That is what I really want to do. Right now it has an old 80 lb. thrust motor that is used for both propulsion and steering. I'd like to replace it with a twin 80 lb. (160 lb. total) thrust pod that MinnKota makes for mounting on outboard motors. It would fit perfectly on my skeg and I would add the rudder from the original design. The rudder post could go up the same tube that I used for the trolling motor.
However, I spoke to MinnKota and they don't recommend the motor for main propulsion. It could be that MinnKota is just covering their butts by saying that the motor is meant for auxillery use only. Plus, the battery drain would limit cruising time. Right now, I have one set of batteries, but the boat is wired for another set, which I would add. That said, I generally don't go out for more then a couple of hours anyway. I have also seen several boats that use a trolling motor for main power, including one that is commercially built.
Another drawback of the trolling motor is speed. They are built to push a big boat slowly. At present, I get a top speed of 5.5 mph at full charge. After an hour of cruising at 4 mph, my battery is down 25%, but I can still get 5mph if wanted. Doubling the power would not double my speed. I'm thinking a new top speed of about 7mph. Hull speed is around 6mph with my 16' waterline and 4' waterline beam.
I have experimented with RC plane props and get a bit more speed and range, but they are fragile and I have no way to replace one out in the middle of the lake if it broke. With the inboard, speed would be no problem.
The bright side with the MinnKota pod is ease of installation, low cost ($1,200) and I don't have to mess up the woodwork in the cockpit.
So, it's either that or go with the inboard, with which I'd have more power then I'd ever need or could use.
Decisions, decisions. The much more expensive inboard option would be much harder to get past my wife.
I'm trying to hold onto my money to pay for our daughter's wedding next June. I suppose I could buy the expensive motor and hold her wedding reception in the basement. I'm sure she'd understand....
