Results 36 to 62 of 62
Thread: 1956 Speedliner
    Dec 2017
    Germantown, NY
    Default Re: 1956 Speedliner
    The end of last week and this weekend saw some good progress of the bottom of the Speedliner. The patches were finished, the keel bedded down and the fairing started. Sunday night the first coat of primer went on. Well on my way to hopefully finishing the painting next weekend.
    Dec 2017
    Germantown, NY
    Here is a little photo progress of how I patched the rotten stuff. I'm only going to show one of the 3, but they were essentially all the same.
    First step was to scrape and brush out all the loose rotten wood and give it time to dry out some.
    Next I used a simple home made jig to rout out a nice flat and square hole. In this case there were two panels at different angles making it a bit more challenging.
    Next I chiseled in a beveled scarf to give some nice gluing surface area and cut out some patches to match. Several coats of CPES were applied until it stopped soaking in.
    Dec 2017
    Germantown, NY
    Next it was glued up with thickened epoxy. Screws were driven into the frames through the original holes and bags of lead shot were used as weights where there were no screws. These bags are 25lbs each and were set on top of plastic sheets so the boat didn't come out 50lbs heavier
    Here is how it looked after the epoxy was cured, but before any fairing.
    And finally after the first round of filling and fairing.
    This patch is certainly not good enough for a varnished repair, but I think with a few more attempts and some more patience it would be possible to make it work. Fortunately this will be under paint and with a little more fairing I should be the only one who can find it in the future.
    Jul 2005
    Down South
    Nice work !!
    Mar 2016
    South Africa
    Good evening,
    This is a very nice little boat.
    I am not from the U.S. Please tell me what CPES is.
    Regards,
    Frans.
    Jul 2005
    Down South
    Clear Penetrating Epoxy Sealer.......... from Smith's and similar products from other companies.
    See here, and other threads: http://forum.woodenboat.com/showthre...s-Smith-s-CPES
    Dec 2017
    Germantown, NY
    Time to call the troops and flip her back over. Five coats of primer and 3 of Perfection and I am ready to move on to the topsides. For the most part all went well. The saying "good from far, but far from good" comes to mind. However, given that it is the bottom I probably shouldn't get too picky.
    There were 2 tiny spots which were contaminated and caused fisheyes, probably some silicone that I missed cleaning out. So I had to grind down to good material and fill, re-prime and paint prior to the final coat. But that wasn't too much of a pain, just an extra week of watching paint dry that I didn't need. Now on to lots and lots of prep and varnish work
    Lake Champlain, Vermont
    Just beautiful...
    Dec 2017
    Germantown, NY
    Today's activities went well and now she is topside up. Time for more fun with the heat gun and scrapper.
    Oh golly look at all those fisheyes on the deck. Hopefully they will go away!!
    P.S. I had a good chat with Steve from Seajay boats yesterday and he gave me some good info to get underway with the stain and varnish. Hopefully I will be putting that to good use soon.
    Jul 2005
    Down South
    Looks great! Are you taking the deck and topsides down to wood? I guess so, if you are restaining.....
    Dave
    Dec 2017
    Germantown, NY
    Quote Originally Posted by DavidS View Post
    Dave
    Hey Dave,
    Unfortunately there are enough spots that need to be stripped to wood, so it makes sense to do the whole thing the right way the first time. This will be my first time staining under varnish, fingers crossed.
    -JP
    Jul 2005
    Down South
    Yes, makes sense. On my boat, I used a gel stain, and made sure that that was totally dried. Then a couple coats of a very thin wood sealer, and then the varnish. I liked the Epifanes Wood Finish which you can recoat without sanding.
    Dave
    Tuscon AZ
    Thanks for the great story and photos!
    Well worth the effort.
    Dec 2017
    Germantown, NY
    Dave
    Hi Dave,
    I'm a big fan of the stuff from AkzoNobel (International, Interlux, AwlGrip) I've been using them for years both for fun and professionally on everything from small boats to large ships. I'm going to go with the AwlSpar/AwlBright system. That varnish system also allows for multiple coats in a day and give a really hard finish in the end. All that with Interstain 42 underneath, apparently the original color for Speedliners.
    -JP
    Dec 2017
    Germantown, NY
    Quote Originally Posted by donald branscom View Post
    Thanks Donald,
    I appreciate knowing that some folks are enjoying following the restoration. I passed 100 hours into her today and will get some photos up soon. I was mostly stripping varnish, but that turned into pulling off the covering boards to glue and screw them down more securely. I can't resist ensuring that she will last another 60 years when already this far in. It seems silly to save a few hours of easy work, just to get to varnishing sooner.
    -JP
    Jan 2017
    Melbourne, Vic, OZ
    Great job , Nice boat !
    Have to agree . You will do her proud , I`m sure !
    If you are the smartest person in the room, you are in the wrong room.
    Dec 2017
    Germantown, NY
    Sorry for the long delay between updates. Each step forward looks so small that I haven't noticed the changes.
    After pulling off all the remaining hardware I began making small repairs. Filling gaps with thickened epoxy and toothpicks for nail and screw holes.
    I began stripping, but realized the covering boards were all loose so they were removed, cleaned up , glued and refastened down.
    Once that was done and the deck was fully stripped I realized that the filled screw holes were not good enough looking. So I removed all the filler, gave each screw a 1/4 turn and re-filled.
    It took some time, but the deck looks good now. Almost time to give the luan "racing stripe" some varnish, then stain.
    Dec 2017
    Germantown, NY
    The sides and transom are also stripped and just need a little cleanup and sanding.
    I also chose to strip the fwd seat back. It was not that good looking and I figured is was a large area that would be very visible. It took some creative twisting to get everything stripped and sanded, but turned out just fine for what it is. It was also my first try at staining, and went fine, which makes me feel more comfortable about doing the rest of the hull.
    Next update to come when the varnishing and staining begin.
    Jul 2005
    Down South
    Nice work. The deck will be much better with everything cleaned up !
    Once all the prep work was done, I actually enjoyed laying down a coat of varnish, or 10....
    Dec 2017
    Germantown, NY
    Thanks Dave, I too enjoy a good varnish session.
    Dec 2017
    Germantown, NY
    First 3 coats are on the "blond" wood. Staining should happen this week after a little bit of prep.
    Tuscon AZ
    Good story and good photos! Thanks
    She’s going to be beautiful!
    Dec 2017
    Germantown, NY
    Staining is done! After several days to make sure it is fully dried the real varnish challenge will begin.
    Feb 2016
    Sea, WA, King
    Looks great! You'll be ready for summer no problem!!
    Jul 2005
    Down South
    Looks great.
    The plans for the Rascal called for 2 coats of wood sealer. I did that after the stain was dried for several days. Then the varnishing began.
    Dave
    Dec 2017
    Germantown, NY
    Hi Dave,
    This is the varnish schedule I am going with.
    Interlux Interstain, color 42-Brown Mahogany
    AwlGrip AwlSpar, thinned 100% This essentially acts as the sealer.
    AwlGrip AwlSpar, full strength, 2-3 coats. These coats provide the color of a traditional varnish job.
    AwlGrip AwlBrite, 10-14 coats. This is a 3 part urethane varnish that is very durable, and goes down quickly. However, is not the easiest to work with.
    It has been a while since I last worked with AwlBrite, so hopefully I can remember all the little details of using it.
    -JP
