Results 36 to 70 of 80
Thread: Simmons Sea Skiff 18 in Missouri
    Jul 2005
    st.louis mo.
    Default Re: Simmons Sea Skiff 18 in Missouri
    I Made a little progress yesterday, after a trip to the Hardwood lumberyard for some red Oak and Sapele. I got the floors notched for the centerline cleat and a coat of epoxy on the floors and interior bottom.
    Simmons Sea Skiff build photos here:
    https://photos.google.com/share/AF1Q...92a21VWm02bmhR
    Jun 2008
    hood river oregon rgods4@msn.com
    What can I say? Very nice! I like! And here I thought I was the only crazy one. Glad you liked my idea. In my mind this center "cleat"/hogback thing does 2 things....gives a great landing for the floorboards; and I think it adds considerable stiffness right down the middle. It's like have two keels. Keep up the good work! I'm really impressed.
    Jul 2005
    st.louis mo.
    I like the Idea a lot, seems it will stiffen the Keel and the Floor boards, I toying with the Idea of using magnets to hold the floor boards in place.
    Jun 2008
    I love it! Don't laugh....machinists (is this the right word?) use "on" "off" magnets for holding dials in place when using the drill press/etc. I think you're on to something here. Electromagnets could be just the ticket.....(again, is that the correct word?) Switched at the helm. I've tried my limited abilities and I'm just going with screws. Have to carry a screw driver as part of my boat mechanic's kit.
    Jul 2017
    west haven ct
    I built an 18 SSS 2 years ago. I used Carnell's plans and WB's Ellis Rowe's article. I was very disappointed on launch day to find that my 210 pounds seated off center to starboard as in the original and Rowe profoundly lowered starboard freeboard. I tore out everything and relocated the fuel tank enclosure, the steering console and storage box/seat pedestal down the center line. It seems to me that the narrow forebody of this hull is very sensitive to weight distribution or maybe I'm just too chunky! Hope this helps you.
    Jul 2005
    st.louis mo.
    Thanks George! that does help, and very timely. I am a bit heavier than you so I will rethink my positioning! I'm heading out to the shop right now to start laying things out.
    Do you have any pictures you could post or email me? I would be very interested to see ho you did yours.
    Jul 2017
    west haven ct
    She is shrink wrapped for winter and I don't have any photos. I had the 12 gallon tank used by Rowe so I turned that lengthwise down the keel and forward of the beam less 6". The tank, 72 lbs of gas, it's enclosure/seating and the 16"x21"x36" console/battery box (group 24) which is part of the rear face of the gas tank enclosure help balance me and a separate seat pedestal/tackle box located just aft of the console. I have plenty of room and my partner has the front of the boat to himself. The boat behaves beautifully, high and dry and stable in as rough as I will risk on Long Island Sound. There are some photos of center console SSSes on the SSS site. Trust them not Rowe.
    Jul 2017
    west haven ct
    Thanks for affirming Erster. And thanks for having advised me, when I was building mine, not to permanently secure the floors. It has worked out very well. NB figo.
    Jun 2008
    I too used Rowe's article, but only using the pix and descriptions to help me figure out just how to conquer the questions I had about a particular phase of the build. Only 'off center' weight in my 22 is me on the starboard helm; but to help counteract that, I placed one of my two tanks on center, and the other just a little to the port. As to the 'sensitive' nature of the 18', I think I'd agree. The smaller the object, the easier it is to get things off kilter. With my 22, I've been somewhat concerned about that, but only when she's in the water will I know.
    Jul 2005
    st.louis mo.
    Well after three or so months of being away from the boat to work on my house I'm back at it. I have completed the 3rd plank on both sides and started fitting the floors. I have also mocked up a center console out of cardboard.
    Hopefully I'll get alot done over the rest of the summer.
    Jun 2008
    welcome back! It's been too long. Very nice progress photos. I'm affirming GEORGEC5's decision to not permantly attach floorboards. Mine are attached using #10 x 1 1/2" bronze screws set with bronze 'finishing washers'. I like the look. And, as of yet, the little 'bump' they make don't seem to be a 'tripping' issue.
    Jun 2008
    Issue of hanging strakes with hardly any clamps.....using "strake hangers", it's a snap. Here's how I hung mine: started out with lots of clothespin clamps + hangers, but on all subsequent strakes, only one clamp at transom, and one at stem; only hangers in between. Strakes hang true and snug to the strake lap.002.jpg003.jpg004.jpg005.jpg001.jpg
    Jun 2008
    hangers thickness match thickness of strake...in this case, 1/2" for each hanger piece. I used some card stock to space hanger pieces where they lap so they would fit just snugly down over the prior strake. In my 22, six hangers was fine. 004.jpg Once strake sat overnight, I used #8 x 7/8" bronze screws to tie thru the lap joint every 3 or 4" along the straighter lap section aft, and 3" as bow curve began.
    Jun 2008
    about all those clothespin clamps...they just sat gathering dust, so I gave them away.
    Jul 2005
    st.louis mo.
    I got a little more work done yesterday, The elevated casting / seating platforms in the rear. This was a lot of cutting and fitting even using templates!
    Jun 2008
    oh, wow! takes me a little to get my breath back. Soooo nice. Keep on with the great work. Hope my postin the strake hangers were helpful. When you're ready to do your side frames (unless you're going frameless), check out my site on Simmons Sea Skiff "revolutionary method" for doing side frames.....it's more 'pattern making'. But I'm really liking your work!
    Jul 2005
    st.louis mo.
    Thanks! I will do that!
    Jul 2005
    st.louis mo.
    Well it's been awhile since I last posted and I have only made a little progress. I closed on the sale of my business at the end of July so that kept me very busy for four months. I am staying on for a few more monthe to make the transition easier but hope to retire soon. So here is what I have been working on, I've struggled with console style and placement and I think this is what I am going to go with.
    Center console 36" tall. I wanted to round the front corners so I milled these .
    Upstate, SC USA
    That's a neat joint with the round over. I'll have to keep that one in my back pocket.
    Jun 2008
    retirement? best invention ever devised. Enjoy!!
    I like your humble approach to the radiused corners.... gotta love that! Nice work. And, the latest posted pix are examples of wonderful workmanship. She's turning out very well indeed. What did you use for your non-skid on the flooring?
    Jul 2005
    st.louis mo.
    Quote Originally Posted by simmons22 View Post
    Thanks! I'm using Totalboat Totaltread on all the floors for non skid.
    Jun 2008
    I'll be waiting to hear how you like it. My crushed walnut shells seem to be working fine. On my floorboards, they are held "in" place by epoxy - layed down unthickened epoxy, then sprinkled the shells into it; floorboards are simply coated in two coats of epoxy, no paint. However, on the bow and forward washboards, I painted on two nice coats of finish paint, sprinkled on the shells, then painted on top of then after letting the previous coat dry. Not sure if that's good enough though. I find occasional loose shell pieces here and there, especially if I've been turning/twisting my feet as I come and go. I may have to rethink that 'adhesion' concept for those areas. Perhaps, sanding off the shells and roughing the finish paint, then a layer of unthickened epoxy, then shells, then cover with finish paint....might be a better more permanent method.
    By the way, just discovered your "photo album"! I finally clicked on the https spot at bottom of one of your threads and bingo! there was a nice goldmine of wonderful build photos! Love looking at build photos! Keep on truckin.
    Jul 2005
    st.louis mo.
    I've gotten a bit more done with the weather being colder. I really am getting to the point where I need to decide what to do about the steering console.
    I decided on a 5" wide deck rail, these are the knees mocked up for it, there will be a 3/4" inwale let into them. I'm going to use 1/2' decking and the knees are on 12" centers
    Do you think I could space them out a bit more?
    Jun 2008
    lookin waaaay cool ! 1/2" thick deck rail is really stiff. You could probably easily get by with using half the number of knees. My deck rail is 3/8". Sturdy as all get out. Once tied into the sheer and the knees, 1/2" rail won't budge. Speaking of 'looking ahead', have you considered storage 'cubby holes' between knees/under rail? Great way to gain storage space for 'small items'. Glad you're back at it. Been watching for progress....now, here you go!
    Jun 2008
    my "cubbies" with deck rail - or washboard - port washboard interior port cubbies etc 005.jpgWASHBOARD starboard READY TO MOUNT 017.jpg I included a 'splash rail' on mine but cubby hole storage can easily be done under the deck rail.
    Upstate, SC USA
    I can see this playing out for you.
    Quote Originally Posted by non boaty person
    What are your hobbies?
    Boat building.
    That's nice. What scale model are you building?
    Simmons Sea skiff 18 in full size.
    That's like 20 inches long.
    No. It's more like 20 feet long.
    Jul 2005
    st.louis mo.
    Well it's been awhile since my last post but I have made a little more progress. The deck framing is basicly done, just need to add a piece for the transom. I'm having a hard time deciding on the steering console I had one mocked up but I decided it was to tall and I may want a seat at the front. I'm also wrestling with fuel tank and battery placement. These are not spacious boats! Here are some more pictures of my progress.
    Jun 2008
    sooo perfect! very, very nicely done! A pleasure to have to back. Keep up the good work.
    Nov 2012
    Farmingdale, Maine
    Lookin' good figo! Are you getting your hardwoods from U-Pick in St. Charles? That was my go-to place when I was contracting in St. Louis.
    I may have missed it but have you picked a motor yet?
    Mike
    "You may be orange, you may like hamburgers, and you may be a clown, but you sir are no Ronald McDonald" - John Stewart
    Jul 2005
    st.louis mo.
    Quote Originally Posted by Mike J View Post
    Mike
    Yes I am, and some from Schaller's in Green Park but they are moving to more S4S dimensional lumber.
    No motor yet, leaning twords an Evenrude etec 25hp . I'm also starting to look for a trailer.
    Nov 2012
    Farmingdale, Maine
    Right on Figo. Somewhere down the road I want to build one of Tom Lathrop's bluejacket designs and the etec will be my first choice.
    Carry on sir!
    May 2000
    St. Louis, MO
    Great work! Love it.
    Jun 2008
    when my buddy built his Simmons 18, he was trying to decide between an Etec 30 or 40hp. After much 'kickin around' between us, he went with the 40. Our thinking was, if one needs a little extra power for whatever reason, the 40 has it. He's on the Cheasapeake Bay a lot. He loves the 40, and glad he made that choice. Same with my choosing between a 70 or 90hp suzi for my 22 foot Simmons. They both weigh exactly the same. Since I'll be out in the salt from time to time, I figured the 90 gives me extra oomph in case I need it - especially coming in over the bar. Tom Simmons always claimed his 18 didn't need more than 25hp. Probably right. Whether 2 stroke vs 4 stroke is important or not, I don't know.
    Jul 2005
    st.louis mo.
    I think I'll stick with the 25hp, my young grandson will be using it and I would rather not have to much power!
    Jul 2005
    st.louis mo.
    I've made a little more progress in the last couple of months but yesterday is what i consider a milestone, the first section of decking went on.2019-07-01 10.04.55.jpg
    Since I live in St. Louis MO there is no supply of marine grade plywood so I ordered 3/8" fir Roseberg from Menards. It had to ship from Michigan somewhere.
    If I remember it was about $40.00 a sheet and came sandwiched between 2 sheets of 3/4" BC!
    here is a shot of the ply's on the fir, not the greatest but no voids either.
    I may glass the deck, haven't decided on that yet.
