Page 26 of 30 FirstFirst ... 16252627 ... LastLast
Results 876 to 910 of 1028
Thread: An offshore capable trailer boat ?
  1. #876
    Default Re: An offshore capable trailer boat ?
    Thanks John, it even looks acceptable !
  2. #877
    Jul 2017
    Toodyay, Western Australia
    Yes, everything from 4 meter aluminium plus outboard to 45 foot trawlers. I prefer quietness and polluting for pleasure isn't high on my list. Workboats , certainly. Pleasure boats , no.
    Totally with you in a preference for sail, but it seems a bit harsh to call power boats 'polluting' when our sail powered boats are not exactly ecologically sound, and increasingly I see a future of 'quiet' power boats with the rise of electric motors and much improved batteries (which could be charged by renewable power).
  3. #878
    Another discussion I think Small Boats, but I was quoting a book title. "Polluting for Pleasure". At this stage I think my JIM will suffice for some time.
    That said I can imagine some useful modifications to make her more suitable for long along shore voyages.
  4. #879
    Aug 2015
    Santa Fe NM
    What makes the most sense, cents, and eco-sense to me is. Use Jim as your normal trailer boat. Then charter a boat for extended cruising.
    Nice rambleing thread though.
    -The Dude-
  5. #880
    Jul 2017
    Ooooohhhh... I didn't pick up on the intertextuality. Hadn't heard of that book, think I'll check it out.
  6. #881
    I like building though Matt, the original aim was to discover a design buildable in wood but it has veered off to some rather nice glass designs.
  7. #882
    After 26 pages, i would say this will be the last one from me, but who knows this thread would have had such legs?
    Didi 29 Retro. https://www.dixdesign.com/29Retrodidi.htm
    Well within your trailer capacity! The 26 would probably be a better fit for a solo sailer, with some thought to raising the mast. Despite the light weight, engineered for off-shore use. I have yet to see a trailer set up for self launch-recovery of an exposed bulb keel though.
  8. #883
    The Didi 23 keel description...... Two Keel Options
    The standard keel is a vertical dropkeel with a 350kg bulb on the end of the high aspect foil. It is lifted by a tackle system led to a cabintop winch. Fully retracted, the bulb remains below the hull, with a draft of 0,5m. Sailing draft is 1.7m. The bulb can be done in either a simple vertical sided foil section for owner casting or a torpedo shape for professional casting.
    We have a fixed keel option as well. This uses a hollow aluminum casing for the foil, constructed over tubular inner framing and fitted with the same bulb options as the lifting keel. The casing is bolted through the hull bottom to an aluminum support box, which is bolted to the internal structure of the hull.
    Rudder options are a fixed blade or a rudder box with daggerboard blade. Both are transom hung on conventional pintles.
    The cockpit and bridgedeck together are 2.6m long, giving plenty of space for working the boat while racing or socialising or sunning when cruising. The only winches on the boat are a pair of 16:1 self-tailers on the cabintop. They are located where they can be operated from the companionway, the bridgedeck or the weather rail. They are oversized to ease keel handling so sail trimming will be a cinch.
    Off to bed now, I'll read more tomorrow.
  9. #884
  10. #885
    From another thread, this looks a lot like a Peter boat.
  11. #886
    It does, a bit bigger though. Do you know what design that is Phil?
  12. #887
    Nope
  13. #888
    Which thread was it on ?
  14. #889
    Wasnt that Thadds boat?
  15. #890
    That is Sally. Canoeyawl's boat.
  16. #891
    Jan 2007
    North Shore, Massachusetts
    Sea Harmony, a much larger boat than Peter's considering, but an excellent sea boat.
  17. #892
    Yes, I should have recognised her but haven't seen a photo of Sally from that quarter before.
  18. #893
  19. #894
    Dec 2015
    Dorset, UK
    I see Chebacco 25's weigh one ton.
    http://www.chebacco.com/category/chebacco-25/
  20. #895
    Good call Ed. Could probably be done in strip plank also.
  21. #896
    Dec 2015
    Dorset, UK
    Lots of waterline too. The builder used the rig from Martha Jane.
  22. #897
    Aug 2010
    BC Coast
    How about this Brent Swain boat.....no connection with me....
    https://www.sailboatlistings.com/view/62972
  23. #898
    That mizzen would handy if you have a runny nose.
  24. #899
    or keeping you head to wind at anchor.
  25. #900
    The Netherlands
    I wish they tilted the outboard
  26. #901
    Jul 2017
    Maybe they were motor sailing.
  27. #902
    Jun 2001
    Living a beautiful life... FREE FREE AT LAST!!
    I have no idea what its weight is but there seems to me that the St Valery by Bolger I think my mammories not what it once was but I think Im right... anyways!!! that would be one fine offshore capable wee boat of trailerable proportions and right work boat type too by gar an jimminy me boyoh... love that luggar design... mmmm might need to gets someone whos into figures and such alchemy and wizardy to figure out changing that damned centreboard to a fixed keel setup
    But yep St Valery indeed
    Nil illegitimi carborundum = Never let the bastards wear you down
  28. #903
    Mar 2006
    Yolo County
    I'm sure this has been posted previously on this thread, but I haven't looked at it in a while. I have a blow up of the study plan on the wall above my workbenches. There is a plan with fasteners schedule and the whole nine yards for building in either strip-planked in wood or FG, and IIRC an elementary school teacher in southern California built one, retired, and sailed it as far as Tahiti, or maybe Hawaii. That was back in the first days of my searching the internet for info about building my own boat. Before I found the WBF.
    Glen-L Amigo. Twenty-two feet.
    I don't care to know what the tough do when the going gets tough.
    I am interested in what the enlightened do.
  29. #904
    May 2002
    Gone West!
    This thread really illuminates the process of choosing a design and has traveled a long way since my post #78. In the interim I stumbled across this Alden for sale.
    https://www.yachtworld.com/boats/199...g#.W1yFcLplCf0
    It looks awfully close to THUMBCAP save a few details. She’s a Fenwick Williams design and described as a smaller sister to his much beloved 24’ gaff yawl. There’s a lot to like.
    Quote Originally Posted by Wiley Baggins View Post
    You might consider Alden’s Design No. 297, THUMBCAP. She is a small keelboat with the following dimensions-
    LOA: 21’ plus a boomkin
    LWL: 18’5”
    Beam: 6’6”
    Draft: 2’9”
    SA: 236 ft^2 Yawl rigged with a gunter main
    Disp.: 4000 lbs
    I doubt she'd be at her best to windward, but she's pretty and looks handy and seaworthy. The latter even more so with a few detail changes. Hopefully someone here can post [additional] images from the Carrick/Henderson book.
    Alden Design Listing: http://www.aldendesigns.com/99years/...php?ID=428&s=1
    Photo: http://www.aldendesigns.com/99years/...7_Thumbcap.jpg
  30. #905
    Jan 2007
    +1^
  31. #906
    Jul 2017
    This is my version of an offshore capable trailer sailer, a William Atkin Perigee with cockpit eliminated and cabin extended. With rigging she will be around 1.3 tons, so would trailer very comfortably on a 2 ton trailer (in Oz 2 tons is the upper limit for normal cars and simple trailers, over that they need fancy things like electric brakes). I have seen much bigger boats trailered around here, but not my cup of tea.
  32. #907
    ^ How would you launch that? My hunting around the area at different ramps showed up different lengths and ramp angle, meaning you might launch a deep draft from one ramp, but not another. After a crane incident, i prefer to self launch and recover, which does mean a certain amount of compromise.
    That reminds me of a wee Hillyard 2 tonner.
  33. #908
    Now there's a handsome we boat !
  34. #909
    An interesting proposition....
  35. #910
    I owned one for about 4 hours, until some other bloke came along and offered me way more than i paid for it! I was actually after a Finnesse 21, which was a better suited to shallow creeks.
    They can often come up at very fair prices in the UK, but for regular towing and a bit less heft, i would "probably" be looking at a boat already mentioned, Paul Fishers Rona Yawl.
    This thread has legs.......
