Results 36 to 64 of 64
Thread: Saw horse test
    New Zealand's Far North
    Default Re: Saw horse test
    In this part of the world they were called sawstools. This video shows ones fairly similar to what I am used to. The fore and aft splayed legs add a lot of stability.
    They were generally made in pairs.
    Oct 2013
    dfw
    Hmmm. Today's post over on Chris Schwartz's Lost Art Press blog is on this very topic. Sawhorses built with nought but a framing square (well, bevel gauge... but you could do it with a framing square), a saw and a chisel. And some screws.
    https://blog.lostartpress.com/2018/0...-thanksgiving/
    THESE HORSES ARE GREAT!!!
    meet the original brief(pass between 2 studs) AND STACK
    sw
    steve
    Usually I only have sawhorses that fold flat but I could see having some of these.
    Nov 2006
    I've been toting these around for too long. Nice and simple, stack nicely. The top plank is Red Oak and the legs are Honduras Mahogany, from back when it was cheap. You can stack two feet of plywood on them, but I don't do that anymore. They were originaly screwed together, but last year they were getting loose, so I unscrewed them and glued them up with PL Premium, screwed them back together. Good for another round.
    Dec 2009
    Vancouver Island
    " Nice and simple, stack nicely."
    This is the design I use also. As a framer the legs would be ripped from offcuts of 3/4" plyfloor sheathing and the plank would be 2x6 edged as shown, pl300 and 2-1/4" gun-nailed, 6" ply gussets outboard of the legs. Wide enough to stand on and work, and stable. Make one plank length 6" shorter and they will stack as well as the one's above. About an hour to make a pair, with a skilsaw. / Jim
    Jan 2013
    Failed on photo.
    [IMG]IMGP0527[/IMG]
    Nov 2000
    cincinnati, ohio, USA
    I built a set of Shopdog saw horses, they are incredibly stable and can handle a lot of weight. They can be pretty versatile as well as shown on his website. They fold up to a small package and are cheap to make.
    http://www.woodshopdude.com/index.html
    I always thought that these horses that I saved from the internet years ago are pretty cute.
    Mar 2017
    Waterbury Center, Vermont
    I make the horses for our company the way my dad did. The top chord is a 2x6 ripped at 15 degrees. Leave the lumberyard radius at the bottom to help with slivers. The legs are 5/4x6 clear pine beveled at 15 degrees top and bottom, 35” long so you get 4 from a 12’. 1x4 cleats hold up a shelf. The spacing of the shelf is such that a circular saw can be set there between cuts. All parts are screwed together. Anyone who cuts into the saw horse is roundly ridiculed.
    Those shopdog legs could be made from 1x4s instead of 2x4s. Keep the 2x for the top piece.
    Dec 2011
    ParrySound
    equine dreams.....anybody
    Jan 2013
    Chippie, is this what you are referring to?
    please note NO METALIC FASTENERS on the top/working surface
    knot to mention STOUT AS ALL GETOUT!
    sw
    Yes, the "slot" at the top was as I said "tapered " to accommodate different door thicknesses.
    Lots of the above examples are "support trestles" in my opinion they lack what swoody terms " please note NO METALIC FASTENERS on the top/working surface " usually 4" approx.
    Emerald Coast, FL
    Carpenter's trestles, made from off cuts, came across the idea in the book Farm Mechanics (1918).
    FMI: Carpenter's Trestle
    Feb 2001
    Seattle, WA USA
    The new issue of Popular Woodworking is at the newsstand now. Waiting for it to hit my mailbox... for this article: https://blog.lostartpress.com/2018/0...kind-of-horse/
    Excellent looking knockdown sawhorses, 2 A-frame trestles, a T-shaped crossbeam and 2 wedges to lock it all together.
    I want to make a pair.
    Jan 2013
    To me that is a trestle support designed to support a vertically downward load. Wallpapering springs to mind.
    A saw horse is designed to resist horizontal pressures ( push sawing and dressing a door edge when engaged in the notches mentioned above) and to bear vertically downward pressures such as standing on to fit architraves at the door frame top, or sit on to when the morning break arrives.
    As someone has already mentioned, the legs are splayed for a reason.
    Why is editing intermittent?
    Nov 2006
    Quote Originally Posted by Chippie View Post
    Agreed, splaying is a small but often ignored detail that adds much to the strength, stability and longevity of a horse without adding any weight. And it looks better.
    Jun 2011
    Here are plans for the horses we use mostly for timber framing. 2x4 and x6 lumber and plywood, assemble with screws, we've used glue but find it's not necessary.
    They're real quick and easy to make. The only fancy cut is the legs but with a compound angle chop saw and a length stop and they're quick too.
    Also a video of load testing one. Kind of boring and the horse didn't quite fit on the platen, but even so it held 51,000 lb.
    Or loaded with one single 8x8" timber centered the top plate crushes and peels up at the ends at about 16,000 lb.
    Jun 2018
    Southeast MA, USA
    Grigg,
    I have used that style sawhorse for years - work great..
    Mar 2017
    5ABDC0AC-63AA-4C3B-88AE-04D9FF0F34A6.jpgHere is quick pair I made yesterday for shop use. They are for a low glue up table so will get a melamine top. 15 degree bevels, 24” tall, 5/4 pine. I put screws in the top chord where they don’t belong only because they aren’t going to be used as saw horses. I realize this is wrong. The ones I usually make are 33” tall and have a shelf that will fit a circular saw and resist splaying, but otherwise identical.
    Jan 2012
    Sequim, Washington
    Sorry about the sideways, Timber frame mortise and tenon horse.
    timber horse.jpg Rotated and still wont load right
    PaulF
    Nice adzes, too!
    Tom, saw horses that fold/lay flat is an issue for many home DIYers look for(me 2)
    so many folks are stuck on 2x4/2x6 construction because they think it is necessary to hold a load
    some friends i cook with have proven the 2x construction method to knot be necessary in most instances/circumstances
    they showed me that 4-legged horses made of 1x4's and hinged at the top will hold some really heavy loads(cast iron dutch ovens full of food) and fold flat to 1 1/2"(2 1/4" thicknesses/pair)
    I think that's a very good example of the huge differences in what folks regard as 'heavy'.
    Quote Originally Posted by Grigg View Post
    . . . the horse didn't quite fit on the platen, but even so it held 51,000 lb.
    Rattling the teacups.
    Oct 2003
    Hell
    mahogany sawhorses
    seriously
    mahogany sawhorses
    seriously
    Good choice, interlocking grain...
    Jul 2015
    St. Paul, MN
    When I was a carpenter I would have been mocked mercilessly if it took me more than 20 minutes to knock out a pair of horses. They were an inverted t with the legs screwed on and a 2x4 brace under the t into each leg.
    The only plastic ones I’ve found I liked are the Crawford Storehorse. Made in the USA, about $50 a pair and they have a tray on top you can screw a 2x in so you can cut without damaging the horse.
    My pair at moment.
    Aug 2012
    Beaufort, NC
    Back in the day when a new man came on the crew he was told to build a pair of sawhorses by coffee time. Any good framer could bang out a pair in two hours. 2x6 top 1x6 legs, 2x4 braces. Legs splayed no wider than 14 1/2" so they can fit between wall studs for easy moving around. More than one guy got sent packing for not being able.
    The really good ones had a slot cut in one top so it could be used as a rip bench. But that was back when we still used hand saws....
    Mine are 30 inches wide, 32 tall, hinged, slotted for a speed square, a rip saw and use crab pot line for stretchers. My first set lasted 14 years, until a guy at work backed a fork truck truck over them. They take about thirty minutes to build. My current set are mahogany and Marine ply. Planking scraps.
    Oct 2003
    Hell
    Quote Originally Posted by Dannybb55 View Post
    pic please
    Oct 2012
    I use ones like this. Very strong, just takes a few minutes to knock out a pair.
    Attachment 13268
    Great way to practice your mortises.
    How the devil do you <<knock out a pair of these in a few minutes>>????
    Aug 2012
    Beaufort, NC
    Nothing wrong with building wooden sawhorses. Fun to do, and good practice for beginning woodworkers. And there certainly are some nifty plans available.
    But I should mention that, as a professional, wooden sawhorses don't work as well as good-quality folding plastic ones. I've got a suite of a dozen that have lasted me for 20+ years of heavy usage. They fold flat for compact storage. They're very light for moving around the shop, or out on a dock or back shed. They carry a surprising amount of weight. And I certainly couldn't build them (since, as a business, I must value my labor) for what I paid for even the top-quality folding ones. And this model has a nifty little top pocket to receive replaceable 2X2's - though that's not strictly required, you can rig something similarly sacrificial with most of 'em.
    Here's an image of several strung together to carry the bed of my spar lathe --
    Why Isn't the saw bench plastic?
    Aug 2012
    Beaufort, NC
    pic please
    I will get some photos next week.
