Results 1 to 8 of 8
Thread: Another stupid battery question
    Mountain lakes of Vermont
    Default Another stupid battery question
    I now have two 12 volt deep cycle batteries, each rated at 100 amp hours, hooked up in series to 24 volts.
    From what I've read, I'd still have 100 amp hours. Is this correct? A google search says yes, but I'd rather get confirmation here.
    Thanks for any answers.
    Default Re: Another stupid battery question
    Yes
    Sep 2004
    Huntsville, AL
    Yes indeed.
    Will
    Looks like the yes's have it! Thanks.
    ... but at 24 volts your amperage draw is half what it would be at 12 volts, so you effectively double your capacity.
    Jun 2015
    Graceville, Florida
    {nitpicking} Actually, that depends entirely on what kind of load he has. A resistive load will draw double the current at 24 Volts instead of 12 Volts, running the batteries down twice as fast. Reactive loads will draw more current at 24 Volts than at 12 Volts, but less than double. Only PWM input power converters will draw less current at 24 volts than at 12 Volts. {\nitpicking}
    regards,
    Joe
    These days, everything I do is just "puttering around"
    Quote Originally Posted by slowpoke View Post
    regards,
    Joe
    Resistive load... reactive load... all new terms to me. So which is my 24 volt trolling motor?
    Jun 2015
    Graceville, Florida
    The motor is mostly an Inductive Reactance load, with a little resistance thrown in. However, it is designed to operate on 24 Volts and while it will draw less current on 12 Volts, the decrease in thrust will be much greater than the decrease in current.
    regards,
    Joe
