Results 1 to 18 of 18
Thread: Car top boat ideas
    Jan 2017
    Franklin, KY, USA
    Default Car top boat ideas
    Iím looking for a boat plan in the 12 - 15 foot range that I can get on and off the top of my car or truck single handed, row well and handle a small (3hp or less). Iíll use it fishing on inland lakes and rivers. Thanks in advance for you help.
    Feb 2009
    Australia
    Default Re: Car top boat ideas
    Here's a couple:
    https://bowdidgemarinedesigns.com/magnum-12/
    https://bowdidgemarinedesigns.com/mushulu-12/
    We do have a smaller version of the Magnum 12 as a 10fter, but I haven't created the new webpage yet
    Regards
    Mark
    www.bowdidgemarinedesigns.com/
    Mar 2005
    Saco, ME
    Mark, nice work! I've admired your purpose designed and built outboard boats. Really look good.
    Clinton B. Chase
    http://tinyurl.com/myboats
    In plywood, if you build a Redmond Whisp to plan, it will be very light - 70 pounds or so. But you only have to lift one end at a time. And being a narrow boat, it will also fit on standard width roofracks easily. To go lighter still, skin on frame is the answer. I'd suggest an electric trolling motor for most any boat in this category.
    Whisp
    Mar 2005
    Saco, ME
    Good point Dave, for cartopping the width is key. You can always go wider than standard on racks, but they can be head bangers. If he can get the boat into the bed of the truck then it is easier.
    Clinton B. Chase
    Mar 2002
    Duncan, Vancouver Island
    As above, long and narrow will be easier to manage. Some nice looking motor canoes out there http://www.selway-fisher.com/Mcanoe.htm
    Jan 2017
    Franklin, KY, USA
    Wow! Great ideas! I really like both the whisp and the 15ft motor canoe. As I have a trolling motor and a 1954 1 1/2 hp Johnson so either would be great. At 70lbs they will both be easy to cartop. Car topping allows me to pull a camper, at 63 I’m starting to get a little tired of sleeping on the ground.
    May 2013
    I am looking for something similar, no motor. Want to be able to put mine on a pickup truck rack so we can still pull a camper. To add to the mix I'll need to bring the wife's 12' wood duck kayak. I really want to build a Rangeley strip, but at 100# it's pushing it weight wise. I'm thinking with the right shaped hull I could nest the two on the rack, boat over kayak. Years ago I made a swivel rack over the cab of our f350, with a fifth wheel behind. Used to put a 14' aluminum boat up there, those days are gone.
    As someone who's done a lot of cartopping and still does a bit, borrow a friend's plastic canoe or whatever and try loading it by yourself. Park on the lawn or dirt so you don't scratch their boat up getting it in position to shove it up on the rack.
    You also may discover that your rack creates issues == if the crossbar is too far forward on the vehicle the boat gunwales may scrape the paint on the back hatch or roof. I have to use a piece of canvas when cartopping on my Forester, and kayak shops sell rubber pads that strap onto the rear crossbar for the same purpose.
    I recommend going SOF if at all possible. My friends that have built them swear that they don't crush when strapped tightly to the rack, and are many times easier to load and unload due to the much lighter weight.
    Aug 2015
    Santa Fe NM
    I think Thorne’s SOF sugestion is good. This Melonseed is nice. Drop the sail rig. I do like then freight canoes too.
    http://gentrycustomboats.com/Melonseed.html
    -The Dude-
    Apr 2007
    Thanks for the nod, Matt.
    Likely my new Indian Creek motor canoe would be more suitable (she's currently in the testing stage). 15'6" x 30something. About 55-60lbs. Oars or up to 2hp outboard.
    Jan 2017
    Franklin, KY, USA
    I built a 17’ SOF kayak 20 years ago. It was a fun boat, but it weighted about 100lbs and was not fun to load single handed. I used heavy cotton duck which I’m sure added much to it’s weight. I was always a little wary of it getting punchered.
    Back in 1948 the magazine Yachting World decided there was a need for a cartop dinghy.This is what they came up with,but loading one single handed simply won't happen.
    Mar 2005
    Saco, ME
    There are 12' skiffs out there that are plywood-epoxy construction and come in under 85 lbs. Pretty easy to get on car top.
    Clinton B. Chase
    Jun 2013
    Mandurah, Western Australia
    My 17' SoF (design by Tom Yost) came out at a mere 11kg - easy to lift onto 4WD LandCruiser.IMG_0254.jpg
    Cheers from Martin B.
    mcbunny09@gmail.com
    Dec 2011
    North East England
    The shape of the boat are equally important as the weight, obviously the weight has to be right also.
    I have a 12” and 30” 35lb canoe which is a breeze to get on.
    when it comes to my daughters optimist it is a whole different game 7’ 5” +80lb with covers
    https://youtu.be/svWEBhF6mb4
    YouTube is awash with videos of people solo roof racking boats and to me over the back is the best
    https://youtu.be/XsjQSGSqPMk
    I would be going long and as above look at the width. It is also worth checking the weight limit of the roof, I had a glass roof on my previous car and had to change when my daughter started doing squads.
    Longer boats are easier. Its relative to vehicle height. My 17 foot aluminum canoe is easier to put on the racks of pickup than my 12 foot plywood skiff because I can do one end at a shallower angle. Both are the same weight.
    If I had an 8 foot boat, it would be more problematic to single hand on to the rack ( though I would slide it in the bed). Its just geometry.
    Mar 2006
    Northern NY
    Another plan you might look at is Robb White's take on the Grumman Sportboat, strip planked:
    http://robbwhite.com/sportboat.html
    We have an old aluminum Sportboat, and it is a fine craft, and a real good car-topper. We just returned from a 7000 mile trip out west with ours on the roof of our truck, while we pulled our old Avion trailer around. Robb's version has a weight advantage, as it comes in at under 90#. Our aluminum version is about 115#, but still not bad to slide up over the back of the cap onto our truck. The nice thing about the tin one is that it is pre-distressed, so we don't have to worry about scratches or bangs while loading
    Either one of them will give great speed and load carrying ability with a small engine or oars. Here's a picture of ours atop the Dodge.
