Page 4 of 4 FirstFirst ... 34
Results 106 to 119 of 119
Thread: Homemade tools and knives.
  1. #106
    Shubenacadie NS
    Default Re: Homemade tools and knives.
    Below are three pictures of the progress on my workbench so far. I hope to get it nearly done tomorrow. I cut two tapered housing dadoes in the front apron and then loosely assembled it. There are wedges that hold it together. Tomorrow I hope to cut the back apron housing dadoes and bolt the aprons on so I can glue the bench top in place.
    Housing Dadoe:
    Loosely assembled bench:
    And a picture with the vise sitting about above where it will be in the bench once complete.
    -Henry David Thoreau-
  2. #107
    It worked! They all came in upside-down Nice slick, Paul! I'm highly jealous of your anvil!
  3. #108
    That posted correctly.
    Scot what gives with the inverted images ?
  4. #109
    Sep 2011
    New jersey
    Looking good. I recently built the Moravian Bench. If your thinking tail vise, the Lee Valley Veretas Inset Vise is very useful. More robust than it looks and quick to install. Needs some dog holes. Rockler has wheels you engage with pedal, four for $60.00. They work good and handy for a small space.
  5. #110
    Shubenacadie NS
    Wheels might be nice on the bottom of it and foot pedal engaged ones sound great. No tail vise for me. Maybe later but for now no tail vise.
  6. #111
    Not the fine craftsmanship shown elsewhere on this thread, but immensely useful. Lapstrake clamps from scrap 2x4s and a floor fitting from 4" ABS with wheels from an old bed frame for the 4" dust collection. Note the nylon washers under the wing nuts. They make it much easier on the fingers.
  7. #112
    Sep 2011
    New jersey
    I think it was Norm, not that Norm, who said you can never have enough clamps. I’d have no use for them but I still want some. That washer is using the old noggin.
  8. #113
    Quote Originally Posted by Boater14 View Post
    If you look carefully at the red cedar one on the right you can barely see that it has a big plastic knob nut. That's way better.
  9. #114
    Clamps ? Here's a shot of one of my lapstrake clamps, I turned up a little gizmo to fit over the butterfly nut so I can do them up easily, quickly and hard.P3290115.jpg
  10. #115
    New westminster BC
    My home made bending iron. Made from a spent propane cylinder with the top cut off and mounted with a 100w lightbulb inside. Works well on stock up to 3mm thick. A crude but effective alternative to the $295 one offered by StuMac.
  11. #116
    Madison Wisconsin
    One of the very early issues of WB had a lap clamp that was one hand, cam operated and called a Brenne Clamp. I keep meaning to make a couple, just because they're cool, but haven't gotten around to it yet.
  12. #117
    Oct 2006
    Livin' in the Golden Triangle
    A simple solution to a very hard to reach pipe joint. Instead of dismantling half the car, we tacked a cheap socket onto a cheap spanner.
  13. #118
    Oct 2006
    A $25 seal puller, modified on a grinder to do the valve shims on my M5. A genuine tool was priced at $400 at the time.
    Homemade layup / welding table. Drilled and tapped for hold-downs. 3/4" thick steel, 4' diameter.
    Homemade device for peening heads onto copper rod to make bolts for the boat
    That valve shim tool again, on top of some home-made bush and bearing pullers... allowing home renewal of all the suspension bushes and wheel bearings on the M5
  14. #119
    Aug 2013
    S.W. Florida
    Have you seen Vince's site, Frayed Knot Arts (LINK)?
    Some fine stuff there!
    Custom Knives & Tools (LINK)
    Custom Spikes (LINK)
    #include [ std-disclaimer ]
    with what pleasure, what joy,
    Ithaka, by Cavafy
