Results 1 to 14 of 14
Thread: 1908 cycle car racing engine
    Oct 2003
    Hell
    Default 1908 cycle car racing engine
    watercooled
    single cylinder
    four valve desmodromic valve train
    dual ignition with four spark plugs
    intake charge was pre-compressed and entered the intake tract via a sleeve valve
    Behold!
    Sep 2002
    Hamilton New Zealand
    Default Re: 1908 cycle car racing engine
    Lots of good ideas in there, a bit ahead of its time. I wonder what it put out?
    John Welsford
    Mar 2006
    Northern NY
    More sophisticated than a NASCAR ENGINE -- but then, what isn't?
    Cunning as ...... especially for 109 years ago!
    Oct 2006
    Livin' in Oz
    Quote Originally Posted by moTthediesel View Post
    What's this pre-compressed intake charge?
    1400cc in a single, eh?
    I'd rather look back at my life and say "I can't believe I did that" instead of being there saying "I wish I'd done that"
    Oct 2006
    Livin' in Oz
    I found the following, but can't get the photos. Not sure if that's just a local issue, or whether they've gone. 100mm bore x 180mm stroke. Wow.
    Ariès:
    single-cylinder, 100/180 mm, overhead camshaft, four vertical valves, four plugs, single disc clutch, 4-speed gearbox, wheelbase 225 cm, track 123 cm, tires 810x90.
    No 14 (weight 643 kg) - Meaux de Saint-Marc, mechanic Guérin:
    www.artonline.nl/heritage-specials/catalogs/aries/aries_14_1908_voitur-099-lr.jpg
    No. 39 (weight 632 kg) - Perrot - mechanic Margoutte:
    www.artonline.nl/heritage-specials/catalogs/aries/aries_32_1908_voitur-101-lr.jpg
    Aug 2006
    Rockford, IL
    What is "desmodromic"?
    Oct 2003
    Hell
    Quote Originally Posted by Nicholas Scheuer View Post
    no valve spring, there is a second cam follower which closes the valve. . .
    Oct 1999
    St. Paul, MN, USA
    What in the world is that gear at the base of the cylinder head? It looks like it engages those little teeth machined on the cam drive shaft, but that doesn't seem possible. The cylinder head doesn't turn? No, it can't. What's that mechanism between the cylinder head and the crankcase? Something's going on there I don't understand.
    That really looks like an exercise to see how many moving parts you can cram into a single-cylinder engine. Complex isn't necessarily sophisticated, and rarely better.
    for nature cannot be fooled."
    Richard Feynman
    Oct 2003
    Hell
    it looks like the cam/distributer gear shaft is driven off the crank case and that the large horizontal gear at the base of the cylinder is driven by the cam drive
    oil pump and/or water drive pump perhaps? does it drive a dynamo generator for the spark? some type of pto?
    the engine is supercharged, i bet the large ring drives the supercharger
    Oct 2003
    Hell
    Aquitaine
    Quote Originally Posted by Keith Wilson View Post
    The first post mentions a 'sleeve valve' to charge the cylinder, so the ring gear might be about that. If so, the four valves are all exhaust. Ignition looks to be off that extension of the cam shaft. Little milled nuts to secure cables. The valving is not dissimilar to the old Detroit Diesels, except they used springs.
    BTW; Paul. Nice find.
    Just noticed: The gear reduction for the cam appears to be in the head. So the shaft is at crankshaft speed, which makes the sleeve valve drive less likely, but not impossible with multi ports.
    Jan 2005
    Deepest Darkest Wales
    Suitable for use in the "Desmodromes" where the racing was particularly fierce - the use of these declined after the first world war and died out altogether following the great depression - though Mercedes continued with the valvegear as late as 1955.
    Incidentally, if anyone knows of any existing remains of a desmodrome I'd like some photographs.
    Oct 1999
    St. Paul, MN, USA
    Ducati currently uses them on production bikes. (link) Mr. Newt's bullshi!tting you about 'desmodromes'.
    Richard Feynman
