Results 1 to 32 of 32
Thread: Wood for stems and keelsons
    Jan 2017
    West Yorkshire, UK
    Default Wood for stems and keelsons
    Hi all
    I'm at the point where I'm going to have make decision about the wood to use for the keelson and apron/stem for my Oughtred Guillemot.
    Should I be content to use the 'overlapped/ planks' method, using something like Douglas Fir (or something else?) or should I be trying to go down the more tricky laminating route? (I'm imagining the finished boat being painted (thereby hopefully hiding my errors!), so perhaps it doesn't matter...)
    Either way, I could do with some advice about what types of wood I should be considering.
    Thanks in advance.
    Noel
    Juneau, Alaska
    Default Re: Wood for stems and keelsons
    Doug Fir would be fine. Carry on.
    -Jim
    Sucker for a pretty face.
    Jan 2017
    West Yorkshire, UK
    Thanks, Jim. If I can find some the right dimensions, I will do!
    (Would you bother laminating the stem??)
    Juneau, Alaska
    I would laminate it. There will be less waste out out straight grained stock.
    -Jim
    I would agree with this, no worries about short grain or grain run out, so stronger.
    These folk supply compass timber and bends for boatbuilding, https://graythwaite.com/the-estate/forestry-sawmill/ they might be able to supply a proper grown crook for your stem
    Jan 2017
    West Yorkshire, UK
    Thanks for this, Nick. Where to find timber and what exactly to look for (what species and the details of 'what's good enough') are things I'm struggling with. I've used few places near where I live in West Yorkshire, but the more recommendations the better... The idea of proper crooks is appealing - what do I ask for, species-wise?
    (I was up in the Lakes this weekend doing a bit of sailing. I thought of you - you're in Walney, yes? I did some flying there many years ago (1988, I think...).)
    Quote Originally Posted by Racundra View Post
    Oak is favourite for crooks.
    Yes, North Scale, just behind the Crown, you'll have passed the entrance to our estate driving to the airfield.
    Jan 2017
    West Yorkshire, UK
    OK. So no worries on the 'steer clear of oak - you can't use epoxy to glue it' front?
    That is an American view with American oak, this is an American forum . Check with your glue suppliers technical department.
    Jan 2017
    West Yorkshire, UK
    Hehe... I haven't had any issues gluing the oak I used for my gaff jaws, so fingers crossed... (Must post some pictures at some point... You helped out with those too... You might not recall - you seem quite busy on here!)
    se pa (Bristol PA)
    Noel,. Which model are you building? Consider steam bending, it's really one of the fascinating fun things that can be done for boat builds.
    Jan 2017
    West Yorkshire, UK
    It's the Guillemot, 11'6" long... https://smallboatsmonthly.com/article/guillemot/
    I like the idea of fascinating and fun, Denise, but I am limited in knowledge and skill and only have a small garage with a few tools to hand. I'm very much learning on the job, so to speak.
    When you say 'steam bending,' are you suggesting taking a single blank and steaming and bending it into the required shape(ish) before cutting it to its finished shape and hoping it doesn't spring back?
    Noel
    I am now a gentleman of leisure, so I can do what I want with my time.
    With Der Management's permission of course.
    se pa (Bristol PA)
    Spring back? I realize for one boat it may not be necessary but it is definitely fun.
    Jan 2017
    West Yorkshire, UK
    That permission is more valuable than almost anything!
    Jan 2017
    West Yorkshire, UK
    That looks like a piece of cake! All I need now is to find a way (without a planer/thicknesser) of getting enough laminates to do the job etc...
    se pa (Bristol PA)
    Sawn lams will glue well, solid wood bends almost as easy it's all about prep really
    se pa (Bristol PA)
    what a sweet boat Ian designed! Going to build it as show Noel?
    Jan 2017
    West Yorkshire, UK
    Do you mean am I going to do an "as it's built" thread? I don't know. I'm nervous that I don't know anywhere near enough and it'll be a very stop start affair!! 😔
    If you are going to build this using traditional techniques, grown crooks are the way to go, and no epoxy needs to be harmed in the build.
    Have you got a copy of this?
    https://www.amazon.co.uk/d/Books/Cli...her/0713636432
    I recommend that you have it on your shelves.
    se pa (Bristol PA)
    Well you mentioned that you were ready to get the lumber for the keel and stem..
    the mention overlap planks?
    The photo shows a traditionally built boat.
    many people go with strip buids as first boats.
    MY very fist canoe was strip build. over 20yrs ago now. I traded it for a very old boat discarded by a museum.
    Per Ian's site. http://nisboats.com/oughtred/mainpages/dinghies.html
    Construction
    Options:
    Traditional planking,
    strip planking,
    cold molding.
    Jan 2017
    West Yorkshire, UK
    Just ordered it. I have Iain's book and John Hill's too. Another can't hurt... 😏
    I do fancy crooks... I'll measure up tonight, so I know what I'm talking about when I speak to them... (apron and stem both from crooks, yes? And DF for the keelson? What about the transom?)
    Questions, questions...!
    Just ordered it. I have Iain's book and John Hill's too. Another can't hurt... 
    Yes, and then some smaller crooks for quarter knees, standing knees and breasthook. And a substantial crook for the stern knee.
    Oak, elm or a tropical hard wood for the transom are traditional.
    Dec 2005
    Shoreline, Washington
    Laminating is a great technology. It's also a messy tedious pain in the ass. If you're in a place where you can find a natural crook - stunning, fantastic.
    On the other hand you can follow the sawn glued together pieces of backbone scheme as demonstrated in the plans. Once all the bits are bonded together, including the planking, this construction is perfectly sound.
    We are talking about glued lapstrake, yes?
    For a variety of reasons, oak would be about my last choice for most parts of this construction. But I suppose that has something to do with locale - you've got to use what you can get your hands on.
    Jan 2017
    West Yorkshire, UK
    Hi Eric
    Glued lapstrake, yes.
    My first thoughts were to laminate, but then I read of people using the sawn and glued together method and it seemed MUCH more straightforward without any real drawback. Then Nick mentioned crooks. I think I might have to sit down when I ask the price of them though...!
    (What would be your first choice of stem material? And does the stem material need to be the same as the keelson?)
    Noel
    Sent from my iPad using Tapatalk Pro
    Nov 2017
    Rangeley, Maine, USA
    This description of laminating stems sounds right to me. Yields a good result, but is a tedious mess.
    i'm getting organized to start an Oughted Caledonia Yawl. I'll be piecing the stems. I'm puzzling over what sort of wood to use. I'd like to use hardwood, but don't like the gluing complexities of White Oak. Any suggestions for a good alternative? I'm located in Maine. Wondering about Ash heartwood (if I can find some). Other ideas I should consider?
    se pa (Bristol PA)
    Quote Originally Posted by DanSimonds View Post
    West systems G Flex solved the white oak glueing problem, but there's no reason you can't steam bend Ash or White Oak. Everybody yells that Ash rots quickly but who builds a small boat and leaves it in the water 24/7 365?
    Jun 2012
    As appealing as a crook might be, if one doesn't turn up, don't shy away from the laminating. Fairly easily done if you have the clamps and access to a thickness planner (or careful work on the table saw). As for the mess, sure there is some, but you are going to be doing a bit of gluing with the laps anyway so get used to being a little sticky .
    I laminated stems for Oughtred St. Ayles skiff with students and they thought it was wonderful fun. We laminated the outer stem right on the boat after the planking was done. This was a little trickier and I now have some strap clamps with epoxy-stiff straps, but lesson learned. A little packing tape goes a long way to avoid gluing your laminations to something you don't want permanently attached to the boat.
    Jan 2017
    West Yorkshire, UK
    Quote Originally Posted by jtdums View Post
    I was hunting for crooks and gave up. I went for laminating in the end and cut 1/8" thick strips of iroko 2 1/2" wide and 50+" long. I then steamed them in an old PVC waste pipe, using a wallpaper stripper. I melted the pipe, but bent the laminates! The laminating was a bit of an unholy mess, especially as my resin pump gave up the ghost half way through, but it wasn't really that tough, and I'm pleased I did it now and the end result is good. I laminated the inner stem first, and then laminated the outer stem around it. I'm only 3 planks into the planking, but it looks OK so far...
    se pa (Bristol PA)
    Did you actually need to steam 1/8" strips? Oh yes PVC gets soft real fast,. How's the iroko with gluing?
    Jan 2017
    West Yorkshire, UK
    Well I tried a piece gently and it made all sorts of creaking sounds, so I thought “better safe than sorry,” and steamed them all. They bent round my former really easily and only took 20 minutes steaming... I also steamed my keelson where it bends down from midships to the transom. That also made some interesting noises, and I’m sure I couldn’t have bent it without steaming it. Iain Oughtred suggests cutting a ‘split’ into it to make it easier to bend, but I figured my sawing skills would have been tested to breaking point (literally!) to put that cut into it. I’m happy with the steaming approach and wouldn’t hesitate to try it again. The iroko glued up very well. I tried a yes piece and the wood broke before the epoxy, with no sign that the glue wasn’t bonding. I didn’t clean up the sawn faces of my 1/8” laminates, as I figured that rough was probably better in terms of providing a surface to key to... I’m not floating my boat prematurely of course, but fingers crossed! 😁
    Nov 2017
    Are you using Iroko for the rest of the backbone as well (keelson, keel)? What about floors? Easy to work with?
