Results 1 to 3 of 3
Thread: How to identify 2 Phrase stepper motor coil pairs with a multi meter
    Aug 2017
    Berlin, Germany
    Thumbs up How to identify 2 Phrase stepper motor coil pairs with a multi meter
    Need to consider the following parameters:
    1) Holding Torque Large motors require high torque.
    2) Output Speed If the output speed is high, torque is lower and vice versa.
    3) Pulses Per Second It refers to no-load starting frequency of stepping motor.
    4) Phase 2 Phase motors are often used for normal applications. 3 Phase motors are used for high speed and high torque requirements.
    5) Special Parameters, In addition, we may need to consider a few special parameters such as water proofing, output shaft length, and diameter among others. (an example from http://www.powerjackmotion.com/produ...stepper-motor/ )
    I hope you people can help me about Stepper motor wiring for sure. Please give me a better solution. I will thankful to you forever.
    Any better idea would be highly appreciated.
    Thanks.
    Default Re: How to identify 2 Phrase stepper motor coil pairs with a multi meter
    A subject I find fascinating and the answer to which will be found with a spot of searching.Failing that,try www.cnczone.com .
    Aug 2017
    Berlin, Germany
    Hello John, Thanks for sharing. I found there too many information threads about stepper motor.
