Results 1 to 14 of 14
Thread: Fenders for painted boat
    Dec 2011
    Default Fenders for painted boat
    Sailrite's "boat blanket" material is what they sell to make fender covers with. The description specifically states that this material is intended for hard surfaces such as gel coat and warns to us caution with painted surfaces. It got me thinking, what's a good practice for fenders on painted wooden boats. I'm using Kirby paint. It's a pretty soft paint. Advice would be appreciated.
    Aug 2016
    Hobart, Tasmania, Australia
    Default Re: Fenders for painted boat
    A low cost solution is to source old knitted jumpers, cut off the arms and slide them over the fender, tied at the top if necessary. I like the wear from fenders on my boats painted rub rails. It gives me a feel for the condition of the paint.
    Aug 2009
    Olympia, WA, USA
    I'm using Kirby's too. I sewed a fender-cover out of cheap synthetic terry cloth ages ago, and had enough material left over I sewed a new one last year. It's okay, not great. It does chafe a bit more than I'd like, but hasn't (yet) gone down to wood with the Kirby's, over a six-month season. It was harder on the Z-spar I used before I changed to Kirby's, too.
    Hinckley's used to use polarfleece for their covers. I've been thinking of doing the same.
    Alex
    I mostly use ball fenders because they can roll in any direction and thus don't harm my topsides. With the cylinder fenders, I either make sure that it's vertically hung to swing or horizontally mounted to not move at all.
    My painted lapstrake sailboat fetches up hard on her mooring buoy for an hour or more at a time, at least twice a day. During their "bonding" time, the topsides and the buoy are continually rubbing together. The old hard pvc buoy wrecked havoc, but the new inflatable buoy does no damage to the planks nor to the paint. I can't imagine that any fabric covering could offer an improvement.
    Mar 2006
    La Conner, WA
    New PVC fenders are shiny, bead up water and work great to protect your topside paint. However on Day 2 they begin to lose that new look and eventually become giant abrasive pads, scouring away on your hull. Run your hand over an older one and you can feel the bits of grit it has picked up, and now that shiny surface looks and feels like clay and wreaks havoc on your paint job.
    The solution is a fleece cover, and there are many suppliers, the fabric does not harm the paint, is easily washed, and you can monogram the "S.S Minnow" on the cover. They are more expensive than the fender but more than pay for themselves in extending the life of your topside paint
    ^^ This
    No covers. They will eventually be an effective sandpaper
    Dec 2011
    Thanks for the help.
    Jill poles (spelling?). Hold her off if using soft paint.
    Of spring her loosely.
    Or use 2 part coating.
    Mar 2006
    La Conner, WA
    I have to disagree canoeyawl, all, I mean all the boats I have seen that have damage to their paint or their gelcoat are from fenders with no protective cover. The fender is the the culprit, you can see the pattern of their abrasive swing on the hull.
    The only thing that will protect is a cover made from the same recycled pop bottles as your fleece jacket, it can be cleaned, the fender, once it ages, only becomes a more abrasive agent.
    Apr 2007
    Cundys Harbor, Maine
    I too use ball fenders and have had goo from the plastic fender deposit on the topsides (Brightsides). The only thing I've found to remove the goo is sandpaper. Switching to a fleece covered ball solved the problem. If you do this, be prepared for the "fuzzy balls" comments.
    Dave
    May 1999
    West Boothbay Harbor, Maine
    If you're in salt water it can be helpful to wash your fleece covers from time to time also. I use Kirby's and the boat's at a dock for four months in winter (sprung off the dock with the fenders held in place from swinging) but they still pick up salt and dirt, both of which can be abrasive.
    "... and the great shroud of the sea rolled on as it rolled five thousand years ago."
    Meg's laying at the dock all last winter left the starboard side considerably more weathered than the port side against the dock. No fender marks after seven months and all those storms.
    Aug 2008
    Scotland
    I have been known to buy used jeans from charity shops. Cut the legs off for fender covers and you have a collection of denim shorts for Summer use.
    Somewhere between Murder and Suicide, there is a place called Merseyside.
