing too difficult inside them. If the winch is worth anything to you, I wouldn't throw it out over missing parts. A decent machine shop should be able to replicate anything inside them.
    Agree with you it's much better to not lose the parts in the first place
    Oct 2017
    Thanks everyone these are great and helpful tips. Ill Give that a try to make sure not to lose any components. I'm hoping the interior is just in need of a cleaning.
    Aug 2016
    Brooklyn, NY
    diesel fuel was the recommended solvent,
    last time i rebuilt some lewmar winches...
    bonus that it's cheap too !
    Oct 2017
    Ill let you know what I find out. I have researched the winches but not sure I have found the exact ones. Mine seem to have a taller top piece for the winch handle then what I see on merriman, barient, barlow, southcoast... Perhaps mine is even older than I think.
    May 2005
    Bradford, VT
    IIRC, my SC winches had pawls with a little slot cut in them, transverse to the axis of the pin on which they swiveled. The springs also encircled the pin. I lost one spring upon disassembly (as recounted above) but made a functional (for years) replacement out of some SS leader wire.
    Good luck
    Aug 2016
    Brooklyn, NY
    noticed a winch similar to yours on ebay:
    wilcox-crittenden 'marinium'
    aluminum, i guess ?
    Oct 2017
    Yes that is definitely it thank you!
    Grind an end of the handle to fit the big top screw!
    I just pulled one of then off my mast last year after tensioning my topsl hlyd for 30 years.
    Rugged and simple, things not very valued anymore.
    (I upgraded to a Murray)
    Mar 2001
    FL
    The good news is you will probably find they only need cleaning and lubing.
