Results 36 to 70 of 142
Thread: Maid of Endor model build
    San Francisco Bay
    Default Re: Maid of Endor model build
    Quote Originally Posted by donald branscom View Post
    Today I cut the rabbit in the keel with a Dremel tool. Frame #8 is giving me lots of problems. I do not know why.
    Maybe working on such a small scale.
    I was having more problems with the frames than other models I have built.
    This is kind of a fat looking boat.
    It just may be a fat looking boat. The lines show a pretty hard turn at the bilge, so "fat" may equate with "stable" in the finished boat.
    Also, did they draw the plans to the outside of the plank or to the inside and did you cut your frames allowing for whether the lines were to the inside or outside of the plank? It's funny how the thickness of a plank on both sides may make a significant difference in appearance, even on a model.
    Tuscon AZ
    Outside of plank.
    Tuscon AZ
    Planking is progressing. The planking near the stern twists almost 45 so
    I thinned down the plank slightly in a gradual transistion to make glueing easier.
    Tuscon AZ
    Closing in on the planking. Maid of Endor-Atkins design.
    The turn at the bilge is almost 90.
    Each end is twisted at about 45
    Intense! Are you soaking your planks to soften them? I'm kinda learning about this model stuff and am watching with interest!
    I found that an application of boiling water and the heat from the hob helps putting twist and or bends in plank stuff.
    Tuscon AZ
    I do not soak the planks.
    They are Basswood also known as larch.
    On some of the more difficult twists I thinned down the plank .
    The planks are 1/8" thickness.
    One quarter inch wide.
    Tuscon AZ
    I finished the planking. Then came the sanding. Filled with a light skin of Bondo.
    I used a contour gage to measure the two sides of the hull.
    Now I have applied white shellac primer sealer. I will give it two coats.
    Nov 2006
    Looking good, Donald, lovely shape!
    Jim
    Tuscon AZ
    Jim
    Thanks Jim!
    Doesn't look nearly as "fat" with the planking on as it did in the frame only state. Very nice low! Is that just plain ol' automotive Bondo?
    Tuscon AZ
    Yes- automotive Bondo.
    Tuscon AZ
    I switched over to working on the interior.
    Installed sheer clamp.
    Omitted the clamp shelf for purposes of the model.
    Now working on interior pieces.
    Tuscon AZ
    Update on photos.
    Interior of the model.
    You can see that it has a bridge deck and vertical ladder.
    If I was building the real boat I would eliminate that bridge deck but
    I am being faithful to the original as much as possible.
    Mukilteo, WA
    Looks great!
    It does look great. Don, are you going to make the cabin top removable so the interior can be seen?
    Tuscon AZ
    Looks great!
    Thanks J for the interest and comment.
    Tuscon AZ
    Yes -the interior will be visible thru the companionway opening.
    Tuscon AZ
    I have been making progress on the cabin top.
    The companionway is almost done and the portholes and trim are also done.
    Tuscon AZ
    I started to put the decks on and once I got rolling I could not stop until I had them all on.
    I used tin snips to cut the 1/32 ply for the deck.
    Nov 2006
    Thanks for posting this, Donald. She's coming out really nicely!
    Tuscon AZ
    Thanks Jim.
    The start was difficult because of the scale of the frames.
    Now it is rolling along nicely. It will slow down when I have to hunt for some of the fittings.
    Tuscon AZ
    Today's progress.
    Completely redo the coamings.
    cut mast hole in deck.
    Cut holes for bits on the foredeck.
    Make two hatches with lids.
    Install a stopwater for the cockpit.
    Just cannot remember the name of that board on each side of the cockpit
    that serves as a backrest and stops the water coming into the cockpit. Anyone?
    Dec 2006
    Maryland
    Today's progress.
    Completely redo the seat back boards.
    Coaming
    Tuscon AZ
    Quote Originally Posted by KMacDonald View Post
    Coaming
    Thank you !
    I am going to claim old age on this.
    Tuscon AZ
    I tried to buy my way out of hand building the rudder hinges and
    pintles but there was nothing close available.
    The bottom hinge and pintle was a very distinctive part.
    So I bucked up Bucky and went shopping for brass.
    I had to leave my brass collection back in California.
    I just could not carry everything with me to Tucson.
    Detail of bottom pintle. Needs some finishing.
    Bulwarks started.
    Tuscon AZ
    This is where I am building this model.
    I have the mini bandsaw and sander out in my back shed
    to keep all that wood dust out of my house.
    On my last build I think my computer got a lot of wood dust sucked into it.
    This morning I started to tape off the interior to prep for paint.
    I finished the bulwarks and made the bowsprit(not shown), I will show it later when I rig the boat.
    That is gorgeous! Most of the planking pine? Bass? Now you've inspired me to start setting up for a decent build next winter. But right now ispring is in the offing and I'm hoping to finish off my Mirror.
    Tuscon AZ
    Planking is basswood/larch and the cabin top is pine and basswood with plywood decking.
    The rudder is douglas fir and pine.
    Thanks for the compliment!
    Love it!!!!
    Tuscon AZ
    Quote Originally Posted by mfdgs View Post
    Love it!!!!
    Thanks MFDGS!
    Painting is underway now so I will post photos soon.
    Tuscon AZ
    I have started the painting.
    The bottom is Flat black,bottom paint.
    The sides are blue.
    The deck is next.
    Tuscon AZ
    Painting underway then rigging.
    The topsides is Rusoleum canvas white.
    Dec 2004
    vancouver, british columbia
    Update on photos.
    Very nicely done, Donald. I've been pondering your objection to the bridgedeck. I've heard someone somewhere wax poetic about sitting on the bridgedeck with his/her feet on the ladder and the heat from inside warming them up while keeping watch. I can see how it might be a bit of a PITA getting in and out, though.
    Tuscon AZ
    You can used to anything.
    I have had boats with and without a bridge deck.
    In the end I did not like them.
    You can sit in the companion way facing forward with OR without a bridge deck.
    The bridge deck helps keep water out of the interior of the boat.
