Results 36 to 70 of 70
Thread: I want to build a boat that does not cost $7,500
    Jan 2007
    North Shore, Massachusetts
    Default Re: I want to build a boat that does not cost $7,500
    the Vacationer is around 20' the weekenders closer to 16'
    I don't recall reading any impartial reviews of those in terms of sailing qualities.There seem to be two schools of thought,those who are happy to have built something that looks salty and those who think they are poor sailors with a very limiting stability curve.
    Is there nothing from the catalogue of Francois Vivier or our own John Welsford (designer of the Scamp) that would appeal more?
    Aug 2015
    Santa Fe NM
    -The Dude-
    Aquitaine
    I have the feeling that with a few mods, like building a box keel which could hold water ballast and a smaller self bailing cockpit the weekender could be a very capable and fun little craft.
    Or, build a design that doesn't need sorting out to make it good.
    Tuscon AZ
    I like this PILGRIM boat!
    Dec 2011
    North East England
    Quote Originally Posted by donald branscom View Post
    That picture is not a Pilgrim it is a Rogue,
    http://www.duckworksbbs.com/product-p/jw-rogue.htm
    The bench setup looks a tad strange to me, I don’t like getting that close and personal with my crew, unless it is in a blow and I want them to shield me from the spray. Not sure if putting a forward bench for the crew and then their weight up ther would affect the balance.
    Sounds like your getting more of an idea what you want.
    Aug 2015
    Santa Fe NM
    Thanks for the correction Tink. I was looking at both the Rouge and the Pilgrim. Both good options. The Rouge for lighter weight and the Pilgrim for more stability.
    Pilgrim below.
    -The Dude-
    Tuscon AZ
    [QUOTE=Daniel Noyes;5551388]I have the feeling that with a few mods, like building a box keel which could hold water ballast and a smaller self bailing cockpit the weekender could be a very capable and fun little craft.
    I really liked the video of this WEEKENDER smoking along on a beam reach! WOW>
    Makes the scamp look very slow like a duck bobbing around.
    northwestern Wisconsin
    Scamp is a much faster boat than you seem to think. I've been aboard a Scamp that was outsailing a 21' Sea Pearl to windward.
    A simple Sharpie - maybe one of Raoul Parkers designs. http://www.parker-marine.com/
    They'd be relatively inexpensive to build and then you could beauty it up as far as your budget would allow.
    Dec 2011
    North East England
    The speed of any boat of this type is constrained by physics. Any displacement boat will only reach 1.23 x SQ LWL (ft) > knots.
    If and how she reaches this speed will be controlled by sailarea, displacement, the foils, the form of the boat, the ability to use all her sail power - stability, and many other factors
    Ben Ainslie and Jimmy Spithill racing two scamps will not get a Scamp to go much over 4.2knots without the aid of waves.
    The Sea Pearl 21 is perhaps not the best boat to look at performance wise. Sail area wise it seams underpowered and the leeboard has always looked a tad small to me and will not be as effective as the Scamp’s relatively large foil deep under the boat.
    I have probably upset both the Scamp Camp and and Sea Pearl posse but I think when advise is sought we should try and represent facts
    Where LWL not known I have assumed and stated the length I have used
    Scamp LOA 11’ 11’ sail area 100 sq ft Hull speed 11’6” = 4.2 knots
    Sea Pearl 21’ sail area 136 sq ft Standard rig Hull speed 19’= 5.4 knots
    Weekender LOA 19’6” LOD 16” sail area 120 sq ft Hull speed 15’ 4.8 knots
    Pilgrim LOA 16’ 5” sail area 162 sq ft
    That's a good general rule (but it's 1.34 x square root of waterline), not an absolute speed limit. You can exceed hull speed to some extent in a displacement hull, it's just that the energy demands to do begin to rise very steeply around that "speed limit."
    So yes, a Sea Pearl is "faster" if you mean it has a higher theoretical hull speed. But so many other factors go into what "faster" means in real life--VMG, pointing ability, leeway, etc. There's also length/displacement and sail area/displacement to consider. Lots of factors.
    I'm not claiming Scamp is a racer, or that it's fast in any absolute sense, though. No sailboat is.
    Dec 2011
    North East England
    Yes 1.34 you are correct, coffee wasn’t working yet. There are many factors but water line length is a very good starting point. As I said the Scamps boards are good for VMG etc. I didn’t get into displacement as it is hard to compare with figures available on the net and in boats like this crew and gear are a significant part of the displacement.
    Tuscon AZ
    this boat does not cost $7,500.oo...
    I think it is more like 7.5million.
    Tuscon AZ
    Thanks TINK for working up those figures.
    The Scamp is cute but the weekender is a bit pretentious.
    I am thinking, which boat is safer in a rough sea?
    I was in my flat bottom steel 30' boat that got knocked down in a gust in SF bay, but a full keel boat also got
    knocked down at the same time. I saw its bulb keel come up out of the water!
    Mar 2002
    Duncan, Vancouver Island
    I wouldn't want to be in either in a rough sea. But if I had to I'd take my chances in a Scamp.
    Jan 2007
    +1
    I'm with you all the way on that one J.D. SCAMP ... unless the Weekender had the mods I mentioned above, and possibly beef up the Mast/ tabernackel arrangement... then I think I might give the WE the edge.
    But if the topic is "Best boat under $7,500 for extreme conditions" I'm not going with the Scamp or Weekender...
    I want to build a small boat up to 15ft. Sail boat- wood.
    Maybe the diversion into 'Extreme' conditions isn't helpful.
    There's an interesting thread from a few years back about what makes a boat seaworthy - the upshot is; The skipper makes a boat seaworthy.
    If your sailing area is prone to sudden squalls, make sure the rig is easy to drop and you have a small motor that can push into the squall - reliably.
    If capsize is a real issue - then righting is the thing to think about.
    I'd suggest; Get a nice 15ft boat and then don't go out in conditions that are extreme or could turn extreme.
    Just checking out the Hartley thread, you could put a T16 together for under $7,500 - second hand rig and second hand trailer.
    Its one of the worlds most popular trailer sailors ever, there's bound to be a rotted out old one somewhere for $300 to pinch hardware etc.. off.
    Tuscon AZ
    Yes, I liked the Hartley because it is a foot wider.
    But getting the plans seems difficult. I cannot even get a price, and some have said they waited for three months.
    Phils Bolgers Micro 15' is out because of the cost and set up to melt 421lbs. of lead!
    The Weekender needs no lead.
    I am looking at some of the Selway-Fischer designs.
    Mar 2016
    South Africa
    I have been considering the SCAMP.
    I have considered the WEEKENDER/
    Now I am looking at Glen L's Minuet.
    Hallo.
    My wife reckons that whatever boat I build must not look like a home built boat. She then add that there is nothing more embarrassing than a husband with an ugly home built boat.
    Glen L is not good at sailboat designs and their sailboats look terrible, no doubt with similar performance.
    The Weekender......don't bother. If you're going to spend months and months building something, at least build to a decent design.
    Good designs don't come cheap.
    Have fun.
    Frans.
    Aug 2015
    Santa Fe NM
    Good call, I think Selway-Fisher is worth looking at. I like the externally bolted centerboards that don’t take up much interior room. Sandgrouse
    http://www.selway-fisher.com/PCup16.htm
    -The Dude-
    Aquitaine
    The Weekender needs 'Something' as it is not very stable and doesn't sail very well to windward. I would not go near it.
    Michelak (sp) does his versions of the Micro, without the lead keel. Uses bits of iron as ballast and a side dagger board.
    Hartleys and many of the S-F designs are proven performers, but take much longer to build, so more expensive.
    A while back on here, there was a build log of a S-F Coble in the US. Looked good and not tricky.
    Jun 2011
    Montreal, Canada
    Hi Donald, back on boat building?
    You have the experience and skill, well go for it and make sure you post a thread to show progress.
    Cya
    ''The work is teaching you the work'' : Bernard Moitessier.
    Single-handed Sailor, 1968-1969 Golden Globe Challenge, 1st around the world sailing race.
    Tuscon AZ
    Quote Originally Posted by sailcanoefan View Post
    Cya
    Thanks Sailcanoe fan!
    Did you finish that Conoe model?
    Tuscon AZ
    I will go back and look at some of those Michelak designs.
    Jan 2007
    Gentlemen do not sail to windward.
    actually Weekender is a boat which has interested me more and more over the past 5+- years, espically since helping a friend build a West Mersa Ducking Punt, a sort of traditional boat from the English broads used for hunting, paddling, and a little light hearted sail boat racing.
    this boat, like the Weekender is a hard chine hull with out a centerboard or even any lateral plane in the form of a keel...
    the punt is a "Simple" design but I have found the duck punt takes some real sailing skills to sail well... I wonder if the Weekender may be a similar scenario.
    certainly a shallow hull with limited lateral plane will require a light hand on the helm and a fairly advanced knowledge of how to get the best out of boat and rig to perform well.
    Dec 2011
    North East England
    The leeway resistance of the punt quite amazes me. I was helping a stunt catamaran in on Sunday. For those unfamiliar with a Stunt it is a 13.6ft foiling catamaran. The Stunt has a slightly curved bottom and certainly doesn’t present a hard chine to the water but it must present some lateral area. The helm had less than 6 inches of board down and the cat made no visible leeway. As soon as he lifted the board the cat shot sideways making less than 45 degrees.
    The point being not only how efficient modern foils are but also how effectively the punt works
    What I get up to
    Sep 2016
    Lom, Bulgaria
    Look for ARGIE 15! It's a simple 3 in 1 day cruiser !
    Petaluma, CA
    Have you considered commissioning Eric Hvalsoe to build one for you? That will definitely not cost $7500...
    Now is a good time!
    Petaluma, CA
    This boat cost $280 (entry fee for the contest) and only took 2 hours to build!
    Edge screwed 3/8 ply, with no chine logs... who woulda thunk.. The trick to this was to mark the hole locations on the bottom and the sides, then drill them separately using a tapered bit. If you don't drill the edge of the ply (right into the center ply of the three ply) then the screws will split the wood, and it will not hold together.
    The hull twist was caused by the port side being slightly longer than the starboard side, and/or not properly placing the hull sides on the bottom.. note that for next time!..put the sides together to make sure they are exact mirrors, and mark the center on them and the bottom (they go on from the center, so placing them in the right place on the bottom is critical)!
    Dan, the designer and one of the (paddlers on the right)...Tom, the other designer and paddler sitting down.
    Dan and Tom paddling for first in the first heat.
    The Master Carpenter award.
    Now is a good time!
    Dec 2011
    North East England
    I am not sure I get this type of competition. I am sure they are great fun to compete in. But unless you are using 100% recycled material and not adding 10 rolls of duck tape they seem to pay a big environmental price. Using virgin wood (even lumber hard stuff) and then a build method that will not produce a craft with any robustness also goes against the grain. Maybe I’m just missing something
    Jun 2011
    Montreal, Canada
    Yes Donald, canoe model (Redbird) is finish for few years now. Looks nice!!!
    Meanwhile I started building a model of my 19 ft Cruising Sailboat from DN Goodchild (about 54 inch long x 7.5 inch wide) but I haven't touch it for 2 years now. no progress.
    For the last 2 summers I've bveen sailing my Sailboat. I can tell you that she is very stable and pleasant to sail, the choice was right!!!
    I think you should build a small boat, no cabin with only one sail (mainsail), this should reduce the cost $$$$.
    However do not hesitate in choosing the right good epoxy, that is West System. Use stainless steel screews (or silicon bronze, better).
    My sailboat runs well with a 2.5 Yamaha outboard, 8 km/hre at half throttle. I get 1 1/2 hre running at this speed before refuelling (.9 liter full tank !) Economy of $$$.
    Cya
    Jan 2007
    building plans... $55.oo
    Feb 2018
    Paulden, AZ, USA
    Daniel would you point me towards the source of those plans, that looks worth a closer look.
    Thanks.
