Results 36 to 46 of 46
Thread: AGM batteries pulling double duty as ballast
    Pleasant Valley NS Canada
    Default Re: AGM batteries pulling double duty as ballast
    Have we been discussing eggman's project or yours? I have been operating under the presumption that it has been about eggman's.
    Shubenacadie NS
    Sent you a PM, should clarify it all for you.
    -Henry David Thoreau-
    Got them. It's late, so I will reply tomorrow, OK?
    Feb 2018
    Paulden, AZ, USA
    This is very enlightening and and the lessons we can learn discussing anyone's particular project is valid and will help me with my mine I would think.
    I asked this question well before settling on a design, I am new to this field but as with our other pastime which is long duration over-landing with a 4x4 vehicle and off-road trailer many of the parameters crossover, space/weight,center of gravity,rough/unstable conditions and being on your own in an unforgiving environment that can and will kill you if taken for granted so ALL views and experiences will help me make the best decisions I can. This idea started well before my choice of design to first see if it was even an option that seems to have been answered so now I can start to work out the particulars that suit our needs and I will still gain insight from others working out theirs. As I stated before "knowledge is power" and I can use all I can acquire as I enter this new field, so it would be hard to 'hijack' this discussion from my point of view...
    Shubenacadie NS
    Glad I didn't steer it too far off. I see my project as almost exactly like yours only on a larger scale with all that entails.
    Feb 2018
    Paulden, AZ, USA
    Looking at this from both ends of the size spectrum will only end with a better understanding of the issue and will be useful to others that may take this path, the efficient use of both space and weight is desirable for any size project.
    Feb 2004
    Texas
    Just curious, what is the result if batteries do happen to flood?
    Sent from my Vivo 8L using Tapatalk
    Quote Originally Posted by peb View Post
    A quick dunk should not be a problem, but immersion for hours(?), especially in salt water can wreck the battery. It seems that the electrical wiring can also be trashed.
    Having read a little more about batteries in the bilge, it seems that some sort of waterproof enclosure would be a good idea. There doesn't seem to be much good information readily available on building such an enclosure, but it shouldn't be too difficult. The enclosure needs to be vented, especially with flooded lead acid. Gore makes Teflon fiber vents that pass gasses but not liquids. Too much pressure for too long will result in some leakage, so it might be good to pad the batteries with packets of sodium polyacrylate gel and a few handfuls of limestone powder. Prepackaged gel absorbent pads are readily available to Pamper your battery, but the choice of packaging Depends on your situation. The gel may be overkill, as well as the puns.
    http://forum.woodenboat.com/showthre...s-in-the-Bilge
    http://owlogic.com/pdfs/Gore-Membrane-vents.pdf
    https://roadslesstraveled.us/wet-cel...n-wiring-tips/
    Jan 2007
    North Shore, Massachusetts
    Tuscon AZ
    All batteries are ballast.
    Auckland ,N.Z.
    I would have thought water across the terminals would be terminal. for the batterries.
