Results 1 to 3 of 3
Thread: Water Heater: What Material?
    May 2007
    Seattle
    Default Water Heater: What Material?
    I am replacing the worn out water heater on my boat with a new one. I heat water with the engine and electricity.
    The replacements have either a stainless steel exterior or one of galvanized metal. The latter is cheaper.
    Is it worth it to pay for the stainless?
    Elect a clown expect a circus
    Default Re: Water Heater: What Material?
    Stainless is prettier. Does the cheap external suggest inferior internal componentry? I'd imagine the cost differential of a stainless exterior compared to galv would be negligible, and the real,savings have been achieved elsewhere. But that's just a WAG. The Chinese use stainless like it's going out of fashion. So I'd be checking out the detail if possible before deciding on price.
    Apr 2018
    London, UK
    Although galvanized aluminum water heaters cost a lot less than stainless lined water heaters, they can actually cost a lot more in the long run because the only cure when the galvanizing starts to wear off the inside of the tank is a new water heater.
