Page 131 of 133 FirstFirst ... 3181121130131132 ... LastLast
Results 4,551 to 4,585 of 4640
Thread: Scientific knowledge
  1. #4551
    Scotland
    Default Re: Scientific knowledge
    Quote Originally Posted by Frank! View Post
    says 62 million years. - this was the maximum possible (even so, fatal for the theory of Evolution).
    - the authors mentioned that the Minimum could include 6000 years.
    Frank!, if there's a maximum of 62 million years, with nothing else defined, then the minimum could include 12 minutes, couldn't it?
    Why - unless you're shoehorning a theory to fit what you want - would you plump for 6000 years, 0.01% of the estimated maximum?
    subduction of ancient seawater (i.e. burying salt) because tectonics 'isn't allowed'
    - not familiar with this argument (and didnt catch it in the reference)
    Ok. Suppose:
    A/ I'm dropping salt into a bucket of fresh water at a particular rate. A spoonful a minute, say.
    B/ After an hour, I tell you the rate and give you the bucket. I don't tell you how long I've done it for.
    C/ You measure the salinity, to work out how many spoonfuls have been added to the bucket.
    D/ You do the maths. Time = salinity/rate.
    E/ You declare the maximum time to be ~1 hour. You'd be unlikely to propose the minimum time was therefore about a third of a second. But that's precisely what you're doing.
    Meanwhile, in the real world, tectonics and subduction is removing salty water from the bucket. It's greasing the sinking plates at subduction zones, and is boiled up and the water released as steam in volcanoes: think of that as new fresh water to fill the bucket, while the excess salts are left buried in the geology.
    If we conduct another experiment where, over time, "some amount" of salty water is removed from the bucket at a regular rate, and replaced by fresh, while I still spoon in salt, you'd now have no idea how long I'd been adding salt. Could be an hour, could be four billion years.
    Andy
    "We were schooner-rigged and rakish, with a long and lissome hull ..."
  2. #4552
    If you want to look at things that way, Gary - then of course it is just the same for the evolutionists.
    They would be, according to your theory, "trying to fit what they observe into what they believe " - ie there is onlly the material / natural (no supernatural necessary)
    Which is fine.
    Either way, it comes back to applying the scientific method, as distinct from scientific dogma.
    Frank
    Scientific method includes the fundamental Laws of Science. So how about applying the Laws of Science to the World Wide Flood, Frank?
  3. #4553
    May 2012
    Hah!
    Yes, Andy,
    Without checking again, i would guess that they were only concerned to determine the maximum possible age. As you point out, the salinity argument probably can't be used to determine the minimum. (If we dont know the initial salti ess, it could have been last Tuesday - or even a femosecond ago!).
    Doesn't invalidate the maximum determination cos that is, as you point out, determined by the initial saltiness and the "salt cycle"
    Your "Subduction Cycle " is interesting. Has anybody examined it?
    Regards,
    Frank
    (And i was beginning to think (hope?) this thread was dying - and my life could return to normal. ...)
  4. #4554
    You are the only one keeping it alive. The solution is at your finger tip. The one that pokes "Shut down".
    Before you go how about answering the question of the Laws of Physics and the Global Flood?
    I am beginning to think that your go to Creation.com has let you down on that one.
  5. #4555
    Which is fine.
    Frank
    No, seriously wrong Darwin didnít have a theory of evolution to start with and then try to fit what he observed into it. He Developed the theory based on what he had observed in the GalŠpagos Islands. Whereas your version is an interpretation of a story written in a book...big difference.
  6. #4556
    May 2012
    With respect, Gary, I would still hold to my point about presuppositional bias.
    Regardless of whether it was set down in a book or not, there have been god believers and non-believers since yonks.
    Respectfully,
    Frank
  7. #4557
    Respectfully,
    Frank
    Frank I have no problem with anyone believing in a god, it's their right to believe in whatever gets them through the dark of night. However what you are trying to do is make reality fit your belief and it's not going to work. It would be like me believing I can fly unaided. The physics will prove me wrong if I test the belief.
  8. #4558
    Jan 2005
    Deepest Darkest Wales
    There are some beliefs which are better not tested too hard.....
    And some which never get tested at all - which is what the demon is for,
  9. #4559
    May 2012
    *The physics will prove me wrong if I test the belief.
    Exactly!
  10. #4560
    Exactly!
    And the physics will prove you wrong on your great flood and young earth theories.
  11. #4561
    Scotland
    Incidentally, I followed up on reading your RATE stuff.
    I particularly love the idea that radioactive decay peaked during Creation Week (or Flood Time, the bible doesn't exactly specify which) when the entire planet would have reached 22000 Celsius as a result, and would have evaporated.
    But didn't.
    Andy
  12. #4562
    May 2012
    (people in glass houses ..... mutter, mutter)
    - so that would be the same Physics that explains everything in our Universe by invoking 20 times as much stuff outside of it ...???
  13. #4563
    May 2012
    btw good on ya for looking at RATE, Andy,
    may i suggest :
    https://creation.com/search?q=the+new+cosmology
    .....> Newton .......> Einstein ....... > Humphreys (? - or Hartnett, or Camelli, or ???) .........>
    but we seem to be getting somewhere.
    - as far as oceanic salinity goes:
    On reflection i cant see enough salty water being recycled out of the oceans by subduction at finger-nail growth speed - and anyway, wouldnt that be related to the amount of volcanic water ejected ? (i seem to remember that being mentioned in the article)
    I accept that it is far too imprecise to provide a date - but maybe we can be reasonably confident that it indicates an upper boundary for the presence of the oceans that is far too recent to allow current models of Evolution to work?
    I had to pass on Star formation stuff - too far above my head to comprehend - but i would note that some of the new cosmologies allow our local region to be thousands of years old and outer regions to be billlions of years yet with the same origin date
    (Einstein's "Twin Astronaut Paradox" and the fudged times in the GPS system come to mind)
    [maybe the same strange physics that allows Accelerated Radioactive Decay (the evidence of which we observe in the products of that accel. decay) - can also account for "Soaking up" or dissipating the heat???
    - but dont ask me........ ]
    anyway exciting times! - love the new vistas opening up!
    frank
  14. #4564
    frank
    Prove it Frank. Just because you personally can't see it is not proof, you need to provide data and calculations.
    Do those new vistas opening up include matching your Global Flood to the Laws of Physics any time soon?
  15. #4565
    Mar 2001
    Concord, Massachusetts
    So, my daughter had her wisdom teeth removed last week. I got to thinking about them. Turns out these teeth are an evolutionary leftover like the coccyx, and the appendix to name a few. We needed more teeth back in the day to grind coarse vegetable fiber.
    Frank! Do you have any of these evolutionary leftovers?
    "Wherever there is a channel for water, there is a road for the canoe. " - Thoreau
  16. #4566
    May 2012
    Look out! - gottem all - inc 6 of the 1st!
    - but Fitzy ya behind the times....
    https://creation.com/human-appendix
    (and even DNA turns out to not so much junk anymore...
    https://creation.com/astonishing-dna-complexity-update
    Regards,
    Frank
  17. #4567
    Mar 2001
    Creation.com has all the answers.... unless you read through the lines.
    I think I will just sit here on my vestige of a tail and enjoy my coffee.
  18. #4568
    Scotland
    3−4.5◊1014 g yr−1 I found in two minutes of Google.
    ...call it about a million cubic metres a day. (Which incidentally means an 'all the oceans' of water has been subducted since the Earth began.
    Andy
  19. #4569
    May 2012
    Quote Originally Posted by AndyG View Post
    Andy
    Wow!
  20. #4570
    May 2012
    UK. Cornwall, Suffolk.
    Ahhh, but how many beans in 5?
  21. #4571
    Wow!
    The subduction zones are very very long, present day subduction zone lengths are 61 940 km. At 8 cm per year that is 5 million sq m per year of sea bed salty mud. Big numbers all round.
  22. #4572
    Oct 1999
    St. Paul, MN, USA
    Shoveling the ocean with a pitchfork.
    for nature cannot be fooled."
    Richard Feynman
  23. #4573
    Quote Originally Posted by Keith Wilson View Post
    Just searching for a chink in which to insert a wedge and start hammering.
  24. #4574
    I’m impressed as well.
  25. #4575
    Iím impressed as well.
  26. #4576
    That is one of my favourites.
  27. #4577
    May 2012
    So, what you're saying is - it would take billions of years to take out by subduction the amount of salt that can be put back in the oceans in a max of 62 million years ?
    have I got that right?
  28. #4578
    May 2012
  29. #4579
    May 2012
    And while we are having fun - how about this!
    https://youtu.be/ogSttUF9mbo
    Yeh - i under stand hez beena norty boy (and some of the things hez torkin 'bout are a bit sus - but,hey! - since when does that matter?
    (and he's got a great delivery style .......)
    - first time ive viewed it
    and its only courtesy of fhis fhread i came acrossit
  30. #4580
    Scotland
    No. You've not got that right. As with just about everything else.
  31. #4581
    May 2012
    (grumble grumble)
    If Atlantic 3,200 kms wide (ruff approx) @ 8cm per yr. - takes 20 mill. yrs to sweep all the sediment water* under the continents.
    in 62 mill years it would get 3x goes at taking the salt out of the ocean
    not enuff???
    OK, be kind to me - its a long time since i did any simple math in order to win a bet.....
    *sediment water as opposed to water in the main body of the ocean
  32. #4582
    Scotland
    Re-read my post #4551.
    What's the 'some amount'?
    It turns out to be (am I surprised?) about the same as the rate of salt deposition - you've therefore got a near 'steady state' going on, which makes using ocean salinity as a clock useless for anything other than determining a minimum age. Still in the millions, mind you. Not a handful of thousands. Easy readable article here.
    I don't know how your mind works, Frank!, but on writing my stuff yesterday, I got thinking about tectonics - picturing scum bobbing about the surface of a hot crucible, and how, in our multi-continental times, we have more 'edges', more subduction going on than in Pangaea days. Was the Panthalassan ocean therefore saltier than ours? Do variable salinities mechanically change the rates of subduction? Etc.
    You may, on this thread, be trying to convince people (or perhaps just yourself) that YEC is a valid system, able to withstand scrutiny (it isn't), but inadvertently you're sending me off in Real World, real science directions that I may not have otherwise wandered down.
    For which, faint praise indeed, I thank you - and the other contributors who've opened my mind to some genetics , geology and evolutionary articles that have been fascinating.
  33. #4583
    (grumble grumble)
    not enuff???
    Wrong ocean Frank, subduction is happening around the Ring of Fire this year, the Atlantic is spreading.
  34. #4584
    May 2012
    I like to get to the bottom of things
    I have a certain amount of respect for the quantity and quality of the people involved
    I agree - it is a fascinating ride - at times .....
  35. #4585
    The earthquakes in Indonesia? Australia moving north.
