Results 36 to 64 of 64
Thread: Timber framing tools
    Default Re: Timber framing tools
    [QUOTE=MN Dave;5399669]The attach code is difficult to deal with. This is an inexpert opinion from a technically backward OF, so take it with a grain of salt.
    I tried to drag and drop the images in Post #31 into the reply. The image files were counted as text and exceeded the character limit, which prevented the post from uploading. I deleted them and used the insert image tool. That looked good until I uploaded the post. The post uploaded with the images where I put them and multiple attached thumbnails in a box like the one in Post #34. To remove the thumbnails, you have to edit the post, use Go Advanced and muddle through the command that I can't remember to select and delete the attached thumbnails. That got rid of the thumbnail box, but it also inserted a bad link that showed up when posted along with the images, but not in the edit mode. It had to delete the post and start over. Totally not worth the trouble except as a learning experience.
    Windows Photo Viewer is the easiest image rotating tool. It doesn't seem to do anything else, but it dies change the orientation and saves the change whether you want to or not. Whether that will prevent the forum software from spinning the pic again, I don't know.
    I already got a lathe. I’m working on a portable version, and a taller set of stocks so I might could turn a bowl one day. I use an old bow for the spring pole.
    Peace,
    Robert[quote/]
    Like this?
    Attachment 5965
    Yar! Jess like that! Mine is built onto a “bench” in my shed, but I aim to make a knock down version.
    Peace,
    Robert
    Edited to add: There is a thread about my silly lathe...
    Jan 2012
    Sequim, Washington
    Mr Bauer,
    I've completed the hook and handle. Today I'll heat treat and sharpen, then epoxy the tool and handle together. Just put pine tar and linseed oil on wood handle will ship tomorrow.
    PaulF
    Blacksmithing is a skill, and like playing a piano, books will only point you in the general direction.
    You have to do the work, learn how the particular material responds when in a plastic state and know pretty much exactly what the finished product will look and feel like before you start. I had collected a nice forge and quite an assortment of tools, but there are a lot of mistakes to be made before you can call yourself proficient. I gave up on the forge and most of the tools associated with it including a few hundred pounds of low-sulphur coal. I kept a couple of anvils, hammers and vises and use an oxy-acetyline torch if I need to do it. Just getting a good working fire meant you were in it for an hour - minimum. And I wanted/needed a powered hammer to work steel...
    For those that love to create (art) it is a lot of fun. It checks all the boxes; fire, smoke, noise, and beauty all in one stroke! Paul's skill and work is exceptional.
    My whole day will be ruined throwing together a small gas forge so I can make some arrowheads and a few lathe tools.
    I used to have a brake drum forge, but this one will be smaller, and gas powered.
    Hoot, hoot!
    Peace,
    Robert
    Jan 2012
    Sequim, Washington
    Thank you, I'm still working on it. Takes lots of doing.
    You need one of these:
    PaulF
    Oct 2003
    Hell
    Quote Originally Posted by paulf View Post
    doesn't everybody???
    May 2009
    Fort Worth, Texas, USA
    Paulf,
    I don't know what the heck I'm looking at.
    I still have several anvils, my favorite is not a horn anvil but a large square anvil like L W in this image.
    Jan 2012
    Sequim, Washington
    Paulf,
    A 1905 Champion 60 Lb mechanical forging hammer. You can form a 1/8 round rod from a 1 inch square bar in 5 minuets with this hammer, no problem.
    It moves a lot of metal fast! The 60 Lb is the weight of the Top die and the Taupe..(connecting hardware)in pounds. I can't use a hand hammer that big 3 times a second for long!
    PaulF
    Jan 2012
    Sequim, Washington
    Looks like a trip hammer. L W weighs in at what??? Good steel like that will serve well! I rarely use the horn.
    PaulF
    Apr 2017
    Decatur, Georgia, USA
    Thanks, Paul (And Others!) for this mind-boggling thread. The WBF community continues to amaze.
    My neighbor has a nice little modern power hammer.
    I don't get as much use of this stuff as I'd like.
    But I can go out there and make my own caulking irons when I need to.
    first make up a swage block
    for forming the head
    There had to be something boat related on this thread. lol
    Now, where’d I set them old files?
    Peace,
    Robert
    Sorry for the drift, but I’m pleased as punch it works. I need a bigger burner, especially if I want to heat anything thickish, but these little blades are quick to heat. Watch it, they heat real quick.
    This isn’t a thing, just playing with the little “forge”. Maybe I’ll finish folding it and make a little hook knife?
    Peace,
    Robert
    British Iron works, making a ships anchor……...
    Mr Bauer,
    I’m just now seeing this post! Looks a treat. (I did see your other messages). Very excited.
    Oct 2003
    Hell
    how do you sharpen that?
    Mar 2006
    Yolo County
    I saw this for sale, a little north of the Bay Area, on the SFBay craigslist, just this morning. The ad calls it a sawyer's anvil.
    1924 Fisher &. Norris Sawyers Anvil - $250 (sebastopol)
    196 pounds.
    https://sfbay.craigslist.org/nby/tls...400738128.html
    I don't care to know what the tough do when the going gets tough.
    I am interested in what the enlightened do.
    That is nice!
    If it hasn't been tempered in a fire it is a very good deal... a serious anvil for 1$ per pound.
    (Mine is similar with a smaller platen, made in San Francisco before the earthquake, the steel top is dovetailed wedged onto it and replaceable)
    Quote Originally Posted by Jim Mahan View Post
    196 pounds.
    Look what came today!
    Thanks, Paul!
    just built my first timber framing chisel. 2 inch,D2 air hardened tool steel, differential hardened and tempered blade, 2 inch at tip RC62, tapering back to annealed RC<40 at the tang socket.
    Next is a 1.5 inch O1
    Attachment 6243
    fifty...
    I want to say,.... Gorgeous work!!!! Very impressive.
    Jan 2012
    Sequim, Washington
    Thanks, Paul!
    Glad it made it so fast! It is very close to sharp, get a extra fine, diamond, tapered hone to really get an edge on it.
    PaulF
    Jan 2012
    Sequim, Washington
    They are a pain..but a diamond hone that is tapered will do a good job. DMT makes some good ones in fine and extra fine grits.
    PaulF
    Paul, do you ever used “charged” leather? My buddy who carves (so has any number of oddly shaped blades) uses diamonds and then charged leather strips cut sort of thin, like laces.
    Also, when forming the cutting edge, is it “wedge” shaped, like a knife blade? I am about to attempt my first hook type blade like that, and I’m curious, is all.
    It IS a lovely tool.
    Peace,
    Robert
    OK. What in (where Paul P. lives) is a sawyers anvil?
    http://www.engraverscafe.com/showthr...-my-Tansu-Work
    Best answer:
    It never ceases to amaze me what guys get really excited about..........82lbs of steel.
    FANTASTIC!!!
    Cheers
    Andrew
    Good answer with more detail in Post#8 of the link above:
    A Sawyer's anvil was designed to be used by a saw tuner, or a sawyer, to tension large circular saw blades by resting the blades on another support and spinning them around in increments so that a portion would rest on the sawyer's anvil, where he would strike it to tension each section in turn. The goal was to manually tension the blade to reduce or eliminate vibration while spinning. They also correctly tensioned and tuned hand saws of all sizes.
    Now I have to look up tensioning.
    Jan 2012
    Sequim, Washington
    Peace,
    Robert
    I've used charged sewn felt wheels, leather I'm sure would strop/buff just fine. You could most likely attach thin leather to any shape hard wood for a custom edge stropping tool.
    PaulF
    Jan 2012
    Sequim, Washington
    Thanks Ned!
    PaulF
    Southampton Ont. Canada
    Peace,
    Robert
    Mdf can be charged,(I use rouge,even though it's green) after using the Odd Shaped Tool To Be Sharpened to make the profile.
    R
    Sleep with one eye open.
    Mar 2006
    Yolo County
    http://forum.woodenboat.com/showthre...light=hand+saw
    WBF member Bob Smalesr posted this tutorial on handsaws, in 2007, wherein he explains about tensioning and how to fix bent handsaws.
