Results 1 to 18 of 18
Thread: Mazda - engine breakthrough
    Default Mazda - engine breakthrough
    So they say. A compression-ignition gasoline engine --
    https://www.yahoo.com/finance/news/m...141200856.html
    Oct 2003
    Hell
    Default Re: Mazda - engine breakthrough
    Zoom zoom!
    Mar 2001
    Grosse Pointe, Michigan, USA
    Hyundai developed one about two years ago. It's been a long-running goal for many auto companies. Might note that most model airplane motors were compression-ignition, burning methanol.
    We'll see if they make it workable... but they seem mighty optimistic, saying it'll be here in 2019.
    Mar 2001
    FWIW, Mazda as been producing diesels and gasoline engines with the same compression ratio for several years. The difference between a DI gasoline engine and one burning diesel fuel isn't all that great. Gasoline-fueled engines tend to be less expensive, mainly due to the lower-cost fuel system.
    Feb 2010
    Freeland, WA
    If they achieve the fuel savings they are touting whilst maintaining drivability, it really is a remarkable achievement. Gone are the days of the " gas-guzzling dinosaurs ".
    Gerard>
    ​Freeland, WA
    Next election, vote against EVERY Republican, for EVERY office, at EVERY level. Be patriotic; save the country.
    I wonder whether the ignition temperatures will be as high as in a diesel.
    The row about pollution from diesels in Europe is due to the high temperatures oxidising nitrogen. Could be a dead end advance.
    Levels of NOx, emitted mostly by diesel vehicles, have been illegally high in 90% of the UKs urban areas since 2010. The toxic fumes are estimated to cause 23,500 early deaths a year and the problem has been called a public health emergency by a cross-party committee of MPs.
    Oct 2003
    Hell
    Why would the ignition temps be as high when gasoline has a significantly lower ignition temperature?
    Did some research, petrol is hotter, unless they use some trick like hot bulb ignition.
    The Self Ignition auto ignition temperature is lowest temperature at which a fuel such as petrol or diesel spontaneously ignites in normal atmosphere without an external source of ignition, such as a flame or spark.
    • Self ignition temperature of petrol is 247–280C.
    • Self ignition temperature of diesel is around 210C.
    So as seen, diesel has low self ignition temperature, and that's why diesel engine doesn't have a spark plug
    Feb 2004
    Texas
    The article has a link in the first line on the word "working", its really cool. Infiniti is developing a variable compression engine where the piston's reach is changed based on the current need.
    https://www.engadget.com/2016/08/14/...-turbo-engine/
    Aug 2013
    S.W. Florida
    Ho-Hum, another technological miracle from the PR Department.
    Footnotes:
    *3 Engine is still under development and figures are subject to change.
    Mazda Skyactiv-X Engine (LINK)
    Mercedes DiesOtto Engine (2007) (LINK)
    with what pleasure, what joy,
    Ithaka, by Cavafy
    Isle of Mull, Scotland
    The compression-ignition (wrongly termed Diesel) model plane engines rely on ether in the fuel mix to achieve ignition. The methanol/castor engines rely on glow plugs.
    This might not seem related and those of you without an interest in current Formula 1 might not have known it went on http://www.f1technical.net/news/20316 .The change to direct injection of fuel rather than port or inlet injection reduced the risk of detonation that was likely with compression ratios above about 13:1.The current regulations for Formula 1 stipulate that the compression ratio is not to exceed 18:1 and this is with a turbocharged engine.Now you could consider that an engine strongly compressing and having fuel injected into a pre-combustion chamber is on the verge of being a diesel and I have to wonder if the spark is absolutely necessary.By an interesting quirk,the direct fuel injection racing engine was refined by Audi and the commercial application by Mahle,both companies within the Volkswagen portfolio.I believe their diesels have been a bit controversial though.
    Sep 2002
    The ignition on model airplane motors, at least the 2 stroke ones not known as "diesel" is assisted by glow plugs, a hot wire maintained by the heat of the previous combustions. Much like a "hot bulb" engine.
    John Welsford, with fingers still scarred by starting the damn things.
    May 2002
    MD
    Looks useful where people are already maximizing the efficiency of auto transportation.
    http://www.independent.co.uk/news/uk...-a7878306.html
    Quote Originally Posted by LeeG View Post
    Hence my comment about temperature and NOx pollution.
    Quote Originally Posted by Gerarddm View Post
    Really? Have you seen the monster pickup trucks they sell these days? It's a big piece of the market.
    Canadia
    Quote Originally Posted by birlinn View Post
    A compression ignition engine is a diesel. The particular fuel used is inconsequential to the nomenclature. If I recall correctly the first compression ignition engine ran on coal dust.
    I'll just take my chances with those salt water joys.
    AR
