Results 1 to 10 of 10
Thread: Building a Hybrid Moonfish
    Mar 2018
    Annapolis, MD, USA
    Default Building a Hybrid Moonfish
    Our summer vacation fleet needs something that sails to complement the outboards, canoes and kayaks already on hand. So Iíve started building a Bateau.com MF14 Moonfish. The Moonfish is a tape-and-glue small plywood sailboat, similar to a Sunfish. The objective is to have her ready by this time next year.
    Sheíll be joining a fleet that features cedar strip-plank boats. Thatís where the ďhybridĒ comes in. Instead of ply, this Moonfish will have cedar strip topsides and deck. Iíll be using versions of the strip building techniques described by Schade, Folsom and others for kayaks and canoes. Topsides and deck will be finished bright.
    A few prior Moonfish builds have been well documented online here:
    https://forums.bateau2.com/viewtopic.php?f=13&t=20214
    Here:
    https://forums.bateau2.com/viewtopic.php?f=14&t=58206
    http://forum.woodenboat.com/showthre...sh-Build-in-UK
    And thereís another underway here:
    https://forums.bateau2.com/viewtopic.php?f=13&t=62869
    Iím indebted to those builders for pre-answering many of my questions and offering lots of good ideas. Now I get to make my own mistakes, of which Iím sure there will be quite a few.
    My sole prior experience in boatbuilding was a stitch-and-glue rowboat about 20 years ago. Iíve been planning this build since January, waiting for the weather to warm up and my daughter to get her stuff out of our garage. Thatís given me plenty of time to overthink everything. This certainly wonít be the fastest or most economical way to build a Moonfish. But itíll be fun! So here we go Ö
    Mar 2018
    Annapolis, MD, USA
    Default Re: Building a Hybrid Moonfish
    Bateau.com offers a CNC-cut kit for all the plywood pieces, but I couldn’t see ordering the kit only to throw a considerable portion away. So I’ll be cutting the plywood myself. The experience is good for me, right?
    There’s a boat in here somewhere:
    Mar 2018
    Annapolis, MD, USA
    Hey, look, I found a transom!
    Jan 2007
    North Shore, Massachusetts
    Quote Originally Posted by Chenier View Post
    thanks for sharing, sun fish are awesome.
    Dec 2011
    North East England
    Mar 2018
    Annapolis, MD, USA
    Here's a visible sign of progress - the frames are all cut and trimmed.
    Lightening holes, ventilation holes, limber holes and drain holes will all be cut later, after I assemble the parts and see where the longitudinals intersect the frames.
    Those longitudinals, the stringers and trunk sides, are next at bat.
    Mar 2018
    Annapolis, MD, USA
    The longitudinals are cut and trimmed. Bow and trunk sides on the left, aft stringers on the right.
    There are two trunk sides and two aft stringers - the pairs were cut stacked so that both sides of the boat would have the same mistakes. The boatbuilding literature calls this "symmetry".
    Mar 2018
    Annapolis, MD, USA
    I tackled trunk/bow stringer assembly. This is a slight departure from the build notes which would have me lay out the deck next. As you can see from the photos my garage shop doesnít have a lot of extra room, so Iím doing as much as I can before erecting a big 4íx16í worktable.
    Here Iíve cut cleats for the mast step and daggerboard from cypress and added lightening holes to the big plywood parts. The lightening holes are partly to save weight but also to allow some air circulation during the months the boat will be in storage. The build plans say ďRespect minimum 2Ē offsetĒ for lightening holes in the frames. That seems like a good guideline. In addition Iím keeping 2Ē between holes.
    Kindly ignore the limber holes some idiot cut on the deck side of the stringers. Thank you. The working limber holes are on the hull sides of these pieces.
    Next is a dry fit of the assembly. It took a while to get everything square and clamped into position. Then I drilled through at each of the cleats and pegged the assembly with 1/4Ē red oak dowels. That holds it square and let me put each component exactly where it belonged when epoxying.
    This photo is the way the whole structural frame gets built - upside down on a flat deck.
    The epoxy step was a bit of a mess, in part because the last time I fooled with marine epoxy was about 20 years ago. Iím trying out SilverTip because the manufacturer says you can let it sit for 72 hours before needing to sand when putting more epoxy over it. Everyone else says 12 hours - even the same manufacturerís other brand of marine epoxy.
    Before assembling everything I coated the inside of the trunk sides with epoxy so I wouldnít have to get into that slot later. Then came a small frenzy of epoxy gluing and fiberglassing. There was enough play in the structure that the final piece, the starboard trunk side, might not line up with the dowels if the epoxy set firm. Fortunately, using slow hardener, there was enough flexibility after 1.5 hours to get that piece in place and then clamp everything:
    In this photo the deck side is up.
    The Build Notes say to fiberglass inside of the mast step and inside the daggerboard slot. I used the method recommended in Gougeon Bros. book: Lay a piece of fiberglass around three sides of the hole. Apply a second piece to the fourth side, then close up the assembly. In retrospect it would have been much easier applying the glass as four pieces - one for each side of the hole. Except for the bow side of the mast step, all the glass could be applied to its appropriate component the day before. Live and learn.
    Mountain lakes of Vermont
    A nice operation you've got going there.
    Mar 2018
    Annapolis, MD, USA
    Itís been a while. Spent the rest of the summer and early fall using and repairing other boats. Now itís time to get back to the Moonfish!
    In this phase Iím working on the long, skinny parts. The 24-inch wide worktable is extended to 15 feet for cutting the side and bottom panels. Iíve also built an overhead storage rack to hold said long skinny pieces out of the way until the build is ready for them.
    Side panels were next up. As mentioned earlier these will be ďstrip builtĒ: made of 1/4-inch x 3/4-inch cedar strips edge glued together. Later in the build these will be sandwiched in 6-ounce fiberglass and epoxy. This is the ďHybridĒ in the Hybrid Moonfish. Some kayak and canoe builders use this technique to produce compound curves and stunning designs. Iím using it just for the looks. That gives me some leeway in how I do the strip build. While borrowing heavily from the strip builderís toolbox Iíll take advantage of the fact that the Moonfishís deck and sides start life as flat panels. The deck stays flat while the side panels take a simple curve in one dimension (the long way.) Iím building these panels flat and will bend the sides into place later in the build.
    The strip builders construct their craft on molds spaced one foot apart. Iím in no position to argue so I set up MDF molds with that spacing. Rather than using staples or hot glue to conform my strips to a curve, Iíve set up each mold as a little panel clamp to keep the panels flat.
    The strips themselves were obtained from a supplier of strip-built kits so I didnít have to cut them myself. These are flat panels therefore no need for bead and cove. Since the strips are only about seven feet long Iíve joined them lengthwise with scarf joints. Theyíll need to hold together when bent onto the side of the boat, so 8:1 scarfs. Strips are glued together one at a time with TiteBond, the favorite glue of strippers. In the above photo the eighth strip was just put in place. You can see the extra clamps for a scarf joint about half way down the table. The tape between molds helps compress the strips together - TB doesnít like gaps. After an hour the tape and clamps come off and another strip gets added.
    In theory if one were a perfect craftsman there would be no difference between the panelís two sides. But Iím not such a craftsman so thereís a distinct difference between the side I can see while Iím building and the side I canít see. Therefore the side I canít see becomes the ďinsideĒ to hide my sins. Hereís the port side panel all glued up:
    Then I reversed the molds to glue up the starboard side.
    Once both sides were glued I stacked the panels back-to-back and taped them together so I could cut them as one. Here Iím laying out the curve of the bottom:
    Et voila! Two side panels.
    Thereís a bit of scraping and sanding in my future to knock off the squeezed-out glue and fair the surface...
