Results 1 to 10 of 10
Thread: Engine mounts
    RI ,USA
    Default Engine mounts
    I'm planning on upgrading my engine mounts. My existing mounts are close to 40 years old. Does anyone have information on factors in choosing mounts? Thanks.
    Sep 2016
    Tasmania, OZ
    More information....
    Boat type, size
    Engine make, hp
    What are existing mounts?
    Mounts should match coupling flexibility.
    If no thrust bearing is used, mounts must be capable of transmitting trust loads.
    Sent from my SM-G935F using Tapatalk
    RI ,USA
    Default Re: Engine mounts
    Info to follow...
    May 2016
    Ottawa, Canada
    Hi Cushy floats has some guidance material:
    http://www.missionsupplyonline.com/p...yfloat_eng.pdf
    Mark
    RI ,USA
    Lot of brands out there..
    May 2016
    Ottawa, Canada
    Quote Originally Posted by mariner2k View Post
    Yup, but I didn't find any other suppliers that provide some data regarding selection. Most of the other marine ones I've seen give a mass, but not if this includes prop thrust and no resonance information with different durometers. If you know of others can you post links ?
    Thanks,
    Mark
    The mfr should be able to tell you what's needed. My Yanmar has the factory mounts & they weren't terribly expensive: about $80 for the forward pair & $35 for the aft one, IIRC. Keeping 'em to what the mfr recommends made it simpler.
    Being 15 years old (even though only about 220 hours, some of which was battery charging/water heating), I replaced them this year just 'cause.
    RI ,USA
    Here's a few that I found. One has a reference pdf, another has a calculator.
    I haven't been to the boat yet to gather the info I need.
    https://www.henleyspropellers.com/Pr...ineMounts.aspx
    https://www.avproductsinc.com/marine...alculator.html
    https://www.asap-supplies.com/us/eng...-engine-mounts
    RI ,USA
    Boat is a 45' sketch
    Engine is an 80 hp Mercedes OM 314@ 2800 rpm.
    Engine is 800 lb with a 200 lb. Paragon reduction gear.
    The mounts are on the engine, not the gear.
    I cannot find any info on the existing mounts. They look like typical aluminum based compression mounts.
    One question is that I noticed, there are compression mounts and shear mounts. Anyone have any knowledge as to which is better?
    Sep 2016
    Tasmania, OZ
    How is the output shaft coupled to the prop shaft?
