Results 36 to 70 of 111
Thread: 1927 Schooner "WILETIE" by E.B. Schock repair
    Default Re: 1927 Schooner "WILETIE" by E.B. Schock repair
    Quote Originally Posted by wowswitch View Post
    we turned a piece of alum for line up... i don't have the bearing yet!
    Ahh good for you.
    Jan 2018
    Hayward, Ca. USA
    Quote Originally Posted by jackster View Post
    "... good enough for now."
    Yea, that paint job represents a GIGANTIC effort!!
    Pat your self on the back!!
    I'm sure
    WILETIE is bustin' her buttons!
    its what we call a 20 footer paint job!
    Best seen in the dark.
    Jan 2018
    Hayward, Ca. USA
    Today we have set the new shaft strut in place with epoxy and tomorrow we will bed in with sikaflex with bolts.
    Jan 2018
    Hayward, Ca. USA
    IMG_6139.jpgand i have the original name on from 1927 "WILETIE"
    Annapolis, MD
    With the state of that strut make sure you check out any other fittings below the waterline. Galvanic corrosion rarely affects only one fitting! I've had a through hull snap off from galvanic corrosion. I'm sure you know this but worth stating for the record!
    Truly gorgeous boat and it looks like you're doing right by her. Very heartening to see.
    Jan 2018
    Hayward, Ca. USA
    Yes we checked all the through hull and all have been replaced, that strut looks like it had been on the boat many years... and here is a good side picture i took yesterday!
    Mukilteo, WA
    Beautiful!
    Jan 2018
    Hayward, Ca. USA
    Ok today we got the strut block epoxy in and bedded the strut in with Sikaflex and all bolted in, tomorrow we re-tighten the bolts, align the shaft, install the new bearing!
    Jan 2018
    Hayward, Ca. USA
    Well the good news is the schooner back in the water with no leaks! and the bad news is i will pull both masts and make all new rigging... not sailing yet...
    May 2002
    Deer Isle, Maine
    Well done ...phase 1!
    Must be frustrating not to go for just a little drift down the harbor!
    Jan 2018
    Hayward, Ca. USA
    Yes for sure... i was hoping too, there was just to much that needed to be replaced. on to phase II
    Looking great!
    Jan 2018
    Hayward, Ca. USA
    We are at phase II, the masts are out and the rig is junk... I thought is was better that it was... time to get to work and the last guy just had too much going on up there, time to make some changes back to original rig.
    Nice picture of the boat. She is very pretty.
    Mukilteo, WA
    The rigging "tangs" are actually sort of clever! But will be much better to do a proper spliced eye! Dyneema rig? Are the spars salvageable? Did that VHF antennae get hit by lightning?!
    Jan 2018
    Hayward, Ca. USA
    Hi Madison
    Yea the tangs with hose clamps or not what i was expecting! we are going to do the spliced eyes not just sure yet if we will try the Dyneema rig... the spars look good so far once we get the rigging off we will see better, it sure looks like something hit that VHF...
    Mukilteo, WA
    Well I vote for they Dyneema for this type of rig. Its so much lighter, several times stronger, and can be spliced easily by hand. The ease and strength of the splice is the real draw.
    Serve it full length and its basically permanent as well.
    Only consider the heat set stuff, Dux or STS-HSR.
    Jan 2018
    Hayward, Ca. USA
    I will have to try it... look at this photo of the top of the mast, he has running rig and 2 stays on top of the main halyard! its a wonder the rig did not snap at that point. On the original rig drawing all the rig was below that point.
    Jan 2018
    Hayward, Ca. USA
    We got the paint off the fore mast and it looks good, going to get the paint off the main mast today...
    San Francisco, CA
    Nice work! Are you going to repaint or finish bright?
    Jan 2018
    Hayward, Ca. USA
    Quote Originally Posted by bdbFC View Post
    we are going to paint because i think it last longer than bright.
    Jan 2018
    Hayward, Ca. USA
    Working on the boom, too bad it was cut down from 23 Ft. to 18 Ft. i have to work with what i got...
    You could have that rust stained, stainless, electro polished while you are doing the other work. Or, you may opt for Everdure Bronze which will turn a nice shade of green! At any rate it is great to see what you are doing for one of the best West Coast schooners still sailing!
    Jan 2018
    Hayward, Ca. USA
    thanks Jay, we are trying to get her ready for the Master Mariners race next month out on SF Bay!
    We would come and help but we are working towards a haul and new engine out shortly. Wishing you God's speed racing on the Bay!
    Jay & Annie
    Mukilteo, WA
    Pity about the boom, it would only add a day or two to scarf on more length. But then you would need new sails....
    If in a hurry, easier to sail with the old one while a new one is on the spar bench.
    Jan 2018
    Hayward, Ca. USA
    that's a good idea Jay... we are also working on the fore mast stay sail boom... fix ... fixing
    Jan 2018
    Hayward, Ca. USA
    Working on the 2 stick today, should have paint on the this week...
    Jan 2018
    Hayward, Ca. USA
    Ok, today we got the masts all painted and ready for all new rigging, going to make all new SS hard ware tangs for the wire.
    Jan 2018
    Hayward, Ca. USA
    Getting ready for the mast to be stepped, adding new varnish to the pin rails and mast collars...
    That is a proper pin rail for sure! Looking good! Those decks can be cleaned with a cross grain scrub using Dawn dish soap, a scrubby pad and a bit of citric acid. Citric can be sprinkled on the wet decks after the Dawn scrub. It won't rail the wood grain and will give a Bristol Fashion look to the decks. Chemical supply houses sell citric in bulk. It is easy on your decks, seam compound and hands! Still give it a final rinse to wash it off and get the best looking decks in SF.
    Jan 2018
    Hayward, Ca. USA
    Thanks Jay for the tip... it will be one of the last things we do when i can make a list-of-things-to-do, now there just to many parts i working on at once! i want to go sailing...
    You owe it to yourself! You have done a great job on your grand lady!
