Results 36 to 59 of 59
Thread: Making a gimballed stove
    Sep 2004
    Utah and SF Bay
    Default Re: Making a gimballed stove
    Quote Originally Posted by Thad Van Gilder View Post
    a couple boats ago I had a 1923 falmouth quay punt. I used 1 pound cylinders for the stove and grill. I used to stack them up in 6" plastic pipe, lashed to the pulpit.
    This is how we store the cylinders for our grill. PVC pipe lashed to the mizzen mast holds two cylinders. But for the gimballed stove on a longer offshore passage, we'll need to store more of them.
    Sep 2004
    Utah and SF Bay
    Regarding the Flame King recall
    REI Service
    ​All inventory was inspected and any affected canisters were removed from our stock in June 2017. Everything for sale from July 2017 on is unaffected. For additional information, please give us a call at 1-800-426-4840.
    Dec 2016
    EU
    Dave I think you missunderstood. The link was for one canister plus the refill kit. A single canister is 18$. The ideea is to have a big normal tank (I would take a fiberglass or aluminium one) lashed to the pulpit, and two of the 1lb canisters, one on the stove and one filled as a spare.
    If space allows one can use the 4,5-5 lb canisters. There are some aluminium ones. The nicest one I know about has a fill indicator and a multivalve, but is steel. Can also be fitted with a valve conection for direct fill from an LPG station.
    http://www.gaslowdirect.com/epages/c...cts/01-4003-67
    Maybe you can find something similar in the USA wich fits the space (and not so expensive)?
    Aug 2009
    Olympia, WA, USA
    They will protect the threads and have a rubber gasket that seals them in case the valve leaks.
    These are genious.... I gotta buy a couple. I didn't even know that was a thing.
    Oh yeah! Those are good. I'll be getting a couple if I again find myself with a propane stove.
    kinda like a refined version of this.... but no legs and gimbled.
    https://cdn.remodelista.com/wp-conte...emodelista.jpg
    Looking at that photo, I could imagine a way to cannibalize the burners from that stove and do a nicer frame in bronze. I could also see re-plumbing the gas line so that a long thin propane cylinder could be suspended on its side beneath the burner, minimizing the gimballed height.
    But all of that is just me getting excited about the project. I'd rather see what you're doing!
    Alex
    Aug 2010
    BC Coast
    I have an old Optimus, mostly as a keepsake. I could use it on my boat, but the Sea Swing with the propane bottle (non-refillable, unfortunately) is so easy and clean and reliable. I need to overhaul it....new washers above and below the pan, and new cleaning pricker's at least. Anyone know of a source for parts?
    Also where do you find those adaptors for filling non-refillable propane bottles?
    Sep 2004
    Utah and SF Bay
    The propane tank needs to be angled upward so that the gas (and not the liquid phase) comes out of the valve. I don't know what the minimum angle is, but it has to be above the horizontal. I mounted mine vertically so that it would work regardless of the angle of heel.
    Sep 2004
    Utah and SF Bay
    They're available on Amazon and many other sources, but I wouldn't recommend using them. There are a number of YouTube videos about refilling "disposable" propane cylinders, bleeding the valves, weighing the tanks, putting them in the refrigerator, etc. Mostly posted by people who haven't blown themselves up yet.
    Feb 2004
    Downingtown Pa (S/V Andantino down in Rock Hall, Md)
    "Looking at that photo, I could imagine a way to cannibalize the burners from that stove and do a nicer frame in bronze. I could also see re-plumbing the gas line so that a long thin propane cylinder could be suspended on its side beneath the burner, minimizing the gimballed height.
    But all of that is just me getting excited about the project. I'd rather see what you're doing!"
    Alex[/QUOTE]
    The burners are cast iron. I bought one to see what I could scavenge. and the valve mechanism... is.... poor.
    I have been thinking of using the valve and burners from normal camp stove. like a coleman or something.
    Aug 2009
    Olympia, WA, USA
    Definitely get in touch with Gary at Bluewater Stove restoration (link at Post #18). I know he keeps a variety of burners in stock, of various different fuels --and knobs, jets, various parts, etc.-- and I think he'd be interested in the project. He has helped me out a lot with various "frankenstoves" I've assembled over the years, swapping burners around among various stove types. Use my name, if you like; I've been emailing with him over the past few days and your project came up over the course of our correspondance.
    Alex
    Sep 2004
    Utah and SF Bay
    A Bremer Sea Swing has turned up on eBay. No affiliation, etc. Wall bracket not included.
    https://www.ebay.com/itm/302605042827
    Talisman has a Bremer Sea Swing. We modified it to hold a little backpacking stove that uses the isobutane fuel cartridges. It was originally dessigned for use with sterno. We use it underway for coffee and soup mostly. At anchor we use one of those one burner butane stoves.
    Feb 2005
    Abbotsford, B.C.
    There was a fellow on this forum that built a stove here step by step.
    I think the post was taken down for some reason.
    He posted often here, his wife was a teacher I think, he moved to the far west, (or was it the far east? Oh well, if you go far enough east you'ii end up west if the rumor that the world is round is true.)
    I hink he had a boat building shop in Port Townsend.
    Ringing any bells?
    basil
    tacoma washington
    I've loved the hanging device that jetboil had for a few years. now a company by the name of " RVOps " is making the jet boil hanger. How about getting the camping stove you like and make the swing set? sorry new computer and I don't know how to post a link ...ps back country gear has it too
    Sep 2004
    Utah and SF Bay
    Quote Originally Posted by the_gr8t_waldo View Post
    Thanks for the heads up.
    Here's the link to Backcountry Gear: www.backcountrygear.com/jetboil-hanging-kit.html
    The hanging kit is for Jetboil's lightweight backpacking stoves that run on an isobutane/propane mix. Their heavier "base camp" stoves run on propane.
    They would be good for coastal camp cruising, but probably not for offshore voyaging.
    Quote Originally Posted by goodbasil View Post
    Ringing any bells?
    The thread about James’s gimballed stove is gone. It was resurrected by Jimmy W but the picture links are gone. He basically bought a couple of slightly different sized pots at a thrift store and through clever cutting and bolting together fastened a gimballed stove mount. You can see it in this video:
    That video led me to this one for a Jetboil mount. Pretty nice looking. Iím not sure if itís still available.
    http://www.safirewaterjet.co.uk/the-...oil-stove.html
    Quote Originally Posted by Dave Lesser View Post
    I hate to think how that would swing around! Camping, maybe but not on a boat surely.
    Aug 2009
    Olympia, WA, USA
    That's like the big-wall kit for the old MSR Firefly. Years ago I made up a version for my MSR Whisperlite, with the fuel bottle slung underneath. It's good on land, but Phil Y is right: it occillates like a mad b*stard on a boat. Scared the b'jayzus out of me when I tried it aboard Bucephalus, suspending it from the boom. I lit it up as it was sitting on the bench, set the pot on it, hung it up under the boom, turned away to prep the food, and a few seconds later, when I turned back to check the food, the stove was orbitting around the cockpit at mach 6. That ended *that* experiment. (To be fair, though, it didn't spill a drop!)
    Alex
    Now, there's a long story...
    This one?
    Heute ist so ein schŲne Tag...
    Sep 2011
    New jersey
    In The first photos it looks like it gimbals sideways but not fore and aft.
    Barrie, Ontario, Canada
    Regarding the original build, I like the way the bottle acts as ballast, stabilizing the motion. And I like the fact that it's quick-unscrew -- you only need to have the bottle in the cabin while you're actually cooking.
    I presume you did a soap-test on all the soldering.
    It occurs to me that similar unit could be made using an Origo-style alcohol burner. These are not as hot of course -- but I find I still manage to burn my food.
    Nice job.
    Apr 2007
    Singapore
    Ringing any bells?
    That guy sounds familiar. Whatever happened to him, anyways? Itís almost like heís gotten too lazy living in a tropical paradise these days to hardly ever even bother to check in anymore. I did hear a rumor that he mostly just sails Lasers these days instead of something wooden, and so probably doesnít have much of interest to report.
    Sep 2004
    Utah and SF Bay
    Yes, I did the soldering because the compression fittings failed the soap test. The supply tube that came with the stove is non-malleable, thick-walled brass that resisted compression, but I had to use it because the fitting going into the stove is proprietary.
    I dunno, but the place just isn't the same without him
    Dave, is there a thread here somewhere about that great article in the Feb. issue of WoodenBoat? You know the one...
